CB125R Swing arm nut bolt problem
hume
PostPosted: 14:07 - 19 Jan 2020    Post subject: CB125R Swing arm nut bolt problem Reply with quote
I'm in the process of cleaning the chain and removing the chain slack. I've brought a ratchet and 24mm socket for the nut bolt but when I use it the bolt doesn't budge at all. The socket fits the bolt, although the bolt appears as if it's part of the steel casing it's resting on.
My question is how do I loosen the swingarm bolts?
PostPosted: 14:26 - 19 Jan 2020    Post subject: Reply with quote
Do you mean the wheel spindle? If so, un-do the nut, not the bolt. This applies to all nut and bolt fasteners not just your spindle. Make sure you're turning it anti-clockwise when viewed from the end. If it's too tight to move - try harder!
Nobby the Bastard
Harley Gaydar
PostPosted: 14:48 - 19 Jan 2020    Post subject: Reply with quote
Are you trying to undo it in the wrong direction.?
Righty tighty, lefty loosy.
Triumph Sprint ST 1050
hume
PostPosted: 14:55 - 19 Jan 2020    Post subject: Reply with quote
Thanks Pete. You were right, a bit more welly was needed.
Both nut and bolt have given way.
The last post was made 6 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 39.56 Kb
