Fork rebuild, do the bushes?
Irezumi
PostPosted: 16:32 - 01 Jan 2020    Post subject: Fork rebuild, do the bushes? Reply with quote
I'll be rebuilding the forks on my bike which is new-ish to me in the coming months once the weathers warmed up. The bike has 30k on it and will assume the bushes have never been changed.
Based on this would you change the bushes, do it based on inspection or assume they will be fine and just do the seals and oil?
Nobby the Bastard
Harley Gaydar
PostPosted: 16:36 - 01 Jan 2020    Post subject: Reply with quote
They're typically about 15 quid each h so its false economy to not replace then every time you strip the forks.
Triumph Sprint ST 1050
PostPosted: 16:39 - 01 Jan 2020    Post subject: Reply with quote
Quite a good chance of damaging them taking it apart anyway in my experience so I'd just order them. Any time I dismantle forks on an older bike, one of the forks invariably lands up with the bushes overriding one another and sticking, leading to hours of sweating/swearing and knackered bushes. The other one usually just pops apart first whack
It would be really annoying to fit new seals then have them leak.
Riejufixing
PostPosted: 18:36 - 01 Jan 2020    Post subject: Re: Fork rebuild, do the bushes? Reply with quote
That.
Irezumi
PostPosted: 19:02 - 01 Jan 2020    Post subject: Reply with quote
OEM parts (which I tend to buy for fork seals as I find they're better/last longer) are about £25 a piece, not a great deal but a lot for a slit metal ring. This is for a Suzuki SV1000 so could get aftermarket parts prefer OEM as mentioned.
Will order them anyway as I'm sure they will be original and worn.
Tdibs
PostPosted: 00:21 - 03 Jan 2020    Post subject: Reply with quote
I would most likely change them. Ive had them without much wear after 50k on the sv650 I had, but on my fazer 1000 they were completely worn through and damaging the fork internals at 29k so just depends on the fork and its use.
I cant say for sure as it was a while ago, but I think I ended up ordering OEM bushs in the end as pyramid parts ones had a bunch of sharp edges and the coating already worn off in areas when I got them in the package.
Riejufixing
PostPosted: 01:04 - 03 Jan 2020    Post subject: Reply with quote
What about whatever they've worn on?
Nobby the Bastard
Harley Gaydar
PostPosted: 10:38 - 03 Jan 2020    Post subject: Reply with quote
The bushes are designed to wear so that the inside of the fork leg and the stations don't.
The last post was made 6 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 56.4 Kb
