| The Gatekeeper |
 The Gatekeeper L Plate Warrior
| Tankie |
 Tankie Crazy Courier
| Riejufixing |
 Riejufixing World Chat Champion
| The Gatekeeper |
| Easy-X |
 Easy-X Super Spammer
 Posted: 14:06 - 19 Dec 2019 Post subject: |
Pissing about with springs and weights doesn't make as much of dramatic difference as people like to make out
How bad is it? Bad enough that it might stall if you don't "nurse the throttle" ?
Basically we need to narrow down whether the issue is the engine not running properly or a transmission problem. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Riejufixing |
| The Gatekeeper |
| Nobby the Bastard |
| Easy-X |
 Posted: 17:36 - 19 Dec 2019 Post subject: |
| The Gatekeeper wrote: | It revs but goes no where. It ticks over fine, its just hardly any drive Full throttle the engine is reving perfectly but the pull away is so slow? Once above 10/15mph its fine. |
If it's running okay on the mid to high end of the rev range I think we can discount issues with fuelling, air intake and exhaust. That leaves a blocked or wrongly sized pilot jet, a blockage in the pilot circuit of the carb, idle and air screw adjustments.
On the transmission side if you had a loose belt that should be obvious from inspection. I take it you swapped out the small clutch springs. How about the main big one?
Other that I can only think of disassembling the whole CVT to make sure all the parts are moving freely. The old turd scooter I rebuilt had seized plates (effectively "stuck in bottom gear") stuck in "high gear" seems unlikely though  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| The Gatekeeper |
| stevo as b4 |
The last post was made 6 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
