Tyre Repair in S.London
LearnerLEGAL
PostPosted: 12:53 - 11 Dec 2019    Post subject: Tyre Repair in S.London Reply with quote
Thought my bike was heavier than usual wheeling it out this morning, only to find a screw planted nicely through the centre of the tyre and it deflating.
Any advice on a good repair/plug call out service in S.London?
Will do this later...at some point...maybe
Undinist
PostPosted: 13:58 - 11 Dec 2019    Post subject: Reply with quote
Much cheaper to plug it yourself. The Rema Tip Top kit never fails for me. https://www.amazon.co.uk/MOTORCYCLE-PUNCTURE-REPAIR-TUBELESS-SELLER/dp/B001AXK9QQ And I've done track days with plugged tyres. They're perfectly safe if you do a decent job.
LearnerLEGAL
PostPosted: 14:07 - 11 Dec 2019    Post subject: Reply with quote
Thanks @Undinist and @mpd72.
This time I may have to fork out a little extra for someone else to do it. I'm still fairly new to biking and don't have the kit/know how to take a tyre and put it back in confidence that it's safe. Or repair it for that matter.
I'm sure it's straight forward, but as I ride every day want to make sure the wheel isn't going to keep going when I stop.
Something to learn going forward though.
Undinist
PostPosted: 14:10 - 11 Dec 2019    Post subject: Reply with quote
I'm in Brixton, I'll show you if you like. No need to take the wheel off or anything. It's a 10 minute job and really not hard. If I can do it, anyone can.
Undinist
PostPosted: 14:21 - 11 Dec 2019    Post subject: Reply with quote
Another option is the RAC. They will plug it with a Rema kit. Or they did last time I called them out, which was a good few years back. I asked the guy whether the plug is really just a temporary repair. He said that the only reason they say that is for liability reasons. He said he saw a test where a Subaru Impreza had all its tyres punctured, then plugged, then the tyres were destroyed with ridiculous burnouts and drifts etc. The plugs stayed in throughout the test. After that I would leave the plugs in even for track days and high speed motorway runs.
Undinist
PostPosted: 14:22 - 11 Dec 2019    Post subject: Reply with quote
Anyway, I can pop over later today if you like. I'll PM you my number in case you want to text me.
Kris
PostPosted: 14:52 - 11 Dec 2019    Post subject: Reply with quote
Take the offer of help Thumbs Up
Those Rema kits are German made quality kits that the RAC use anyway.
If you ride every day you should keep a kit in your bag for next time.
www.prisonplanet.com
Undinist
PostPosted: 17:58 - 11 Dec 2019    Post subject: Reply with quote
So we're going to plug the tyre at the weekend.
All this has served to remind me that the kit I keep on my bike is so old that the glue has probably petrified. I'm about to start blood biking so I need to get organised and Ready For Anything. So I bought a new kit at J&S, having politely declined the Oxford Products alternative offered by Infinity. Fucking Oxford Bollocks. It looked like something you'd get in a cracker. If I'm going to monkey around reaming a big hole in my precious tyre I want TÜV certified quality, danke schon. You get a Rema kit in your tool kit when you buy a BM. Or you did the last time I bought a new BM. Must have been when Eden was Prime Minister and Princess Margaret was hot stuff.
LearnerLEGAL
PostPosted: 15:31 - 18 Dec 2019    Post subject: Reply with quote
Undinist very kindly and very graciously came round to show me how to plug a tyre over the weekend. He even picked up a kit for me on the way. A true gent.
However, the biking gods were not smiling on us that day. Having brushed up on the instructions we tried the first plug.
It ripped.
It must have been a dud in the pack. Unlucky.
That's ok though, we have 2 more.
In goes the 2nd one.
Another rip.
Huh..stumped..Undinist had never come across this before.
The conclusion was the hole must be too small. The instructions say nothing about a minimum width, only a maximum. But ok, it's being forced through a hole too small.
We filed away at the hole to make it bigger and in goes the final plug. Hurray, it doesn't rip. So we pump the tyre up and, yep, we made the hole too big and the plug doesn't have a tight seal.
We messed around with it for another hour easily but to no avail.
So earlier in the week I ordered a tyre to my local shop and was able the stuff the hole with enough push-bike rubber so there only a slow puncture which I then plastered over. Image attached.
It was an experience. The only thing we could conclude was that there was some of the metal wire visible on the sides of the hole inside the tyre, and it must be snagging the plug. However, even when we tried to turn the plug to avoid the wire as it went in they still ripped.
Undinist
PostPosted: 16:00 - 18 Dec 2019    Post subject: Reply with quote
Anyone know what the procedure is when the tyre reinforcement wire is on the edge of the hole? I've never come across this problem. I doubt you can file the wire without weakening the structure of the tyre. And I think the wire destroyed all three plugs we used. If I was stuck in the middle of nowhere I think I'd soak a piece of rag in glue, stuff it in the hole, let it dry, then inflate.
Easy-X
PostPosted: 18:13 - 18 Dec 2019    Post subject: Reply with quote
For some reason my mind wandered and read that as "soak a piece of rag in glue, sniff it and wait for the recovery truck" Very Happy
Anyhoo, how do these Rema kits compare to the common "liquorice string" type plugs? The Rema plugs look entirely different.
LearnerLEGAL
PostPosted: 18:18 - 18 Dec 2019    Post subject: Reply with quote
Well..the fact that 2 ripped didn't leave me with a lot of confidence. They looked pretty straight forward to use in the instructions. Eager to hear from others that have used them as well.
PostPosted: 18:28 - 18 Dec 2019    Post subject: Reply with quote
I've been perfectly happy with the string type jobbies.
I've used them with both car and bike and they have been good. I don't remember ever having one fail.
There again I've used the mushroom ones with no issues as well but I've never tried the Rema ones.
They can't be bad if the RAC use them though.
Easy-X
PostPosted: 01:49 - 19 Dec 2019    Post subject: Reply with quote
The first time I saw a puncture repair kit in action was funnily enough on my Mod 2 training. Instructor's bike had a flat and I got to see how it was done. He used the sticky string type (which seemed to work well enough) and I wonder if that type is less bothered about stray steel wires than the rubber ones.
Riejufixing
PostPosted: 02:56 - 19 Dec 2019    Post subject: Reply with quote
Did you use the reamer ("rema" Smile ) on the shaft of the insertion tool? That should be the right diameter.
Having used "mushrooms" on steel-belted tyres a few times, I think the diameter of the hole is quite important. It needs to be big enough to get the plug through, of you'll have a lot of trouble. You can use an HSS reamer or a TC one, it doesn't really matter. The fit with the filler needs to be tight but not that tight that you destroy your bung getting it through.
What sort of stuff i the plug made from, solid/homogenous or "bitty"?
To lay the strands of the belt, I'd guess a rotating action after the initial "in-out" of the reamer, and a similar action in the same direction plus pushing in for the plug.
Maybe I'll get the chance to try one sometime. Fingers crossed that I don't!
Undinist
PostPosted: 09:54 - 19 Dec 2019    Post subject: Reply with quote
We used the reamer and very gradually increased the size of the hole. But I think the wire was nicking the edge of the plug every time. Plus there was no sideways 'give' in the wire when we pushed the plug in. So I think the plugs were a lost cause. I wonder what the RAC would do?
colink98
PostPosted: 10:18 - 19 Dec 2019    Post subject: Reply with quote
maybe try the string as opposed to the plugs ?
Ride it like you stole it.
doggone
PostPosted: 11:55 - 19 Dec 2019    Post subject: Reply with quote
The strings don't need the cement stuff, I find it has usually gone off or you only get one go and ruin the tube or it sets in the nozzle.
If it's a really big hole you can reasonably put two in but I wouldn't trust that longer term.
Have used them many times in various vehicles and trailers.
The last post was made 6 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 102.69 Kb
