4stroke/2stroke?
Courageous T
PostPosted: 14:57 - 29 Mar 2005    Post subject: 4stroke/2stroke? Reply with quote
whats the difference?
50cc's are two stroke but arn't 2-stroke bigger bikes better?
Gazdaman
I did a trackday!!!
PostPosted: 14:59 - 29 Mar 2005    Post subject: Reply with quote
2 strokes aren't really used much in bigger capacity bikes anymore.
They used to be, the 750cc liquid cooled 'kettle'.
I think they're horribly polluting, expensive on oil, just there's more demand for large capacity 4 strokes.
Gaz
haGGard
PostPosted: 15:08 - 29 Mar 2005    Post subject: Reply with quote
I heard that after roughly 250cc, the stroke of a 2t will become to large and will become less efficient as they tend rev high Question Question
chaff mans random tingz on loot Razz
"Why dont you go and weld your face to a moving train, you sack of pus" - tobyr
"ROFL MY TOFFLE I AM TEH 1337 SPELLING MISTAKE FINDER!" - BikerBen
Smoto Bob
PostPosted: 15:37 - 29 Mar 2005    Post subject: Reply with quote
LOL, its more that after 250cc (welll after 125 really) they tend to eat petrol and 2 smoke oil
Never worked out the mpg of my kx500 it was easier just to measure in seconds Laughing
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
PostPosted: 16:23 - 29 Mar 2005    Post subject: Reply with quote
A 2 stroke produces power on every downward stroke of the piston, a 4 stroke only produces power on every other downward stroke of the engine.
Trouble is that a 2 stroke draws fuel and air into the crankcases then as the piston comes down the exhaust port opens and the burnt gases escape, followed by the transfer ports opening. As the exhaust port is still open (these ports are just holes in the side of the bore) some of the fresh air complete with unburnt fuel disappears straight out of the exhaust. For this reason they are have very dirty exhaust emissions.
There is a solution to this, using direct fuel injection. Basically draw the air in as normal but squirt the petrol in at high pressure once the exhaust port is closed again. The problem with this is injecting the fuel quickly enough for a high performance 2 stroke engine is not easy (there are 4 stroke direct injection engines, but then they only need to inject fuel half as often, plus being lower revving car engines have almost twice as long to inject it). Added to which lubricating such high pressure components is not easy (most diesels are direct injection, but diesel fuel is a reasonable lubricant while petrol is quite the opposite).
There have been a few direct injection 2 stroke. Aprilia make loads of direct injection 2 stroke scooters, but these are hardly high performance. Very clean running, very fuel efficient and use next to no 2 stroke oil. Bimota made the Vdue 500cc V twin 2 stroke with fuel injection but the system they developed was badly flawed (the bike landed up with a very sharp power band). An Australian company called Orbital hold loads of patents for direct injection 2 stroke engines and there was loads of interest from the car industry. However they were only getting engine lives of around 50000 miles which is fine for bikes but nowhere near long enough to be acceptable for the car industry. Honda have raced a direct injection 2 stroke off road bike, but they only touch 2 strokes when forced to so have not developed the idea further.
r0b
PostPosted: 17:06 - 29 Mar 2005    Post subject: Reply with quote
yeah the v-due was so bad bimota re-released it with cv carbs
and im guessing for a high performance 2t the optimum cylinder displacement is 125cc since all 2t gp bikes are (although this may be just a restriction of the rules?)
this might be usefull for people who dont understand, theres also some really cool stuff about rotary engines (wankel norton anyone ? )
https://science.howstuffworks.com/two-stroke.htm
'92 Honda NX650 Dominator RD02
'98 Kawasaki ZX9R C1
'00 Yamaha TT600R Belgarda
PostPosted: 17:51 - 29 Mar 2005    Post subject: Reply with quote
They rereleased them with normal Delloto slide carbs.
Theory as to why they had such a nasty power band was that they relied on the piston coming up to impact with the fuel being injected to attomise the fuel. Nice idea in a way, but only worked well when the piston happened to be in the correct place for this. With the timing of the injection this only happened over a fairly narrow rev range and the power tended to come in with one hell of a bang.
When they fitted carbs they lost 10hp and also landed up with a far dirtier running engine (the injected bike had no problems passing emissions rules round the world even without cats) which could not be sold in most markets.
The GP rules limited the number of cylinders in each class, which resulted in them all having 125cc cylinders. Up to the late 1980s the 125 class was limited to a maximun of 2 cylinders and the 125 twins were a hell of a lot quicker than the singles. The rule changes killed off a load of the smaller 125 race bike makers and pretty much made it a Honda only series for a few years until Aprilia got serious. The advantage of the single cylinder rules was that the bikes were cheaper, plus they pretty much only had to design one barrel for all 3 major classes.
Beef
PostPosted: 18:01 - 29 Mar 2005    Post subject: Reply with quote
you can get alot more power out of a 2 stroke engine, iv got a RGV250 (v-twin) and its putting down 68bhp at the back wheel, they are alot easier to tune than a four stoke
stevo as b4
PostPosted: 00:06 - 30 Mar 2005    Post subject: Reply with quote
True i think 125cc is probably the optimum size for a 2 stroke cylinder. Its the cylinder capacity that has had the most development of all 2stroke's, and it seems to be capable of far higher power per litre figures than the larger capacity 2stroke cylinders can acheive. A 250cc MX engine works fairly well, but has a better midrange and smoother build up into the powerband than a 125, but its rpm and usable rev range is lower and it cannot make up for this with the better/nicely spread power delivery, so ultimate power suffers. The big capacity 2stroke engines, especially big singles have probelms with cylinder filling at higher rpms, and there is not enough time to fill a big cylinder with mixture at high speeds, so they cannot produce the same amount of power per litre as smaller engines can, but despite a comparitively narrow usable rev range, they have huge torque and midrange, much more on a 500cc MX bike than any 600cc or sometimes bigger 4stroke 4cylinder engine would acheive!
PostPosted: 00:31 - 30 Mar 2005    Post subject: Reply with quote
Everyone seems to have a downer on 2-strokes these days. I like the way that they are very simple in terms of moving parts yet hugely complex in terms of design.
One of the main reasons they are dying a death is because the racing authorities have brought in big descrepancies in the allowable weights of racing 2-strokes as compared to the 4-strokes. This is deliberate because the companies want to concentrate their engine development on something that will pass the emissions regulations when they translate the technology into a road machine.
A 2-stroke moto GP bike would still be faster than a 4-stroke if they hadn't been activley descriminated against
PostPosted: 00:34 - 30 Mar 2005    Post subject: Reply with quote
The shorter the stroke the higher you can rev it. The more cylinders you have then the smaller bores you can have for the same stroke.
Yes a 125cc cylinder works well, but nothing like as well as 2 62.5cc cylinders.
Check this thread where is is expecting a 200kmh (125mph) top speed from a 2005 Honda RS125. Back in 1987 PB had a 125 Frency and a GP 125 twin (think it was an MBA) managed 142mph. OK the RS is running lower gearing, but I wonder if it really could manage the extra 17mph, and that is with 18 years more development behind it.
Frost
PostPosted: 01:04 - 30 Mar 2005    Post subject: Reply with quote
You can't run 62.5cc cylinders on a GP500 though, and thats what the maufacturers want to focus on. 4 cylinders is about optimum for a 500 so it makes sense to compromise the design of the smaller bike's for the benefit of development of the larger bikes.
Unfortunatly all the road going 2 strokes we have now are commuters, with the sports bikes being detuned versions of compromised race bikes.
The potential for 2 strokes is huge. If only a manufacturer would develop a modern 4 cylinder injection 250 then it would be a hell of a machine capable of embarrasing everything round a track. It could very well spark all the manufacturers to develop similar bikes in an effort to keep up.
Such a shame it'll never happen Crying or Very sad
Any more news on that RSV450? last i heard they canned it. Sad as it's about as close to a modern 2 stroke race bike we shall ever get, even if it is a V twin 4 stroke Laughing
PostPosted: 02:52 - 30 Mar 2005    Post subject: Reply with quote
The only reason you could not run an 8 cylinder 500cc GP 2 stroke bike with 62.5cc cylinders was because the rules disallowed you from having more than 4 cylinders in that class. If they had been allowed more cylinders then they would have made more power. As it was they could not put down the power they managed to get from a 4
Not really. None of the 125 sports bikes really bare any resemblence to the race bike except in the minds of the brochure writers. The RS uses a cast alloy frame too look vaguely like the race bikes, and a reed valve engine with a counter balancer (rather than a disk valve engine). Cagiva haven't had a 125 GP bike for
years, and the Mito engine alone weighs close to the weight of a competitive GP bike. The NSR engine is closer to the CBR125 engine than the RS125 race bike engine.
Still be a 4 stroke though Crying or Very sad .
mchaggis
PostPosted: 03:04 - 30 Mar 2005    Post subject: Reply with quote
Why can't we have normal carburetted fuel introduction, directly through the inlet side port without pissing about taking it through the crankcase, and have a wet sump and oil pump to feed the bearings? Just have some kind of plenum, supercharged or otherwise, and run it like a normal two stroke? You don't solve the unburnt HC emissions without conventional 4 stroke exhaust valves of course.
Feel free to shoot my idea full of holes, it's not really something I've given a lot of thought to.
I must not be a troll...
Mmmm, Guinness
Frost
PostPosted: 03:26 - 30 Mar 2005    Post subject: Reply with quote
I was reffering to much older bikes. The fastest 2 strokes on the road were designed in the late 80's using technology developped during 2 stroke racing in the 80's.
Normally when people compair modern 4 strokes to 2 strokes they are comapiring a modern 600 to a 15 year old 250 made using 20 year old technology.
If technology developped in the late 90's during 2 stroke racing were used in a modern 2 stroke then they would be far more competetive.
Even 125 2 strokes don't use modern technology in their design. An HRC RS125 puts out about 45bhp. surely it would be possible using modern technology to create a reliable 125 that makes an actual 30bhp+
Sadly, the demand just isnt there when people can go out and grab a brand new 4 stroke with the latest styling Crying or Very sad
Acid
PostPosted: 06:19 - 30 Mar 2005    Post subject: 2 strokes Reply with quote
Rs 125 mate 33bhp full power
mito 125 33bhp full power
simon1221
PostPosted: 11:38 - 30 Mar 2005    Post subject: Reply with quote
More around the 30bhp mark, and thats after mods (exhaust, vforce3 etc etc)
I think the standard RS is about 28bhp, Mito is abou 28bhp, NSR 26-27bhp, TZR + 2T XTC + DT 22bhp
I think the RG is in the middle somewhere.
However that is before tuning and port polishing and god knows what else.
Josh|RD125LC
PostPosted: 11:53 - 30 Mar 2005    Post subject: Reply with quote
You've just got to think of the power of the Suzuki RG500, Yamaha RD500LC, Honda NS400, to believe that large capacity two strokes rule Razz
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
binge
Emo Kiddy
PostPosted: 12:11 - 30 Mar 2005    Post subject: Reply with quote
Im not very technical when it comes to engines but I can see what you mean.
I suppose the reason the fuel and oil is inducted through the crank case into the cylinder is to keep it simple. And isnt that what gives a 2 stroke more power, Not having a wet sump?
<|Ben|>
mchaggis
PostPosted: 12:48 - 30 Mar 2005    Post subject: Reply with quote
Well, it needn't be a wet sump, just a pressurised oil feed for the main crank bearings and conrod bearings in the same fashion as four stroke. Two strokes are more powerful simply because they fire on every second stroke rather than on every fourth. That's mainly a function of the fuel/ air flow, in that they induct new charge in the same stroke as expelling spent charge.
In basic terms, one stroke does expansion, exhaust and induction, and the other compression. I'm just wondering if having the volume decrease under each piston is necessary to help push the gas into the cylinder above in co-ordination with the volume increase in the cylinder.
Was the V-Due directly injected, rather than injected before the inlet opening? I don't see why they can't inject it before the inlet or use carburettors. Of course, they'd lose some of the control you can have over an engine like that, some of the marketing spiel, but perhaps also a lot of cost and problems. A complete loss lubrication system always did seem a bit silly to me.
Mmmm, Guinness
Courageous T
PostPosted: 13:16 - 30 Mar 2005    Post subject: Reply with quote
wow, of all the essays Very Happy
PostPosted: 13:22 - 30 Mar 2005    Post subject: Reply with quote
Even so the connection was far more to do with marketing than with engineering. For example the RGV250 came from Suzuki when they did not even have a 250 GP bike. The NS400R was a triple, after Honda had given up with the triple in GP racing (and the cylinders pointed in different directions on the GP bike).
Not much did happen really. One reason they moved to the 4 strokes is that nobody was really doing anything new with the 2 strokes.
DaFrostyOne wrote:
Even 125 2 strokes don't use modern technology in their design. An HRC RS125 puts out about 45bhp. surely it would be possible using modern technology to create a reliable 125 that makes an actual 30bhp+.
Only real problem is emissions.
True.
Because nothing would draw the mixture in to the cylinder. They rely on drawing the mixture into the crankcases, then pressurising the crank cases (by the piston coming down) then allowing the pressurised fuel / air mix through the transfer ports into the cylinder.
If you start using exhaust valves to try and stop unburnt fuel going down the exhaust then you also throw away a large part of the tuning opportunities for the exhaust.
He meant the Honda RS125, a race bike, not the Aprilia RS125 road bike.
Original early RS125 made 28.5hp at the back wheel in the UK road tests. Probably is a bit over 30hp at the crank.
Unless you run a seperate supercharger to push the mixture into the engine then you need the volume of the crankcases. Cannot see any real reason why you could not use sealed bearings for the mains and big end and then just use a low pressure oil system, although the little end bearing might be more difficult and you still need to lube the bore.
Yes, that is the whole point of the direct injection system it used. The fuel was only injected into the cylinder after the exhaust port had closed.
Because then you still have the exhaust port open when the fuel ladden air goes into the cylinder, resulting in a load of unburnt fuel going down the exhaust, and giving every environmental agency a heart attack.
mchaggis
PostPosted: 15:00 - 30 Mar 2005    Post subject: Reply with quote
I thought those things might be problems. Smile How does the V-Due get the charge into the cylinder? Is it still through the crankcase with total loss lubrication as normal, just with direct injection to avoid unburnt HC emissions?
Giant two strokes with proper valvetrains are really quite clever though.
https://www.billzilla.org/sulzer3.jpg
98,000 hp @ 100rpm from almost 22,000 litres! Shocked
https://www.billzilla.org/sulzer2.jpg
https://www.billzilla.org/othercars.htm
There's some cool stuff on that website.
Mmmm, Guinness
PostPosted: 15:12 - 30 Mar 2005    Post subject: Reply with quote
Yes, the VDue used normal 2 stroke induction through the crankcases with total loss lubrication. No reason that cannot be improved though, as just dumping the oil in with the air means that 90% of it goes nowhere useful.
The last post was made 21 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 142.69 Kb
