| Eki |
 Eki Derestricted Danger
 Posted: 16:41 - 23 Nov 2019 Post subject: ER-6F Electrical Issue |
Hi everyone. I'm hopeful someone here can help me before I give in and take my bike to a garage and get charged an arm, leg and probably a kidney.
I recently replaced my headstock bearings/races on my ER6 (2006), it took a while because every time I ordered a tool I found out I needed another tool, then a tool that actually worked, but I got there in the end.
I've put my bike back together and now only the indicators/hazards work, no other electrical activity. The idiot lights come on and blink, the indicators come on and blink, but that is it, no other lights. Not even the clock on the dash works, nor the horn or plate lamp. (front+rear indicators work)
I've checked all the fuses, all are good.
I'm not really sure where to go from here, it seems obvious that I did something when I was changing the headstock bearings but I have no idea what nor no idea how to even start to find out where the break in the thing has occurred resulting in a complete lack of power, except in the indicators.
Any help would be appreciated, thank you. |
| Polarbear |
 Polarbear Super Spammer
| Eki |
| jaffa90 |
 jaffa90 World Chat Champion
| Eki |
 Posted: 22:35 - 23 Nov 2019 Post subject: |
The bike does not have security built in, as far as I know, this is the 2006 model too which I think doesn't have the thing built into the key, where you need to replace the CDI or something if you swap the key.
I did not disconnect the battery, I have however replaced the battery, it was the first thing I thought of.
As for posting the wiring, it's from the Haynes manual so there would be copyright issues so sadly I'm unable to post that, sorry.
Looking at the diagram, the grey wire goes from the signals into the signal/hazard, then around to the fuse box and then up to the ignition switch. It appears to be the only wire that uses the fuse #4. Fuse 1/2/5/6/7/8 all hook into the brown wire to ignition switch, fuse 3 is a white wire to the ignition and hooks into Parking.
I'm sorry if that isn't clear, but it's the best description I can manage. |
| Ste |
 Ste Not Work Safe
 Posted: 22:43 - 23 Nov 2019 Post subject: |
There won't be any copyright issues from posting the wiring diagram.  |
| Eki |
| jaffa90 |
| Eki |
 Posted: 15:14 - 24 Nov 2019 Post subject: |
I dont no, I guess it'll have to be taken to a garage. Thanks for all the feedback guys  |
| MCN |
 MCN Super Spammer
 Posted: 16:51 - 24 Nov 2019 Post subject: |
I was all packed up, primus stove, pots, pans, 1 shot Moka pot, spare stove, torches, schlepping bag, renters, folding chair, folding water bottle, and wind-breaker (mitt poles).
I pushed the hoowur off the centre stand and leaned it on the side stand.
I noticed the lights went out.
I found the key was at the on position so turned it to ignition position and nothing...
Fuck... I was catching a bastirt ferry at 06:00 next day.
Checked battery connection good.
Started troubleshoot the harness.
After about 1/2 of panic mode I found that a multiplug had fell out the receptacle under the steering brace thing.
Pushed it back in and bingo. Normality restored.
I pulled the bastirt out again, put a blob of EvoStick on the side and plugged it back in.
It's been fine since then.
You need to check cm by cm cause you have fuctup somewhere in the assembly.
I'm sure you'll find it. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| sickpup |
 sickpup Old Timer
| jaffa90 |
 Posted: 00:49 - 26 Nov 2019 Post subject: |
I'd suspect ignition switch. It makes two seperate connections in the on position. The old ER5s were notorious for them partially failing. So you could have engine and no lights, lights but no engine, starter but no ignition etc. etc.
Here's one for you to try. Does the "pass" button make the headlamp flash? It's on the "other" circuit to the actual headlamp along with the flashers and brake light. If this is the case, it's almost certainly either the switch itself or the wiring going to it. This would make sense because you either have had to disconnect it or leave the top yoke hanging off the wire to change those bearings.
You can sometimes get the switch back by squirting a load of WD40 in the switch and wiggling it about but they tend to fail again soon after.
Got a multimeter? With the ignition switch ON you should have continuity between the white and brown wires AND between the red and white on red wires at the ignition switch connector block. None between any other pair. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
| Eki |
 Posted: 17:04 - 05 Dec 2019 Post subject: |
Quick update, my new ignition switch arrived today (technically a switch for a Ninja 250 because £20 instead of £200), put it in and it all works perfectly.
Conclusion (for anyone else that has this issue). It's either the ignition switch failing or the ignition switch not properly plugged into the harness (under the fuel tank).
Thanks for everyones help  |
The last post was made 6 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
