Insufficient laptop space to update Garmin
Freddyfruitba...
PostPosted: 12:48 - 13 Nov 2019    Post subject: Insufficient laptop space to update Garmin Reply with quote
Just tried to update my Garmin satnav as usual using Garmin Express, and it's announced that it needs at least 14 Gb (!) of temporary hard disk space to do this. My laptop has an SSD of only 150-odd Gb, with about 8 Gb free; that's nearly all program/system files so there's no way to achieve the necessary space without uninstalling software (which I'd then need to do again every time I needed to repeat this).
Is there any clever way round this? I have a 32 Gb USB drive and a huge networked P: drive, but Garmin doesn't seem to care about that...
Copycat73
PostPosted: 13:16 - 13 Nov 2019    Post subject: Reply with quote
go here C:\ProgramData\Garmin\Maps and delete the old maps ..
defrag.. and use tools to delete unwanted clutter..
caveat emptor
PostPosted: 14:27 - 13 Nov 2019    Post subject: Reply with quote
Copycat73 wrote:
defrag
Don't do that.
PostPosted: 15:13 - 13 Nov 2019    Post subject: Reply with quote
Aye, don't defrag an SSD. Are you running Windows 10? You might get some space back if you reduce the page file and lose the hibernate :-
https://www.pugetsystems.com/labs/support-software/SSD-optimization-in-Windows-10-964/
And cleaning WinSXS :-
https://www.tenforums.com/tutorials/82643-clean-up-component-store-winsxs-folder-windows-10-a.html
xX-Alex-Xx
PostPosted: 16:31 - 13 Nov 2019    Post subject: Reply with quote
Disk Cleanup will likely help. It's built into Windows, and will SAFELY remove old files.
Treesize will give you a good overview of what folders are taking up the most space - https://jam-software.com/treesize_free/
As mentioned, DO NOT defrag an SSD. Thumbs Up
DILLIGAF
Copycat73
PostPosted: 18:30 - 13 Nov 2019    Post subject: Reply with quote
Paddy. wrote:
Copycat73 wrote:
defrag
Don't do that.
and why not ?
incidentally installing on an external drive will cause more problems than it will fix..
caveat emptor
Im-a-Ridah
PostPosted: 19:48 - 13 Nov 2019    Post subject: Reply with quote
Well you could try creating a symbolic link on your OS drive that points to a folder on your USB or network drive. That way Garmin thinks its on your OS drive... but it isn't Wink
https://www.howtogeek.com/howto/16226/complete-guide-to-symbolic-links-symlinks-on-windows-or-linux/
weasley
PostPosted: 19:57 - 13 Nov 2019    Post subject: Reply with quote
Copycat73 wrote:
and why not ?
Because it is both unnecessary and potentially harmful. In fact a defrag utility may not even run on an SSD, or will warn you not to.
xX-Alex-Xx
PostPosted: 22:16 - 13 Nov 2019    Post subject: Reply with quote
and why not ?
On a spinning disk, data can be read faster if all the data is in a solid block, rather than if the data is spread over the disk causing the read heads to search for each tiny piece of the data block. As the disk is spinning, not only do you lose speed for each time the head has to move, you also have to wait for the disk to spin into the right place for the head to read the data.
SSDs can read info from anywhere on the disk at the same speed, so it doesn't matter if the data is in a solid contiguous piece or not. Add to this that SSDs have a limited number of writes, and defrags will really hit the reliability of the drive.
DILLIGAF
PostPosted: 09:14 - 14 Nov 2019    Post subject: Reply with quote
Copycat73 wrote:
and why not ?
See thread, it's flash/NAND. If I was to defrag my M2 it would likely complain, but it's not something you do on an SSD...
Copycat73
PostPosted: 11:21 - 14 Nov 2019    Post subject: Reply with quote
Paddy. wrote:
Copycat73 wrote:
and why not ?
See thread where exactly did i say defrag the SSD ;/ ..
caveat emptor
PostPosted: 11:25 - 14 Nov 2019    Post subject: Reply with quote
Here is where you say it.
You talk about C:\ first off, surely then you need to qualify you next statement by saying "Don't defrag C:\" Quite a large proportion of peoples C:\ drives are SSD's these days.
Defragging doesn't gain you a lot of space. Disk cleanup does, but not a lot.
Freddyfruitba...
PostPosted: 13:09 - 14 Nov 2019    Post subject: Reply with quote
Thanks all.
I'm reasonably savvy about keeping crap-free, but I managed to increase my free space from 8Gb to 11Gb (most of that was killing System Restore) so am still falling short. Crying or Very sad
@Shaggy - I'm still running Windows 7 actually - I deliberately bought the laptop with a win7 'downgrade' as I loathe Win10 (and IIRC it doesn't support some of my software). However since Microsoft are about to end Win 7 support it's really time for me to bite the bullet; so I think it's probably time I bought a bigger SSD and worked out how to install it with Win10. OMG. That will be a whole other problem... Rolling Eyes
doggone
PostPosted: 13:47 - 14 Nov 2019    Post subject: Reply with quote
I would of thought it might install onto a USB3 flash drive, presumably it's all the stored maps are so large.
Do you have to install all of them in one go?
PostPosted: 18:48 - 14 Nov 2019    Post subject: Reply with quote
Still might be some mileage in cleaning WinSXS.
https://helpdeskgeek.com/how-to/cleanup-the-winsxs-folder-in-windows/
The last post was made 6 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 97.9 Kb
