Cylinder Fin Damping
Easy-X
PostPosted: 19:14 - 14 Nov 2019    Post subject: Cylinder Fin Damping Reply with quote
So before I got the DT engine parts vapour blasted I took out all the rubber dampers that were wedged between the fins. I could reuse them but the rubber's in a pretty poor state.
I was thinking of cutting up bending silicone: it's the stuff you'd stuff in plastic pipes before heating and bending to prevent kinks - a bit like the old trick of filling metal pipes with sand.
Silicone has a fairly high melting point (>200ºC) will it be okay or is there some "magic" rubber than you're meant to use on air cooled engines?
WD Forte
PostPosted: 20:03 - 14 Nov 2019    Post subject: Reply with quote
Pro tip:
use Toblerone
trust me it works and you can eat what you don't use
bikers smell of wee
Easy-X
PostPosted: 20:09 - 14 Nov 2019    Post subject: Reply with quote
WD Forte wrote:
Pro tip:
use Toblerone
I think liquorice rope would last longer Laughing
WD Forte
PostPosted: 20:43 - 14 Nov 2019    Post subject: Reply with quote
People often use silicone to seal between downpipes and silencers so it should be up to the job temp wise.
bikers smell of wee
redeem ouzzer
PostPosted: 22:56 - 14 Nov 2019    Post subject: Reply with quote
Dampers are still available new. You’ll want to fit them as well, they do take the edge off the engine noise.
Be a REAL MAN!
Easy-X
PostPosted: 23:18 - 14 Nov 2019    Post subject: Reply with quote
The Toblerone sort maybe but I haven't found anyone still doing the old rubber rope style.
stevo as b4
I'm not sure unless a road used bike needs to be more refined. But to me an air cooled two stroke is all about engine noise, that's why they sound so good! My TY 175 having a very similar engine, had no rubber dampers fitted in the finning, and it sounded really good!
PostPosted: 01:03 - 15 Nov 2019    Post subject: Reply with quote
I've seen silicone hose used for this purpose. It's effective.
I personally like to hear an air-cooled 2-t ringing its arse off but some may consider this antisocial.
JackButler
PostPosted: 04:05 - 15 Nov 2019    Post subject: Reply with quote
If I can remember from my 2t days it's called harmonic vibration & depends much on how the fin is shaped.
Sister Sledge
PostPosted: 09:32 - 15 Nov 2019    Post subject: Reply with quote
Do without = bike goes faster.
(it won't break the engine not having any fitted)
CCM 404 DS
redeem ouzzer
PostPosted: 09:35 - 15 Nov 2019    Post subject: Reply with quote
Stop being autistic and google the part number.
Be a REAL MAN!
Easy-X
PostPosted: 13:05 - 15 Nov 2019    Post subject: Reply with quote
Of course! Why didn't I think of that before Rolling Eyes
The last post was made 6 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 75.47 Kb
