VFR800 FI light continuously flashing
myvision
PostPosted: 17:40 - 23 Nov 2019    Post subject: VFR800 FI light continuously flashing Reply with quote
All,
After some help as I can't find the code for a continuous flash of the FI light on a 98 VFR800 has anyone had this?
It starts fine and will rev fine but there's obviously something wrong.
I can't now take it out as I've had a can.
I jump the service indicator and again it just flashes which the book only goes to 24 flashes codes.
Any ideas?
VFR800FI, YZF600R Thundercat and FZS 1000
ThatDippyTwat
PostPosted: 17:58 - 23 Nov 2019    Post subject: Reply with quote
First off - check the (blue?) connector behind the left hand front fairing under the bars. Might be slathered in tape. They're a bit tempremental at this age. Give it a clean it out, there's likely corrosion. Then, check your earths, one of them may have fuzz, or has worked loose. Yell if you need a .pdf of the manual. See if they sort things.
ThatDippyTwat
PostPosted: 17:08 - 24 Nov 2019    Post subject: Reply with quote
Not sure if you've sorted it - a mate suggests it's a sensor near the fuel tank, quite common apparantly.
myvision
PostPosted: 20:44 - 24 Nov 2019    Post subject: Reply with quote
Sorted vacuum pipe had come off the map sensor put it back on and good as new.
The last post was made 6 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.5 - MySQL Queries: 13 - Page Size: 39.61 Kb
