Cornering - Episode IV, No Hope
Easy-X
PostPosted: 00:19 - 26 Oct 2019    Post subject: Cornering - Episode IV, No Hope Reply with quote
Okay, so I admit I'm a total n00b and I've only had some sort of bike since Jan/Feb and passed my test in the summer but I seem to have some sort of mental block when it comes to extreme hairpins, i.e. > 270 degrees.
Bonus side effect on small roundabouts though (where you're almost doubling back on yourself) I've been tooted by cars for going slow and, once at my exit, it's full throttle; goodbye, baby! Almost like I'm trolling them...
This is not helping Very Happy
PostPosted: 00:22 - 26 Oct 2019    Post subject: Reply with quote
As ever. Look where you want to go.
On a sharp hairpin, this may well involve looking over your shoulder.
Easy-X
PostPosted: 00:29 - 26 Oct 2019    Post subject: Reply with quote
Mmm... it's like I'm already forgetting things I learnt in the Mod1/2 training Shocked
chickenstrip
PostPosted: 00:47 - 26 Oct 2019    Post subject: Reply with quote
Relaxed grip on the bars. Well, on anything other than a cruiser, anyway Smile
chris_hu_cheng
PostPosted: 12:17 - 26 Oct 2019    Post subject: Reply with quote
PRACTICE
Every bit of advice is just guidance, helpful in some contexts but not in others and every person is a different size, shape, and level of balance, body feel, control etc.
You can look and not turn that way (being able to do that is a skill to learn in itself). You can hurtle down the motorway lean off the bike in one direction and push the bike away from you to a fairly alarming angle and still continue in a straight line, so all the advice about weighting pegs etc. etc. may or may not apply to you as you may be doing whatever that bit of advice helps with naturally without thinking anyway.
I just practice regularly in car parks, a rolling uturn from 20mph without using brake (apart from engine braking and cornering braking) within two parking spaces. Uturns with rear brake and slipping clutch within 1.5 parking spaces. Ride a 125 on tick over (no throttle) and uturn.
Faster speed uturns, see how narrow you can make them if you can find space to practices. I am learning sliding turning stops with rear brake and stoppies now (more practical skills, I will worry about flashier things like wheelies much later).
Go around in every decreasing circles.....
I force myself to keep practicing by looping around in a tight space in front of the garage when I come home etc.
I find it relaxing and fun.. almost like a meditation and you can do the same thing 30 times in a row which is hard to do on a road.
Oh yeah do it sometimes when it is raining, or cold, or you are feeling tired riding home from work, just like real life.
I had a comment once along the lines of "what is the point practicing u-turns in two parking spaces when the Mod1 gives you more than a third more space?" Well one thing I can pretty much guarantee. If you can reliably u-turn in small spaces (in various ways) and you add some practice of other manoeuvres, just to get better.... NO FUCKING MINI ROUNDABOUT OR HAIRPIN BEND IS EVER GOING TO BOTHER YOU AGAIN.
SpiritMr89
PostPosted: 12:33 - 26 Oct 2019    Post subject: Reply with quote
If you are a total noob. Then you won't be going knee down to the shops for milk.
Just wait for a dry day and have a laugh. The more relaxed you are the easier it will be.
And at the end of the day if you are enjoying it then what is the problem?
Seen plenty of nobs who scream down straights then hammer the anchors on.
Hello
Kentol750
PostPosted: 12:35 - 26 Oct 2019    Post subject: Reply with quote
Think about what your riding, it's never going to turn quickly. Just get it out of your head that you're going slowly, follow the advice above, and above all take it easy in the shitty weather conditions we are experiencing.
Some bikes.
PostPosted: 13:03 - 26 Oct 2019    Post subject: Reply with quote
OK pro. Not everyone can corner at 150mph, anchors need to be applied init.
doggone
PostPosted: 13:28 - 26 Oct 2019    Post subject: Reply with quote
It sounds like you aren't really understanding what makes the bike lean into a turn and stand up again, it would be beneficial to watch a few videos about counter-steering and practice doing it somewhere safe.
barrkel
PostPosted: 20:25 - 26 Oct 2019    Post subject: Reply with quote
Look where you're going to be exiting, almost over your shoulder if necessary.
On actual hairpins (on mountains, rather than U-turns on mini-roundabouts) it helps to widen the turn: move to outer edge of corner first (on opposite side of road if necessary), and turn in sooner so you end up around the bend on the correct side of the road. Uphill is generally easier than down.
On tight turns: practice slow control at full lock, revving engine and balancing rear brake and clutch to control power. This is enough for almost any situation on the road, and is safest if it's really wet - roundabouts can be awash with diesel. On anything less than a sports bike or sports naked you can u-turn on most roads with this.
Even tighter turns can be done at slow speed with counter-lean, where you tip the bike into the turn underneath while you lean off the other way, effectively keeping your torso upright. But you need to master slow control first because you need to be able to apply a burst of power if it tips in too far. You also need clearance, it's a riskier way to go between e.g. cars when filtering; with the bike tipped over, if you tap the front brakes you will drop it.
The only way out once it starts to tip in is applying throttle and straightening up - it'll be too fast to stop with your leg and probably too heavy. So work your way up to this gradually from the slow control at full lock situation. Do it in an empty car park on a Sunday, and don't push too far too fast unless you don't mind if you drop it.
Alex A
PostPosted: 21:06 - 26 Oct 2019    Post subject: Reply with quote
All sorts of people will give you all sorts of advice. We don't all work the same way. Some of the advice will be helpful, some will make you over-think and will be counter productive, and some will be outright wrong and unhelpful.
There's no substitute for mileage, especially the right mileage.
Ride whenever you can. And ride mountain roads!
This is a good one
Kentol750
PostPosted: 00:30 - 27 Oct 2019    Post subject: Reply with quote
How many switchback mountain roads do you encounter daily?
Some bikes.
ThatDippyTwat
PostPosted: 07:50 - 27 Oct 2019    Post subject: Reply with quote
Go see the instructor you passed with. Practise what you learn. actually practise it, actively thinking about it. Most will offer lessons in actually riding a bike, not passing a test. With no test to potentially fail, you'll have fun doing it as well.
I tagged along on one to give feedback when an instructor I know was starting to offer them to new riders with a fresh license, and learned more than I thought I would.
om15
PostPosted: 12:00 - 28 Oct 2019    Post subject: Reply with quote
Lots of duff gen on the internet about cornering, some strange ideas, for some basic information try to source the IAM full control document, I have tried a google but the link is disabled unfortunately, I have a pdf copy which I can email to you if you give me a contact.
Alcohol doesn't solve problems, but neither does milk
PostPosted: 13:31 - 28 Oct 2019    Post subject: Reply with quote
With the wife's permission Smile
Easy-X
PostPosted: 13:39 - 28 Oct 2019    Post subject: Reply with quote
Here's a odd thing: I've ridden to work today and been comfortably flicking the bike left and right - almost like I knew what I was doing! So what has changed? Thinking
"You've received quality moral support from BCF members!"
Yes, of course Smile
RhynoCZ
PostPosted: 13:55 - 28 Oct 2019    Post subject: Reply with quote
Less thinking, more riding.
Years ago, I found this video and it changed the way I ride today: https://www.youtube.com/watch?v=zt9lB-LErQ4
Especially the bit about leaving some space between the tank and your manly parts. Also, keeping my torso up with my core muscles rather than using my arms. Many people tend to push their bars, efectly doing pushups while riding.
The video above combined with perfectly executed rev matching will give you tons of stability and confidence. Especially on bigger displacement engine bikes, where being careless about your downshifts may result in the rear wheel getting locked. Even if for a split of a second, you do not want your rear wheel to skip under braking/slowing down in front of a corner.
Don't be aggressive, be smooth, as it is a smooth approach that leads to greater stability, speed and confidence. Karma
WreckTangle
PostPosted: 14:11 - 28 Oct 2019    Post subject: Reply with quote
I found a good way to learn how to corner. If you can find a oval shaped roundabout (or as close to a oval shape that you can get) , late in the evening, when there is no one around, go round the roundabout multiple times. first start slowly, then each time you go round , see how fast you can go round without falling off.
I found that if push the right handle down a bit when you go round the corner, the bike will lean in to the corner, keep doing this until the corner stops, and rinse and repeat. Try to steer in to the corner, by pressing the handle bar down, if you can, try and steer with your body ( cannot explain this, you will learn in due course) and avoid looking straight ahead, try to look in to the far right corner (as much as your head can turn), and you will realise that you bike and the body will kind of 'flow' into the direction you aim your head in to
I remember going round the same roundabout about 13 times before I got the hang of it Mr. Green
Obviously, as I said, make sure this is in the evening, when there is no one round to ask why you are doing this......
My wife asked me to get her something that goes from 0-100 in under 5 seconds for her birthday. ......................I got her a bathroom scale.
RhynoCZ
PostPosted: 14:14 - 28 Oct 2019    Post subject: Reply with quote
Just tell people you either got lost or you can't decide whether to go home or keep on riding. Thinking
PostPosted: 15:08 - 28 Oct 2019    Post subject: Reply with quote
Some bikes probably don't have the capability of certain combinations of speed and corner.
Am I making a subtle dig at cruisers? Well, it seems not so subtle now!
Easy-X
PostPosted: 18:33 - 28 Oct 2019    Post subject: Reply with quote
Why are you writing so small... I know no shame Rolling Eyes
Easy-X
PostPosted: 20:28 - 29 Oct 2019    Post subject: Reply with quote
I'm starting to believe swapping from a back pack to a top box is seriously improving my cornering. Does that make any sense?!
chickenstrip
PostPosted: 20:31 - 29 Oct 2019    Post subject: Reply with quote
By god, I think you've just hit on how we can all be like MM! Laughing
Ribenapigeon
PostPosted: 19:01 - 31 Oct 2019    Post subject: Reply with quote
Go at your own speed and don't feel pressured to speed up. Roundabouts are a Bastard as well as they are often pasted with oils and crap and worth being more cautious on.
Easy-X
PostPosted: 00:02 - 01 Nov 2019    Post subject: Reply with quote
Wise words Thumbs Up
Weird, I feel like I'm riding a lot better since starting this thread!
https://media.giphy.com/media/TG9y0s7JNmv5BHu0k5/giphy.gif
The last post was made 6 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 10.56 - MySQL Queries: 13 - Page Size: 135.11 Kb
