Fes125 burning oil
bazzaboy2010
PostPosted: 14:16 - 02 Nov 2019    Post subject: Fes125 burning oil Reply with quote
Got a 08 s-wing fes125 that was rebuilt. Everything seems ok. I do sometimes get a backfire but that is not all the time. Some days it happens and others it doesn't. But the main thing is it seems to burn oil a lot quicker. Any ideas would be great
jaffa90
PostPosted: 14:43 - 02 Nov 2019    Post subject: Reply with quote
Oh dear, if you have blow by (oil on cyl wall)i would check if the crankcase is breathing first.
WD Forte
PostPosted: 14:56 - 02 Nov 2019    Post subject: Reply with quote
"Rebuilt"
That's a term that can mean anything and nothing.
from a crank up detailed renovation to a wipe off with an oily rag and tart up.
bikers smell of wee
bazzaboy2010
PostPosted: 17:42 - 02 Nov 2019    Post subject: Reply with quote
WD Forte wrote:
"Rebuilt"
Sorry I should say that it had a new piston put in
jaffa90
PostPosted: 18:19 - 02 Nov 2019    Post subject: Reply with quote
""""Sorry I should say that it had a new piston put in""""
Did you check the cyl wall for scouring and the piston rings/oil ring for the correct gap clearance?
bazzaboy2010
PostPosted: 18:46 - 02 Nov 2019    Post subject: Reply with quote
Yes all that was ok
RhynoCZ
PostPosted: 19:12 - 02 Nov 2019    Post subject: Reply with quote
Freshly rebuilt 4 stroke engines do tend to burn some oil before they break in.
steve the grease
PostPosted: 20:12 - 02 Nov 2019    Post subject: Reply with quote
In the world I grew up in, you were supposed to rough up the bore , hone it ideally, and the thrash the engine in to wear the piston rings in. if you don't the rings can become burnished ( which is like polished) and will never seal properly in the bore. New engines are run in because both the bore and piston are in a just machined state so the rings run in. An old bore is polished, hence roughing up. yeah until bedded in they can use loads of oil.
bazzaboy2010
PostPosted: 20:20 - 02 Nov 2019    Post subject: Reply with quote
I have used the bike for around 500 miles now, and I have used around 400ml of oil
Nobby the Bastard
Harley Gaydar
PostPosted: 21:16 - 02 Nov 2019    Post subject: Reply with quote
Thats normal for an exup....
Triumph Sprint ST 1050
RhynoCZ
PostPosted: 22:06 - 02 Nov 2019    Post subject: Reply with quote
What Nobby the Bastard says, keep an eye on the oil consumption and get back to us after you do some more miles.
Also, if you read your service manual, they do tend to tell you what is considered as an ''excessive'' oil consumption and how to break in an fresh engine.
The last post was made 6 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.45 - MySQL Queries: 13 - Page Size: 67.91 Kb
