| TheGazWaz |
 TheGazWaz Nitrous Nuisance
| stinkwheel |
 Posted: 18:28 - 29 Oct 2019 Post subject: |
You only need to remove the rocker covers to CHECK the valve clearances. If they are all within tolerances, put it back on and carry on. The cams only need to come out if they need adjusting.
I'd rather re-shim a head than change out steering head bearings. It all does what it says in the book, you just need to be clean, tidy and methodical. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Bhud |
 Bhud World Chat Champion
 Posted: 19:09 - 29 Oct 2019 Post subject: |
Valve clearances are very quick and easy to check on many bikes, after you've done them a couple of times. Also keep changing the oil and oil filter at regular intervals, and make sure the cam chain tensioner is doing its job. Stay on top of these things and you won't have to worry about mollycoddling your engine. Cams may have to come out but don't worry, they go back in.  |
| Easy-X |
 Easy-X Super Spammer
 Posted: 20:20 - 29 Oct 2019 Post subject: |
My work colleague was in the same boat. He spent about a week fretting about it I think his CBR had done something like 20k.
All the work was in taking off the fairings. Once past that he found the shims were perfectly fine. Better safe that sorry  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Old Git Racing |
 Old Git Racing World Chat Champion
| BusterGonads |
 BusterGonads Trackday Trickster
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
 Posted: 23:10 - 30 Oct 2019 Post subject: |
Make sure engine is cold, best left overnight.
Checking the timing marks is not hard, but it does have to be bang on.
Lots of writing down measurements in boxes and triple checking calculations.
If you do need shims then you either wait for them to be delivered or you buy a mixed set beforehand.
So just buy the shims now, as sods law dictates that waste of money guarantees the clearances will be in tolerance, either that or the sizes you need are not in the box
Decent feeler gauges, and a light drag is what you're after.
If you're taking the cam holder out, you need to torque it up in the right order and also to the correct torque value, otherwise those nicely adjusted shims might not fit properly anymore. ____________________
'81 CG125, '97 FZS600 : '99 CBR600F4, '09 KTM RC8 |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| Fizzer Thou |
 Posted: 20:09 - 31 Oct 2019 Post subject: |
When I bought my Exup 1000 back in 1992 it was the first bike I had owned that used shims.I bought the Haynes manual and set about checking the clearances using Imperial feeler gauges as they go down to a thinner size so can be more accurately measured.Out of 20 valves then eight were found to be below the minimum,both on the inlet and exhaust.There was no way I was going to take it into a shop so I set about doing them myself and I was pleased that I found the procedure relatively easy and straight-forward.
Since then I have done them on other peoples bikes with the owners supervision,so that they could take notes and measurements.
As for changing engines instead of shims......  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| mentalboy |
 mentalboy World Chat Champion
| TheGazWaz |
| Easy-X |
The last post was made 6 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
