Kawasaki ER-6N Gear Indicator Installation
sapstar
PostPosted: 14:51 - 10 Dec 2019    Post subject: Kawasaki ER-6N Gear Indicator Installation Reply with quote
Just started using my first bike Kawasaki ER-6N (2015). I would like to install a Gear Indicator. Can someone suggest what I need to buy? I see multiple different versions in a wide price range.
This is something I found on amazon.
https://www.amazon.co.uk/IDEA-Motorbike-Indicator-Waterproof-Motorcycle/dp/B078HY1W4T/ref=sr_1_3?keywords=er6n+gear+indicator&qid=1575985728&sr=8-3
Is this easy to install?
First/Current Bike - Kawasaki ER-6N
PostPosted: 15:14 - 10 Dec 2019    Post subject: Reply with quote
If it is plug and play it should be. It depends where it plugs.
I fitted the Rolls Royce of aftermarket gear indicators to wifies ER6N, The Healtech GI-Pro. It was brilliant, no issues.
https://www.moorespeedracing.co.uk/healtech-gear-indicators/healtech-gi-pro-x-type-g2-gear-indicator.html
It plugs into the diagnostic socket and thats it, but it costs north of £100. When I fitted it the only other choices were the magnetic input one which you had to programme and were crap.
The one you indicate, if truly plug and play will be fine but I have no personal experience of it.
One thing with Amazon though, if it doesn't work as said they are pretty good with refunds. Thumbs Up
ThunderGuts
PostPosted: 15:33 - 10 Dec 2019    Post subject: Reply with quote
Do you really need one? If it's your first bike is this because you had the comfort of one on the bike you did your mod 2 on?
You may have good reason, but I'd be tempted to see how you go for a bit before adding accessories like that - you should get the feel of the gear you're in from how the engine sounds and behaves, plus you get used to the sounds at different speeds so you'll know what gear you're in.
TG.
sapstar
PostPosted: 15:46 - 10 Dec 2019    Post subject: Reply with quote
True. My mod 2 bike had the gear indicator. I am struggling to know which gear I am in and in heavy traffic where I keep changing gears often, it would be nice to have.
Just want to do it, if it is cheap and easy to fit it myself. If it is too expensive, I won't be bothered about it.
sapstar
PostPosted: 15:50 - 10 Dec 2019    Post subject: Reply with quote
Yes I have seen this, but don't want to spend that much on mods now... May be I will give the one in Amazon a go.
Easy-X
PostPosted: 16:55 - 10 Dec 2019    Post subject: Reply with quote
I didn't get one on my Rebel and got used to it. Eventually your brain will tune into the speed you're going and the engine sound so you can pretty much know the gear you're in Smile
About the only thing I sometimes miss is changing up to 6th cruising >60mph as the wind noise starts to obscure the engine sound.
redeem ouzzer
PostPosted: 22:51 - 10 Dec 2019    Post subject: Reply with quote
Extra weight and pointless.
Be a REAL MAN!
kawakid
PostPosted: 00:46 - 11 Dec 2019    Post subject: Reply with quote
Why on earth do you need an LED showing your gear.
Your boot changes up and down and you should know.
Pointless, waste of money.
I've a twin and a 4.
ThatDippyTwat
PostPosted: 07:52 - 11 Dec 2019    Post subject: Reply with quote
You don't need one. You'll get used to the bike, where it likes to be at certain speeds and rev ranges.
lilredmachine
PostPosted: 22:54 - 13 Dec 2019    Post subject: Reply with quote
You are more than welcome to have one, but it's a band aid, to use a terrible Americanism.
I took the one off my ZX12R because quite frankly it was a pain in the arse and dominated my vision with it's brightness when looking at the clocks at night.
Bike gearboxes are sequential, you go one up, one down. If it's lugging, shift down one -or two- or up if it's revving it's tits off. You know where first is, because you have to go though neutral to get it and it won't shift down again when you get there.
If you are trying to shift through the box at a standstill and getting lost, then you need to learn to shift down with the braking, and not just pull in the clutch and coast to a stop. This is the only situation I could imagine you would find yourself needing one.
They were originally created with track riding in mind, where bikes don't have a speedo, and the gear and revs are the only indicator or entry and exit points. I.e this corner should be entered at 8k rpm in 3rd and exited at 10k in 4th etc.
On the road, they are totally pointless.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:01 - 13 Dec 2019    Post subject: Reply with quote
I can't count and always end up trying to change up in 6....
Triumph Sprint ST 1050
sapstar
PostPosted: 23:57 - 13 Jan 2020    Post subject: Reply with quote
I bought a very cheap one for £11. As it is plug and play, I installed it. If I feel it is useless, I will throw it in the bin...
PostPosted: 13:24 - 15 Jan 2020    Post subject: Reply with quote
I have one on my CBR600RR track bike, but that's because pretty much the only thing I need to know is what gear I'm in, and in the middle of a track session I often forget what gear I'm in. The gear position indicator has transformed my track experience and I'm sure helped me to improve my laptimes. It's a nice to have on the road (my Street Triple has one as standard) but I can't say it's in any way essential.
Learning to count through the box is something that we all learned the old fashioned way, and I daresay it's made us better riders because of it. If you fit a gear indicator to your first bike you'll need one on every subsequent bike and that will be a bit of a faff.
The one I bought was a cheap chinese knock off, and it plugged straight in to the diagnostic port on my CBR. It had no pinout and I had to work out the 4 pin connections via trial and error. I did however have instructions for calibration which helped as it took a couple of goes to get it to calibrate properly.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:34 - 15 Jan 2020    Post subject: Reply with quote
The one I bought for the strumpet was OBD socket and a power lead.
Then to claibrate you just take it up through the gears.
Works perfectly. It did cost £120 so you would expect it to.
The last post was made 6 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.62 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 83.55 Kb
