| Jay2903 |
 Jay2903 Scooby Slapper
| Easy-X |
 Easy-X Super Spammer
| WD Forte |
 WD Forte World Chat Champion
| Riejufixing |
| mentalboy |
 mentalboy World Chat Champion
| Jay2903 |
 Posted: 05:24 - 12 Dec 2019 Post subject: |
Cheers for the help guys. Completely forgot I posted on here. It was the aftermarket ignition coils. As soon as I switched back to the originals the spark was consistent and noticibly stronger.
| Jay2903 |
| Easy-X |
| jaffa90 |
 jaffa90 World Chat Champion
| Jay2903 |
| Jay2903 |
| Riejufixing |
| jaffa90 |
| mentalboy |
| Tankie |
 Tankie Crazy Courier
| GettinBetter |
 GettinBetter Crazy Courier
| Teflon-Mike |
 Posted: 15:53 - 11 Jan 2020 Post subject: |
Eliminate variables.
Who knows is that spark is intermittemt, or that the plug is just bouncing off the rocker cover when the engine cranked....
CAR JUMP LEAD!!! clamp the plug in croc-clip one end you know you got a good electrical contact. Other end croc-clip to a known Good earth.. preferably not a bit of frame or engine that's pained or laquered.
Then try again, and is the spark more consistent? And DO you actualkly have an intermittent spark?
If points system... yeah.. ergh! But the condensor was/is always my most likely usual suspect... and fact you say that its already been changed dont so a lot for my confidence... what was it changed with, and even a band new item, I would have doubts over how long it had been sat, drying out, on a shelf for.. especially for a more obscure model of old classic.
Old 'trick' was to get a new condenser from the mororfactors, and something common and hopefuly cheap, that comes out of a box that gets refreshed pretty often, the common as muck item for a Mini/Morris/Lucas distributor used to score well here; THEN isolate the OE connenser in the mag, and couple the car condenser between the coil input and a known good earth. Makes the same circuit, and does the same job, soking volts when points open, but car typr condenser usually has a little extra capacity, and not stuck against the crank case isn't having its electrolyte boiled dry or di-electric tissue cooked by engine heat. Plus better odds that new car type condener is closer to 'fresh' and not been sat on a store room shelf for forty years.
Whilst in there, I'd check the state of the points, and again, they maybe shop new, but how fresh are they? Contacts could be rusty as feck by now, or have been 'protected' with grease/oil thats now a nice layer of soot or crud. So clean and gap critically, and re-check timing.
Beyond that... first question is DO you actually have a miscellaneous spark?Second Is everything you think you have checked/eliminated really checked/eliminated... SO, what is the 'real' problem? Wont the engine start? Hold idle revs? Take load? What? And IS the ignition system a likely suspect in that?
Its an old engine, has it been rebuilt? Has it burned off assembly oil? Are the valve clearances correct? Does it have good compression etc. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Jay2903 |
| jaffa90 |
| mentalboy |
| Jay2903 |
| Teflon-Mike |
 Posted: 02:52 - 23 Jan 2020 Post subject: |
The Montesa motors, especially the Cota trials versions with a heavier mag-rotor for slow-running were notorious for sheared keys; I've lost about half a dozen over the years. When 'new' it was usually caused by the rotor not being so carefuly fitted. When old/Resto'd, it was a similar looseness, usually caused by a little surface rust on the rotor and or crank taper, and or looser worn rotor nut.
On resto, the advice was to use a little valve lapping past on the crank-shaft, and spend indeterminate hours working the rotor back and forth on the crank taper to a) get the surfaces properly clean of any surface rust and or crud' b) clean thoroughly with thinners (esp after lapping with valve past) c) To critically fit the rotor onto the crank, which meant using a copper mallet to actually get the rotor to interference fit to the crank taper, rather than merely relying on the pressure made by the, probably worn, rotor nut.
If that's any ideas for you. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| mentalboy |
| Jay2903 |
 Posted: 05:34 - 23 Jan 2020 Post subject: |
| Teflon-Mike wrote: | The Montesa motors, especially the Cota trials versions with a heavier mag-rotor for slow-running were notorious for sheared keys; I've lost about half a dozen over the years. When 'new' it was usually caused by the rotor not being so carefuly fitted. When old/Resto'd, it was a similar looseness, usually caused by a little surface rust on the rotor and or crank taper, and or looser worn rotor nut.
If that's any ideas for you. |
Cheers, I’ve been looking at it and I can see the problem.
The inside of the rotor is rubbing against the field coil as you’ll probably be able to see in the image of the rotor. Any ideas what’s causing it ?
(I can’t upload the image of the field coil because the file is too large but that also has scratches like the ones on the rotor)
| Jay2903 |
The last post was made 6 years, 154 days ago. Instead of replying here, would creating a new thread be more useful? |
