| stinkwheel |
 Posted: 17:35 - 05 Nov 2019 Post subject: AC/DC Headlamp switch needed |
Not sure if this will be possible.
I'm looking for a neat, ideally one-piece headlamp switch for a bike with an AC/DC lighting system.
The side and tail lights are DC from the battery. The main headlight is direct single-phase AC from the alternator with an AC regulator.
So, there is an AC and DC input.
In the "side" position, the DC is connected to the side and tail lights.
In the "ON" position, the DC is connected to the tail light only. The AC is connected to an AC regulator and to the dip switch.
The Dip switch then toggles the AC output to either Headlamp or full beam.
The output to the AC regulator has to come off after the "on" switch but before the "dip" switch, if it was beyond the dip switch, both filaments would come on at the same time but it can't be powered up unless the headlamps are on.
Just to make it more difficult, I'd rather it didn't have an indicator switch but this isn't a deal breaker. Again, I'd rather the sidelights went off when the headlight goes on but again, not a deal breaker.
Wow, complicated huh?
Visual representation below.
https://www.bikechatforums.com/download.php?id=102891
https://www.bikechatforums.com/download.php?id=102890 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Meatybeaty |
 Meatybeaty World Chat Champion
 Posted: 18:22 - 05 Nov 2019 Post subject: |
| stinkwheel |
 Posted: 18:27 - 05 Nov 2019 Post subject: |
I don't think so. That switch has 5 wires. I have 2 in and 5 out.
I should say it's for going on a enfield trials bike.
I'm trying to avoid using lucas replica switches because they are utter shite. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Easy-X Super Spammer
 Posted: 21:32 - 05 Nov 2019 Post subject: |
Does it need to look good? If yes then your choices are minimal. If "standard" Chinese copies aren't a problem then there's plenty of this sort of thing:
https://i.ebayimg.com/images/g/ogwAAOSw3w9c4mSt/s-l500.jpg
Order a few different ones and either they work or maybe possible to dismantle and rejig the wiring. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Robby |
 Robby Dirty Old Man
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 23:26 - 05 Nov 2019 Post subject: |
| Easy-X |
 Posted: 23:46 - 05 Nov 2019 Post subject: |
Lol... what do they say "if you have to ask you can't afford it!" ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| stinkwheel |
| Nobby the Bastard |
| steve the grease |
 steve the grease Crazy Courier
| stinkwheel |
| Nobby the Bastard |
| WD Forte |
 WD Forte World Chat Champion
| stinkwheel |
| Easy-X |
 Posted: 17:02 - 06 Nov 2019 Post subject: |
The minimum I'd expect on a "modern" bike might be:
Ignition off: no lights
Ignition on, engine off: sidelights + tail light from DC/battery (but with no separate switch, "always on")
Ignition on, engine on: switchable headlight + hi/lo beam, brake light - both from AC
For simplicity I'd consider running all the lighting bar the headlight from the DC - the brake light only being active occasionally.
IMO trying to shut off the sidelights when the headlight is active is a) a lot of bother and b) counterproductive: what happens if you stall? Headlight goes out and you have no sidelights until you switch the headlight off!
For minimalism you could have a multi position ignition switch (off, on, on+lights) and just a hi/lo toggle on the handlebars. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| stinkwheel |
 Posted: 18:28 - 06 Nov 2019 Post subject: |
I'm an idiot!
The solution is relays. Two of them. The side light/tail light can be wired in standard fashion. The usual DC headlight outputs can be used to trigger a SPNO relay which is switching the AC. That feeds the AC regulator and a second, changeover relay. The changeover normally feeds the headlight and feeds high beam when switched by the high beam supply (can even use an LED high beam tell-tale then).
Also reduces the load on the switch because the main bulk of the lighting current is going through a relay. Less and thicker wiring between the alternator and the lights and no weedy little contacts. It will probably also get rid of the momentary period of darkenss when going from Hi to lo beam.
So I can use pretty much any standard switch, just need to find one that looks good! Ideally one with all the lights and the horn control on one cluster but no flashers.
Might go C90 again because the choke lever is perfectly capable of working the decompressor. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Nobby the Bastard |
| stinkwheel |
| Nobby the Bastard |
| stinkwheel |
| Nobby the Bastard |
| Nobby the Bastard |
| stinkwheel |
| stinkwheel |
 Posted: 00:10 - 07 Nov 2019 Post subject: |
Wrong relays. 2x DPST would do it.
https://www.bikechatforums.com/download.php?id=102896
A C90 light switch has separate outputs for the tail/instrument lights and the side lights as well as the main and dip.
I also attached an original wiring diagram for the bike. I didn't before because it doesn't show you the switch outputs anyway. I checked them with a meter and the connection to the AC regulator from the switch is via the dip switch. It's always connected to either the main or dip output (but never both together).
The OEM switch works but it's shite quality and has indicators too.
Yes, seperate switches would be easier but one of the things I'm trying to do is make room for a decent valve lifter lever as well as the light switches, choke lever, throttle assembly, clutch lever and brake lever. I'm running out of space and ditching a switch cluster would make that space. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 6 years, 229 days ago. Instead of replying here, would creating a new thread be more useful? |
