Left / Right indicator different speeds... why?
theMusicMan
PostPosted: 18:22 - 10 Nov 2019    Post subject: Left / Right indicator different speeds... why? Reply with quote
Hey All
At 56 years young, I am totally new to bikes, and new to this forum. For my sins I bought a 2016 Lexmoto Aspire which will allow me to see if I can get through the winter using a motorcycle as I have gout in my hips - it gets worse in the cold so didn't want to spend a lot of money on a bike if I can't use it through the year. If my hip is good (getting on and off is the issue) I'll consider getting a better bike in the spring.
Meanwhile... is there a reason the right hand indicator flashes at half the speed of the left hand indicator?
I don't have a wiring diagram, but am happy to dive in and explore/learn.
Thanks all.
The Artist
PostPosted: 18:25 - 10 Nov 2019    Post subject: Reply with quote
Probably old school flasher relay so the cause is most likely either one bulb is dead or the bulbs are different wattages.
The flasher rate is usually a function of the power draw through the relay. Flasher bulbs are usually 21W but if someone has used a 5w or if you have a bulb out then the rate will change either faster or (usually) slower.
theMusicMan
PostPosted: 18:32 - 10 Nov 2019    Post subject: Reply with quote
Many thanks both - and for your quick replies, much appreciated. Thumbs Up
Aha yes, I see, makes perfect sense thank you.
I didn't spot any of the indicator bulbs not working, so will check the power ratings on each of them.
Tankie
PostPosted: 04:32 - 11 Nov 2019    Post subject: Reply with quote
suspect dirty earth
The last post was made 6 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 42.51 Kb
