| thuganomics16 |
 thuganomics16 Nova Slayer
| tatters |
 tatters Exxon Valdez
 Posted: 02:02 - 29 Mar 2005 Post subject: |
| Quote: | ive heard that the engine is practically bombproof |
(falls on floor laughing )
a top engine re-bulid would be every 10,000-20,000 miles depending on how well the bike has been looked after (quality of the oil, warming up fully before riding etc.)
cost about £50 for a piston, £110 to replate a cyclinder if needed, gaskets about £30
a mate of mines 2001 mito evo,s big end bearing broke up at 5,000km and it was a well looked after bike. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Frost |
 Frost World Chat Champion
| tatters |
 Posted: 19:16 - 29 Mar 2005 Post subject: |
| DaFrostyOne wrote: |
You WILL need:
Piston
Rings
base gasket
Piston clips
You may need:
Head gasket
Barrel replating
small end bairing
Piston pin
pistons ushally come with the rings/gungon pin/circ clips
l think mitos have a "o" ring in the cyclinder head so no need for a head gasket, but a re-placement cyclinder head may be needed if it has substained serious damage.
cyclinder would only need re-plating if it was worn out or had substanded damage from a forgein object or bits of bearings/piston ring.
small end bearing only needs to be replaced if it is failing or has broken up (which would destroy the piston).
also note that some times the conrod can snap or the bid end bearing/thrush washers can break-up which would mean the crank cases would have to be split to get the crank out and have it re-built. Worst that could happen is that the conrod snaps and punchs a hole in the crank cases which is caused by a failing thrush washer on the crank which alows the conrod of move sideways more than it should (nearly happened on my KR1S!). ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| Robby |
 Robby Dirty Old Man
The last post was made 21 years, 189 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 49.96 Kb
