| seeyalater |
 seeyalater Trackday Trickster
| jaffa90 |
 jaffa90 World Chat Champion
| seeyalater |
| stinkwheel |
| seeyalater |
| MCN |
 MCN Super Spammer
| seeyalater |
 - Super Spammer
| stinkwheel |
| Bhud |
 Bhud World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| seeyalater |
| seeyalater |
| seeyalater |
 Posted: 17:08 - 06 Dec 2019 Post subject: |
this looks too thick or is it just the pic.. could be right though |
| Riejufixing |
 Riejufixing World Chat Champion
 Posted: 18:51 - 06 Dec 2019 Post subject: |
| MCN wrote: | High temp silicunt adhesive is good too.
3m make it for sealing ovens and furnaces etc. May seem pricey.
Amazon e-ghey etc.
VITCAS
4.5 out of 5 stars 386Reviews
Black Fire Cement 1250 C - 310ml for Fireplace, Stove, Boilers etc |
Unfortunately it's not silicone rubber, although it has a high silicon content. As far as I know, silicone rubber that's highly resistant to heat tops out at 300C. The stuff I've used has the disadvantage of being available only in bright red.
Edit: "Ordinary" silicone sealer might do the job. Test temperature of pipe with a loop of lead-free solder around it as you go along. That melts at about 230C.
Edit: well, maybe there is ultra-high-temperature silicone sealer, like: https://www.fluesystems.com/shop/high-temperature-black-silicone-enviromgraf.html - however, I have never seen this, and it comes with usage warnings.
Edit again: the above "1250C silicone" says:
Envirograf® Silicone Sealant has been tested in fire furnaces for up to 4 hours and 1200°C, where joints in walls are sealed and any vapours burn off in the furnace to leave the fireproof seal.When sealing in situations, which normally have adjacent flames, it is absolutely essential that you allow 3 days WITHOUT FLAMES, for every 1-2 mm of Silicone Sealant installed, in order to set the silicone into its fireproof state. For example, 5-6 mm of Silicone Sealant installed would require 4-5 days for the silicone to set. DO NOT allow flames in the vicinity of setting silicone. If anyone has used this stuff and knows how it works, I'll be really interested to hear!
Use gun gum? Shim cut from aluminium beer tins? Old lithoprint plates? |
| seeyalater |
 Posted: 19:20 - 06 Dec 2019 Post subject: |
| Riejufixing wrote: | | MCN wrote: | High temp silicunt adhesive is good too.
Amazon e-ghey etc.
VITCAS
apart from the last line what was your point dude, struggling to see wha you were saying aprt from fire cement may take days to set?
gun gum is crap stuff but a can or high temp silicone does look a good idea from what ive seen in the last hour or so. il see how the stuff sets ive used, feel it will be too brittle for where it is, wont be firing the bike up until sunday and i only used about 2mm depth. fingers crossed. |
| Riejufixing |
| seeyalater |
| Sister Sledge |
 Sister Sledge World Chat Champion
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
 Posted: 09:59 - 07 Dec 2019 Post subject: |
Fire cement is brittle when dry, and will vibrate out in a few days/weeks, I've tried it many times. I work in a Foundry, I have unlimited access to the stuff, free is the best price if you can make it work. Really, it's useless for pretty much any bike application in the long-term, due to the vibration, and getting it wet is a recipe for it falling out almost instantly.
If the gap is big enough, get a graphite exhaust gasket. You'll need to measure uncompressed ID of the can and OD of the pipe and use that to search. You can also use a Silicone. the aforementioned 5990 is good, or an oven door silicone sealer works and will be cheaper, using with pop/beer cans to fill the gap, as that will blow out over time without something in there. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| Tdibs |
 Tdibs Traffic Copper
| seeyalater |
 Posted: 10:48 - 07 Dec 2019 Post subject: |
Not sure if it was blowing from bottom but will bet it was, wasnt really from the can as the pipe goes well into it. was a little breeze if you like but no black marks.
I know in my head how the stuff was it wll be brittle and any movement will shake it loose. going to order the better clamp and silicone and find a can, Guess il have to buy beer, dam it.  |
| ThatDippyTwat |
| seeyalater |
| ThatDippyTwat |
The last post was made 6 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
