| TheGazWaz |
 TheGazWaz Nitrous Nuisance
 Posted: 18:43 - 24 Jan 2020 Post subject: ZX9R Sticking gears - C2 (1999) 19k |
Hi everyone. Really concerned about this. The problem started this morning on my way to work.
Basically the bike will go up through the gears fine but intermittently doesn't want to shift back down. It's like instead of a gear shift there's a space on the lever.
So I'm in 5th gear, approaching a roundabout, 50mph, Drop down to 4th, 40mph, go to drop down to 3rd. nothing but a space. I keep pressing, clutching in and out but it just won;t go. Selects up fine and back down to 4th. Finally gets 3rd and does the same thing until I finally get second by which time I'm at the side of the road waving people past while frantically trying to get first.
Any ideas guys. I'm pretty desperate here. The bike has never missed a beat. It never slips out of gear. The engine sounds fine. No grinding when in gears. When I pull away it will be fine for a while then it does it again.
Please help
Gary ____________________ Went like this.. 43 years old(2013) decided to do CBT to get a 125 for new job. Bought 2011 YBR, loved it for three months then hated it because it was too god damn slow. Did DAS 4 months later then bought RF600 Loved it, sold it bought Bandit 1200(K3). EFFIN lOVED IT. Wanted something a bit more sporty so got Triumph Sprint ST 955i (53). Not sporty enough so now on my GSXR 1000 K3 and absolutely love it. 1 year down the line, nearly died way too many times on this bike. Sold it. Had a 6 month break. Missed biking so now, Aug 2019 have a 1999 ZX9r. What a beauty she is too. |
| Bhud |
 Bhud World Chat Champion
 Posted: 18:56 - 24 Jan 2020 Post subject: |
Interesting problem. I did a quick Google search, and apparently others have reported similar issues. This web page is interesting:
https://www.ksrc-au.com/html/fixing_a_zx9r_gearbox.html
And there are a lot of other reports on the web to read.
From the sounds of it, all other things being good, you will need to remove the engine and split the cases to see what's wrong. |
| stevo as b4 |
| TheGazWaz |
| stinkwheel |
 Posted: 21:24 - 24 Jan 2020 Post subject: |
I just looked and they have a similar gear selector shaft pawl to a GPZ500. I've had two of these fail in the way you describe. it has a couple of hooks on a bit of flat plate on small bendy springs that grab the selector drum and rotate it. if the hooks wear round, it doesn't always grab the next notch on the drum.
Beore you do anything though, make sure you are taking your foot totally off the lever before going for the next shift. You wouldn't be the first person to have a gearshift problem that was their new boots making them leave their toe on the lever (do you have new boots?).
On a GpZ, the selector is under a cover of its own behind the front sprocket and you can wiggle it out with the engine in the frame. No idea about a ZX9R though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| DJP |
 DJP Crazy Courier
| 1198 |
 1198 World Chat Champion
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
 Posted: 10:41 - 25 Jan 2020 Post subject: |
The issue is well-known and potentially very easy to cure. It is usually NOT the gear box and may be down to this:
https://i.postimg.cc/0ywddfBp/zx9-gear-change-peg-recess.jpg
There are stories of entire gearboxes being replaced and the problem remaining - until eventually being chased down to that one peg.
In short I think there is room for cautious optimism.
Go here for more information on this and other aspects of the C2:
https://www.zx-9r.net/viewtopic.php?f=48&t=22019
NB you may need to join that website in order to access the relevant content - but if you're running a nine it's invaluable and there are still a fair few active and very knowledgeable owners there, even though the bike is now about 20 years old. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
| TheGazWaz |
| Sister Sledge |
 Sister Sledge World Chat Champion
| TheGazWaz |
| Bhud |
The last post was made 6 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
