94' Royal Enfield Bullet 500 Fuel leak From carb
piratebiker
PostPosted: 09:42 - 19 Nov 2019    Post subject: 94' Royal Enfield Bullet 500 Fuel leak From carb Reply with quote
Got a fuel leak from base of carb, see image. How can I fix this? Thanks.
PostPosted: 10:21 - 19 Nov 2019    Post subject: Reply with quote
That's an overflow. Either your needle valve is damaged/dirty/blocked or the float is punctured.
Hitchcocks do a service kit for those carbs. They are a mikcarb, a licenced copy of a mikuni. The kit has all new brass parts and seals up to mikuni spec. They improve the running of even a new mikcarb (especially at idle) and yours is 25 years old. The kit includes a new needle valve and seat.
I'd suggests stripping and cleaning the carb and fitting a service kit.
Also check the float. If it has fluid in it (shake it next to your ear) or sinks/floats unevenly on water, it's burst and needs replacing.
If you have a performance exhaust/air filter, you may have different jetting on your carb so check what's in there as you strip it, they should have numbers stamped on them.
I would be the last person to suggest using kitchen equipment for motorcycle parts Shifty however, if you strip the carb, the body and float bowl will come up lovely after a run through the dishwasher.
If you're short on funds, try cleaning the needle and seat and check the float but I'd budget for replacing the needle valve and seat. The needle has a rubber ring on it which may not have been ethanol proof in 1994, a new one will have a viton sealing ring.
https://accessories.hitchcocksmotorcycles.com/1837?qty=1&continue_url=https%3A%2F%2Fwww.hitchcocksmotorcycles.com%2Fpartsbook-pages%2F1621
piratebiker
PostPosted: 10:32 - 19 Nov 2019    Post subject: Reply with quote
That's great, thanks.
piratebiker
PostPosted: 12:02 - 10 Dec 2019    Post subject: Overflow valve Reply with quote
Hi, how is the overflow valve removed, there's a Black plastic cap but can't get that off? Is there an O-ring that can be replaced as not confident dismantling the carb. Thanks.
PostPosted: 12:22 - 10 Dec 2019    Post subject: Reply with quote
Does this help?
https://www.team-bhp.com/forum/attachments/motorbikes/43254d1220002094-help-carburetor-bullet-500-rd-350-rd350carb.jpg
PostPosted: 13:51 - 10 Dec 2019    Post subject: Reply with quote
You wouldn't normally remove the overflow. It'll be attached to a pipe on the inside of the carb and is almost certainly a very tight push-fit. The plastic bit may well be glued on.
The overflow isn't a valve, it's just a pipe in the bottom of the carb. If the fuel level gets too high, it reaches the top of the pipe and fuel runs out of it. Exactly like the overflow on a toilet cistern Nothing there to go-wrong and there should be no need to remove it.
You need to fix the reason stuff is coming out of it which will be something in and around the vicinity of the float or needle valve as previously discussed.
WD Forte
PostPosted: 15:43 - 10 Dec 2019    Post subject: Reply with quote
Not sure if relevant, but it reminds me when I found some old CX Carbs
where the overflow pipes made from very thin brass
had rotted and split over time.
I got some brass tube from a moclel shop and
after some Dremel jiggery pokery JB-Welded new ones in.
bikers smell of wee
The last post was made 6 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 52.58 Kb
