| dn38416 |
 dn38416 Nitrous Nuisance
 Posted: 19:35 - 30 Dec 2019 Post subject: |
Check the play on your unitrak bushes. GPZs eat those for breakfast. Also the swingarm bearings
Get the rear wheel up off the ground (maybe put a plank under the mainstand) then put a pry bar under the rear wheel and lever it up and down, see how much free play there is before you come up against the shock spring. There should be almost none. If there is a lot, you shold be able to see where the movement is. It's usually in the bushes on the unitrak casting but could also be swingarm bearings or wheel bearings.
Also check the cush drive bearing for play by wiggling the sprocket up and down/side-to-side and back and forth (might explain your chain issues). The bearing can be completely shot and not really affect the handling.
Visually inspect the mainstand for bends/cracks with a bright light. Also have a look at the pivots for signs of damage and free play, the mountings can go oval over time. Have a look at the angle the stand is sitting at when the bike is on the stand, it should come to very slightly over the vertical. If it's pointing way forwards, you could have damage/wear on either the pivot or the bump stop. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| doggone |
 doggone World Chat Champion
| Nobby the Bastard |
| dn38416 |
| dn38416 |
| Nobby the Bastard |
| dn38416 |
| Nobby the Bastard |
| dn38416 |
The last post was made 6 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
