| ThatDippyTwat |
 Posted: 19:29 - 13 Jan 2020 Post subject: FIXED - Bike dies on idle or closed throttle. |
Bike is a Roadwin 250fi, essnetially a CBR250R single.
If you let it idle in neutral, it does after 3-4 seconds. If you roll off the throttle it will die when revs get lower, about where you would start to clutch in to come to stop. it's done it the odfd time or two in the last couple of days, but it was particularly horrific tonight in the lashing rain. It happens less when it's hot, but it was thrashed on the way home tonight, in a gear lower than usual, because it kept dying - It was certainly hot.
I'm inclined to think it's the TPS, possibly a bad or soaked connection to it, or it's on the way out. Before I go tearing into it, does anyone have any other ideas? ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine)
| jaffa90 |
 jaffa90 World Chat Champion
| ThatDippyTwat |
| Easy-X |
 Easy-X Super Spammer
| ThatDippyTwat |
| ThatDippyTwat |
 Posted: 19:21 - 18 Jan 2020 Post subject: |
| ThatDippyTwat wrote: | Fixed it .
Sprayed carb cleaner around the intake and no increase in revs. So I took the fairings off, which was a battle in and of itself, to look at the throttle body. There was a touch of slack in the throttle cable, so we adjusted that out, and it no longer dies on idle, or low throttle. The slack was really insignificant, but evidently enough that on the lower stop, it won't feed in enough fuel to idle. It still ticks over at about the same RPM, so we're calling it done unless it plays up again. We'll give it a run tomorrow to make sure. |
The throttle cable isn't supposed to be used to set the idle. It's supposed to have a bit of slack and if you raised the idle by adjusting it you probably now don't have any.
Check that it doesn't pick up revs when turning the bars lock to lock. ____________________ a.k.a 'Geri'
| ThatDippyTwat |
 Posted: 21:27 - 18 Jan 2020 Post subject: |
| Pete. wrote: | The throttle cable isn't supposed to be used to set the idle. It's supposed to have a bit of slack and if you raised the idle by adjusting it you probably now don't have any.
Check that it doesn't pick up revs when turning the bars lock to lock. |
I'm aware it isn't, and I did check (MOT fail if it does), it doesn't change revs at all when moving bars. At the end of the day, it's a work hack, it just needs to get me to work, reliably. The idle wasn't raised enough to be noticeable by anything other than it not cutting out. It's still at 1500 cold, 1200 warm, which it was when I got it a few months ago.
It appears to have done the trick, and I'm happy with it. If I need to, I'll adjust the lower stop, but that's tank cover, tank and all the other bullshit coming off to get to it, and it's fucking freezing at this time of year, so it can wait. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
The last post was made 6 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
