Opinions on "fixing" pitted chrome
Easy-X
PostPosted: 16:57 - 04 Nov 2019    Post subject: Opinions on "fixing" pitted chrome Reply with quote
This is one of those topics I'm starting to hit information overload...
There's the old coke/vinegar + tin foil trick, a succession of finer abrasives + polishing, rust converters (which I would think were more useful for rusty steel than chrome plate) and some "magic stuff" like Quick Glo (a combination of abrasive, polish and wax - all in one - what could possibly go wrong?!)
Any other techniques I may have missed?
After that, what are people's opinions on maintenance: keep polishing or a coat of lacquer? The latter seems like a low maintenance option but when lacquer starts to go it looks bleedin' awful.
WD Forte
PostPosted: 17:09 - 04 Nov 2019    Post subject: Reply with quote
Money
Just spend lots of dosh and it will look fab
bikers smell of wee
PostPosted: 17:13 - 04 Nov 2019    Post subject: Reply with quote
You are delaying the inevitable.
You could bodge with araldite and sanding it down smooth. Rolling Eyes
The stanchion needs rechroming and it's time con$uming work.
Start a fork fund now. Thumbs Up
Sister Sledge
PostPosted: 17:17 - 04 Nov 2019    Post subject: Reply with quote
Get it re-chromed...
Nah - honestly are you going for a mint look or everyday canny looking bike?
Long ago in the olden days (turning into Tef..) I would just keep on top of the rust spots with tin foil. It just means more in depth cleaning so to speak but it's easily done.
Another is get the rust out and bleb some oil onto those exposed steel parts (in moderation!) though what will happen is dust will stick to all of that and make it look worse.
How about plastidip on the rims? Paint? 'Galvy spray'?
CCM 404 DS
PostPosted: 17:27 - 04 Nov 2019    Post subject: Reply with quote
Is this cosmetic stuff or fork stantions?
If the pitting is through the chrome plating you are always going to get rust coming through the pit. That means you have to keep on top of it but the real problem is if the rust gets under the chrome plating, then it's only a matter of time before it comes off in flakes. Then it's time to get it re-chromed.
I haven't had a bike with much chrome on it for donkeys years. Back then it was Solvol Autosol and elbow grease.
I have no idea what fancy concoctions are available nowadays though.
Triumph Trophy Launch Edition
pepperami
PostPosted: 17:35 - 04 Nov 2019    Post subject: Reply with quote
Pitted chrome is pitted chrome, stop putting off the inevitable and get the parts re-chromed.
Kawasaki Jimbo
PostPosted: 20:46 - 04 Nov 2019    Post subject: Reply with quote
Yep, mine were rubbed down twice over a few years and didn't look too bad but eventually the tiny pits were enough to let oil past. I had the stanchions rechromed (£175/pair) but still got through several fork seals and a bush set before the MOT guy declared that the chrome must be a fraction too thick. He dealt with it by fitting K-Teck fork seals which are apparently "a bit softer" than stock. He also had a local machine-shop sort out some damage on one stanchion where the lower bush sits. Total cure! Maybe I was unlucky but next time I'd try some aftermarket stanchions from Wemoto at around £130 each.
Easy-X
PostPosted: 01:21 - 05 Nov 2019    Post subject: Reply with quote
Just the rims on the old DT, the forks are fine. The annoying thing is the front rim now looks brand new but the rear is just starting to go: odd patches of pitting here and there but so far no flaking.
Sister Sledge
PostPosted: 08:40 - 05 Nov 2019    Post subject: Reply with quote
Paint/damage the better one to match the sh*t one?
CCM 404 DS
Easy-X
PostPosted: 11:15 - 05 Nov 2019    Post subject: Reply with quote
Lol... that's definitely not an option I'd considered Smile I've got some 400/800/1200 grit papers, gonna try that first.
If I get the chrome looking reasonable does lacquer help keeping things from getting worse or just stick to regular polishing?
A100man
PostPosted: 13:14 - 05 Nov 2019    Post subject: Reply with quote
Waste of time IMO - might as well just spray on ACF or equivalent during winter and polish/wax in summer.
OR
Earn your spurs and rebuild the wheel with stainless spokes and a new rim.
Easy-X
PostPosted: 14:39 - 05 Nov 2019    Post subject: Reply with quote
Aha! Good shout Smile Almost forgotten I have plenty of ACF50 kicking about Thumbs Up
Easy-X
PostPosted: 21:05 - 05 Nov 2019    Post subject: Reply with quote
Okay so with just polishing I had this:
https://i.imgur.com/CR50m3W.jpg?1
And then I went over with a succession of fine abrasives + a final polish with ultra fine Scotch Brite:
https://i.imgur.com/T8UROZT.jpg?1
I *think* that's the same area but TBH it turned out better than expected Smile
PostPosted: 01:29 - 06 Nov 2019    Post subject: Reply with quote
That's an improvement. Thumbs Up
Now you have become a slave to maintaining that standard. Smile
Easy-X
PostPosted: 11:23 - 06 Nov 2019    Post subject: Reply with quote
Thankfully there's not too much chrome on the DT: headlamp glass surround, indicators, rims, clocks... all easy to get to for cleaning when it's rebuilt.
If one were doing such things on a regular basis it might be better to get a mega selection of Dremel polishing bits Smile
The last post was made 6 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.48 - MySQL Queries: 13 - Page Size: 88.65 Kb
