Annoying fairing buzz
Andy_Pagin
PostPosted: 14:51 - 21 Dec 2019    Post subject: Annoying fairing buzz Reply with quote
My recently acquired 2010 FZ1 has what sounds like a buzzing noise coming somewhere from the front, only happens at about 4,500 rpm and only when moving, ie. it won't buzz if I rev it when at a standstill. It sounds more like plastic resonating than something mechanical. Ideas anyone? I don't fancy stripping off all the plastic and re-tightening everything this time of year.
Tankie
PostPosted: 15:21 - 21 Dec 2019    Post subject: Reply with quote
see if you can find it by using a finger nail just touching different areas of the fairing , then tape a coin or weight in the area to change the frequency at which it resonates
PostPosted: 16:02 - 21 Dec 2019    Post subject: Reply with quote
So it only buzzes when you are moving and only at 4500 rpm.
Is the 4500 whichever gear you are in or only one gear. If it's every gear it's engine induced and only in one gear it's probably speed/rolling chassis induced.
Then you have to work out if it's a problem with what is inducing the vibration or with what is being induced. Laughing
It can get very annoying.
PostPosted: 19:26 - 21 Dec 2019    Post subject: Reply with quote
Loosen off the screws, wiggle it all about a bit, then tighten them again. It'll probably buzz at a different speed/revs.
Then realise it's the helmet strap/hoodie string.
Sister Sledge
PostPosted: 19:28 - 21 Dec 2019    Post subject: Reply with quote
It's going to be what you least expect. I thought my clutch basket had unscrewed and was rubbing on an outer casting - turned out to be a stripped (loose) bolt on the engine bash plate.
CCM 404 DS
chickenstrip
PostPosted: 19:40 - 21 Dec 2019    Post subject: Reply with quote
On the FZS1000, there are little foam dampers between the fairing and liner panels. As they age, they lose their damping ability, and you get all kinds of weird noises. Anything like that on the FZ1?
almostthere
PostPosted: 22:10 - 23 Dec 2019    Post subject: Reply with quote
Had a similar thing on my old zx9r after an age trying to figure it out i cured it by putting thicker rubber washers on the mirror mounts,
turns out the fairing was rattling against the mirror bracket Thumbs Up
Beer, It's the reason I get up every afternoon
www.mfairco.uk
thx1138
PostPosted: 00:48 - 24 Dec 2019    Post subject: Re: Annoying fairing buzz Reply with quote
I opened the thread to see what the bike was. Yes, happened to me, same bike 2007 model. Really annoying,
Nobby the Bastard
Harley Gaydar
PostPosted: 11:30 - 24 Dec 2019    Post subject: Reply with quote
You should be able to reach most plastics whilst riding to tell by touch if they are vibrating.
Remove individually the bits you cant reach and test til you find what was the offending article and find some way to damp it.
Triumph Sprint ST 1050
PostPosted: 14:23 - 24 Dec 2019    Post subject: Re: Annoying fairing buzz Reply with quote
Yeah, and who would've thought it was the thingy-ma-jig rattling.
seeyalater
PostPosted: 11:47 - 27 Dec 2019    Post subject: Reply with quote
I had a similiar thing, thought engine was screwed. then one day was doing something and noticed where indicators was fitted there were 2 parts close to each other, plastic and metal, the rev frequency vibrated them together. so added a little tape to dampen it inside, now is quiet.
The last post was made 6 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 70.5 Kb
