Tricity 125
Darkzentai
PostPosted: 20:32 - 18 Dec 2019    Post subject: Tricity 125 Reply with quote
Just got myself a Yamaha Tricity 125 replacing dying old bike .
The Tricity is the best bike I’ve ever ridden what it lacks in power and top speed it makes up in stability and tons of grip due to its 2 front wheels .
It does care about high wind or heavy rain it doesn’t even feel them .
I might even kick myself up the ass to pass my test so I can get the 300cc version .
Zentai
Nobby the Bastard
Harley Gaydar
PostPosted: 20:41 - 18 Dec 2019    Post subject: Re: Tricity 125 Reply with quote
Homo.
Triumph Sprint ST 1050
PostPosted: 20:42 - 18 Dec 2019    Post subject: Reply with quote
I very much doubt you have even approached the limits of grip with modern tyres on a two wheeled motorcycle unless you have panic braked a non ABS bike on gravel or similar.
As a rider of 40 years I struggle to see what benefits this configuration brings. The front end will be heavy and complicated. I do wonder if it's a psychological thing that 3 wheels are better than two.
Saying that, as I have never ridden one I'm not really in a position to criticise so if you are happy, Thumbs Up
But if you really like those things, pass your test, be a man and buy...
https://i2.wp.com/tfortrends.com/wp-content/uploads/2017/10/Yamaha_06.jpg?fit=1000%2C750
RAYK47
PostPosted: 21:05 - 18 Dec 2019    Post subject: Reply with quote
Whatever makes you smile fella. Personally I don't really get it.
Darkzentai
PostPosted: 21:06 - 18 Dec 2019    Post subject: Reply with quote
I love the Niken this is my dream bike .
It not so much panic breaking as that will make it slip but It just corners a lot better than anything I’ve ridden especially in the wet or places you know to be slippery where my old bikes would aquaplane this just carries on without a care .
It is heavier but what makes the difference is you’ve got two tires at the front giving you more grip.
There may be a psychological element to it as well.
Zentai
PostPosted: 21:21 - 18 Dec 2019    Post subject: Reply with quote
A 125 does not go fast enough to aquaplane.
Whatever happened, it wasn't aquaplaning.
Darkzentai
PostPosted: 21:43 - 18 Dec 2019    Post subject: Reply with quote
it would do 68mph but you can aquaplane at 35mph .
Regardless I could feel the front wheel slip on corners in heavy wet .
Zentai
Teflon-Mike
tl;dr
PostPosted: 22:57 - 18 Dec 2019    Post subject: Reply with quote
It's a twist and go scooter... with an extra wheel...
The classic scooter as defined by the Vespa, was and remains a mule of design. It was an attempt to make a motorbike with 'some' of the user-friendliness of a car... but dynamically? It gave little or none of the luggage/passenger carrying capacity of the car, none of it's weather protection, and lost virtually all of the possible 'stability' a bike might have by starting with daftly small wheels... and they have been trying to overcome 'that' pretty fundamental design flaw with ever more convoluted technological tong twisters for three quarters of a century!!!
This and machines like it are pretty good examples of marketing over merit!!!
But if you like it... and can afford it.... what the heck.....
BUT DO NOT try and repeat or justify the sales hype here to us and folks like us that see it not as a marvel of mechanics, but for what it is, an evolved design donkey that's neither fish nor foul.
It's a 12bhp four stroke 125 scooter... with a twist and go transmission for folk that cant handle gears, and an extra wheel to pander to them afraid of falling over!
At BEST with 12bhp, a 125 might just nudge a genuine 70mph... just.... in scooter styling with the aerodynamics of a mars-bar, plus the drag of an unnecessary extra wheel? Yup, you MIGHT see 68 or 70mph on the speedo occasionally... but I seriously doubt it would achieve that over the measured mile in a proper two way timed top-speed test.
As for aqua-planing, yup you might aquaplane at as little as 20mph.... why this should be a problem? Learn to ride, and get results with technique not technology... Yup. Aqua-planing happens when the wheel; traps surface water beneath the tyre and starts to 'float' on that water, rather than grip tarmac beneath.... having an extra wheel here actually wont help!
You have a bike, with weight it puts that weight on the tyre and if there's water under the tyre, it'sinks' until tyre touches tarmac. Adding an extra wheel, just shares the weight on an extra point of contact, so that there's less pressure on the tyre to push it through the water and find grip on the tarmac beneath.... it does NOT give you any extra 'grip'... and certainly not from diddly little commuter compound scooter tyres, compared to a soft compound motorbike tyre, which around 20" rolling diameter compared to 14" or so for a scooter hoop, has a shallower 'approach angle' more inclined to NOT build up the wall of water under the tyre to begin with.... like I said, its a heck of a lot of technology being chucked at 'non-problems' to over come basic design inadequacies, and appease marketing men and numpties (like you!) in the street.
The main selling point of these things when they first appeared in the form of the Piaggio MP3, was that with wheel spacers to get the front track width out above reg, they 'might' be ridden, without L-Plates on a car licence as a 3-wheeler.....
It is NOT some astounding bit of design, or a particularly great motorcycle, and has virtucally NO advantages by dint of it's extra front wheel, over even a more conventional two wheeled twist and go scooter, let alone a 'propper' motorbike, other than they can charge more money for it on the show-room, on the fallacies you have fallen for. Congratulations...
B-U-T is you like it and it makes you happy.... great.... just don't try conning US with the sales chit YOU fell for.... it wont wash!
PostPosted: 00:55 - 19 Dec 2019    Post subject: Reply with quote
You may have lost traction but not by aquaplaning. That 35mph is the conservative advice for a worst-case scenario in a car regurgitated across the internet and based on research on aeroplane tyres in the 1950's.
Bikes have a radically different contact patch shape. A sportsbike with a 120 section tyre has to be doing over 60mph to start having a risk of aquaplaning.
Also the rear would aquaplane plane first due to the larger contact patch/lower load per unit area.
In fact, a double tyre would probably make you MORE likely to aquaplane.
So your issue is grip. That's all about contact patch size and tyre compound. Yes, a dual wheel has more grip. Twice as much in fact. However your last bike probably had crappy tyres. It's a really unfortunate feature of the motorcycle industry that they put shit rubber on bikes designed for learners.
Pass your test, get a bike big enough to stick some PR5s on and find out what a proper tyre can do on a wet road.
Video for inspiration. Note how some of these guys do aquaplane and come off. Also note how it's the rear wheel every time. They manage to keep it together a lot of the time and that's because it's the rear letting go, the retain some directional control fron the front. If your front wheel aquaplaned in a corner, you would be off the bike, it would lose ALL grip and you'd lowside immediately, rider input would not correct the situation.
https://youtu.be/tv4_425K8r4
Riejufixing
PostPosted: 01:16 - 19 Dec 2019    Post subject: Reply with quote
How you can say that when there are so many variables?
Easy-X
PostPosted: 02:00 - 19 Dec 2019    Post subject: Reply with quote
There is a good use for such a scooter: give it to Randy Grubb...
https://randygrubb.com/wp-content/uploads/2013/05/Deco-Bipod-B-with-randy-grubb.jpg
As far as I can tell the only benefit is not having to stick a leg out when stationary which is genuinely useful if you have mobility issues but still want a bike. Mechanically it's very complex though, i.e. extremely expensive to fix if things go wrong. Plus you have to factor in an extra tyre to pay for when they wear out Smile
PostPosted: 02:08 - 19 Dec 2019    Post subject: Reply with quote
That's pretty much what comes out of the afore-mentioned 1950's aviation report calculation speed = 10.27 * Sqrt(tire pressure) and assumes a square contact patch and about 5mm of water with a tyre inflated to 35psi. Such as you'd find with an aeroplane landing on a wet runway.
In reality, motorcycle contact patches are likely to be much better for clearing water than this due to their shape and resistance to cupping.
Riejufixing
PostPosted: 03:00 - 19 Dec 2019    Post subject: Reply with quote
But the whole point is that you said the '50s report is discarded. The contact zone is NOT "square". So how can your generalisation be made?
I'll have a poke about & see what I can find re the TRL or whoever.
Sister Sledge
PostPosted: 08:56 - 19 Dec 2019    Post subject: Reply with quote
Thought this was a post about washing machines..
I'd only accept a 3 wheeler if it was a Ford Focus front end welded to a motorcycle rear.
CCM 404 DS
PostPosted: 12:25 - 19 Dec 2019    Post subject: Reply with quote
I quite fancy one of these.....
https://upload.wikimedia.org/wikipedia/commons/c/c6/Can-Am_Spyder_RSS_%2802%29.jpg
WD Forte
PostPosted: 13:58 - 19 Dec 2019    Post subject: Reply with quote
I think me mum had a Tricity
https://www.gracesguide.co.uk/images/7/73/Im196003IHX-Tricity.jpg
bikers smell of wee
WD Forte
PostPosted: 14:08 - 19 Dec 2019    Post subject: Reply with quote
Overly complex
It should be fine when brand spanking new but when it all starts to wear will be a nightmare for the home mechanic to keep aligned/safe/fit for purpose
Similarly if it takes a clout, just hope you don't have to foot the bill
Filtering options will be constrained
just buy a bloody car!
bikers smell of wee
Riejufixing
PostPosted: 14:25 - 19 Dec 2019    Post subject: Reply with quote
Coo!
Every so often something comes along that makes me say "Coo!".
That's one such thing. Randy Grubb's decopods.
I can think of lots of disadvantages, but. Coo!
PostPosted: 00:14 - 20 Dec 2019    Post subject: Reply with quote
My point was, I'd take that as a working minimum, worst case for a motorcycle tyre. In reality they will almost certainly perform much better because the contact patch shape and curved tyre profile will effectively plough through the water rather than ride up on top of it. Like comparing a speedboat with a skiff, which will go up on the plane at the lower speed?
I've ridden sportsbikes through standing water at three figure speeds on numerous occasions and never a shimmy.
Sister Sledge
PostPosted: 08:27 - 20 Dec 2019    Post subject: Reply with quote
WD Forte wrote:
Overly complex
My local Piaggio dealership has several in the yard. Each bike has been dismantled down to the linkage mechanisms and then abandoned!
CCM 404 DS
Evil Hans
PostPosted: 08:39 - 20 Dec 2019    Post subject: Reply with quote
Trike.
PostPosted: 08:42 - 20 Dec 2019    Post subject: Reply with quote
But it isn't a trike. It's a bastardised bike that solves a problem that only exists in peoples minds.
A trike is a bit of fun but I always had a bike as well.
andyscooter
PostPosted: 10:53 - 21 Dec 2019    Post subject: Reply with quote
as someone who has ridden one
they are ok until one of the tyres loses a bit of pressure
they then pull like fuck to one side
piaggio did the tilty three wheeler first and they made a 500cc version that could be driven on a car licence
Easy-X
PostPosted: 12:20 - 21 Dec 2019    Post subject: Reply with quote
Of course! How did I forget that Smile So these are classified as trikes and car drivers get trike entitlement so no CBT, no Am/A1/A2/A training required?
iooi
PostPosted: 13:38 - 21 Dec 2019    Post subject: Reply with quote
https://youtu.be/FjKpuJOlkZc
Aquaplaning in the extream.
TBH. Depth of water makes a lot of difference compared to speed, contact patch etc.
The last post was made 6 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 137.05 Kb
