ACF50 wider application?
ThunderGuts
PostPosted: 12:34 - 09 Jan 2020    Post subject: ACF50 wider application? Reply with quote
Ok so maybe this strictly speaking isn't the right place as it's to do with my car; the subframe on my Subaru is slightly corroded and it'd be nice to help prevent any more as I don't want to bin off the car just yet - any reason why ACF50 wouldn't be suitable for giving the underside of the car a good coating? Or would Waxoyl be a better choice?
If the marketing blurb is to be believed ACF50 can be sprayed everywhere . . .
TG.
PostPosted: 13:22 - 09 Jan 2020    Post subject: Reply with quote
No reason you couldn't use it. May work out expensive.
Or get it up and a ramp and underseal it?
Nobby the Bastard
Harley Gaydar
PostPosted: 13:29 - 09 Jan 2020    Post subject: Reply with quote
It'll wash off in short order.
Proper rustkilla and underseal are your friend.
Triumph Sprint ST 1050
Riejufixing
PostPosted: 14:20 - 09 Jan 2020    Post subject: Re: ACF50 wider application? Reply with quote
Grease might be OK. I like Waxoyl, though. The "clear" paint-on stuff, not the black or the spray-on. Note, whaever you put on is useless if it's over flaky paint or dirt, you will have to clean the thing you're coating. Waxoyl goes on best when it and the component are reasonably warm.
I don't like the old-fashioned plastic/rubber underseal. It cracks, traps water (even salty water) behind, and if you want to get it off it's a swine even if it is still stuck on to some extent. Don't use a wire cup brush, the results are very, very messy.
The last post was made 6 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.8 - MySQL Queries: 13 - Page Size: 39.95 Kb
