ZZR 1100 no brake light.
Scotsrick
PostPosted: 07:32 - 01 Dec 2019    Post subject: ZZR 1100 no brake light. Reply with quote
I’m trying to move on my old ZZR that’s sat for at least a year,before my new Sprint GT arrives.
Everything seems okay except I can’t get a brake light either from the front or rear brakes. Twin bulbs but nothing from either.
Mechanicals I’m fine with, electrics are voodoo stuff.
Can you suggest some simple checks before I have to get someone in to fix it for me?
I do have a multimeter.
UncleFester
PostPosted: 08:58 - 01 Dec 2019    Post subject: Reply with quote
Would seem odd that both switches don't work - ergo i'd pull the lamps and check the contacts for crud - it can be removed with emery paper. Also check the filaments of the lamps.
2017 Z1000SX
PostPosted: 09:45 - 01 Dec 2019    Post subject: Reply with quote
Absolutely nothing stopping it blowing both bulbs. Happens a lot in my experience so simple things first.
Then check the switches are working with your meter. Set to resistance and measure between the terminals, should be high resistance with the switch off and low resistance with the switch on.
Then check there's power to the switches, should be 12v at one terminal on each switch when the ignition is on. Black lead to earth (battery negative or any bit of bare metal) red to the terminal.
Then check there is 12v at one of the bulb holder terminals with the ignition on and the brake held on.
1198
PostPosted: 10:26 - 01 Dec 2019    Post subject: Reply with quote
There’s a connection under the seat where the wires from the bike loom connect into the small loom that splits to connects to each lamp holder. Have you checked that you’re getting 12v there when you squeeze a brake? The lamp holders themselves are not that good too, my bulbs are now both hardwired in.
I’m assuming g you’ve checked the fuse of course...
The last post was made 6 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 39.93 Kb
