Master Cylinder suggestions?
A100man
PostPosted: 11:34 - 01 Jan 2020    Post subject: Master Cylinder suggestions? Reply with quote
The m/c on My GT250 needed a revbuild.. I cleaned out the original parts but it went soft quickly..??
Anyhow I bought a (cheap) rebuild kit and now it won't bleed at all.. even at the top union..
So I figured bollocks to it i'll buy a new generic pattern unit or a something from a more recent bike that works (e.g. my XJ550 sports a GPZ600 m/c)
Suggestions welcome.
WD Forte
PostPosted: 14:21 - 01 Jan 2020    Post subject: Reply with quote
Have you tried sticking your thumb over the top union hole
and working the lever to get initial pressure and seat the seal?
( assuming proper assembly that is)
Check the return hole isn't blocked as well
bikers smell of wee
A100man
PostPosted: 14:38 - 01 Jan 2020    Post subject: Reply with quote
Ta..
I'll give it another go at that before I finally throw the towel in. Return pin prick hole checked a couple of times earlier in the process..
redeem ouzzer
PostPosted: 16:27 - 01 Jan 2020    Post subject: Reply with quote
KTM Duke or Aprillia 125.
Be a REAL MAN!
A100man
PostPosted: 19:51 - 11 Jan 2020    Post subject: Reply with quote
Just to tie this one up. I has reassembled some components in the wrong order, Embarassed corrected it but still gave weak pressure. Bought a secong hand Nissin from of a recent CBR125 for a tenner, this now has nowfirmed things up.. suspect though I also need to remew all the copper washers.. again...
Easy-X
PostPosted: 21:47 - 11 Jan 2020    Post subject: Reply with quote
Just a thought but if you're swapping out the master don't forget to check the line for bulges and cracks while you're at it.
A100man
PostPosted: 12:34 - 12 Jan 2020    Post subject: Reply with quote
Thanks - line is new braided type.. Thumbs Up
The last post was made 6 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 51.36 Kb
