Still got a oil leak from around the starter motor
breakyyyy
PostPosted: 14:47 - 30 Oct 2019    Post subject: Still got a oil leak from around the starter motor Reply with quote
Hi, I've got a 92 tdm 850 and I've got an oil leak from around the starter motor area and I have just fitted an original yamaha o ring oil seal but it's still leaking!!!!
Could it be the wrong grade engine oil or something silly like that?
I'll try again tomorrow and make as clean as possible and yes I did oil the o ring before putting it in I'm just getting frustrated with it now lol
Breakyyyy
Nobby the Bastard
Harley Gaydar
PostPosted: 16:07 - 30 Oct 2019    Post subject: Re: Still got a oil leak from around the starter motor Reply with quote
No. It'll be badly fitted, most likely the mating surfaces weren't surgically clean or you haven't done up properly.
There is an outside chance of a cracked casing or warped mating surfaces but these are unlikely.
Triumph Sprint ST 1050
RhynoCZ
PostPosted: 16:11 - 30 Oct 2019    Post subject: Reply with quote
Did you lube the o-ring before putting it there?
Phoenix
Twisted Firestarter
PostPosted: 04:18 - 02 Nov 2019    Post subject: Reply with quote
Is it definitely coming past the o-ring seal and not from a crack somewhere? Check the part number on the starter motor, could be that it fits but isn't actually the right one and so doesn't seal properly.
breakyyyy
PostPosted: 16:42 - 15 Nov 2019    Post subject: Re: Still got a oil leak from around the starter motor Reply with quote
[quote="Nobby the Bastard"]
There is an outside chance of a cracked casing or warped mating surfaces but these are unlikely.[/quote
Just an update on my oil leak... It turns out it wasn't the starter motor o ring but it was a knackered seal around the output shaft where the front sprocket is bolted on.
Breakyyyy
Nobby the Bastard
Harley Gaydar
PostPosted: 17:27 - 15 Nov 2019    Post subject: Reply with quote
The obvious question is,,is it an actual leak or is it chain lube?
breakyyyy
PostPosted: 18:26 - 15 Nov 2019    Post subject: Reply with quote
It was an actual leak I could see the oil leaking from around the shaft while the engine was running, I've changed the seal today and its fixed no more leaks
Breakyyyy
The last post was made 6 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 51.42 Kb
