| chaza |
 chaza Nova Slayer
| Nobby the Bastard |
 Posted: 15:07 - 26 Jan 2020 Post subject: Re: Amp meter install |
| chaza wrote: | What intend to do is installed, the meter on between the fused wire from the battery I think it goes to the ign sw, is that correct.
Kind of.
You need to be mindful of where the charging output from the reg/rec enters the circuit.
If you want the ammeter to show charge/discharge, the reg/rec feed needs to be on the "bike" side of the ammeter, not the "batttery" side.
It's quite common for the charging input to connect at the starter solenoid at which point you need to start re-jigging the wiring.
Looking at a really small and shitty wiring diagram for your bike. It seems like the regulator output connects to the fuse holder itself. If you find that fuse holder, I think there will be two wires on the "bike" side of it. Your ammeter needs to connect between the fuse and these two wires.
I would say the easiest way to do this is to connect the ammeter in that wire going to the ignition switch like you propose. Disconnect the wire going into the fuse holder from the regulator and run a new length of wire from the regulator up to the "bike" side of the ammeter.
What I think you have is on the left. What you want is on the right.
https://www.bikechatforums.com/download.php?id=103078
EDIT: As above, this is for am AMMETER. Which will measure both the quantity and direction of current in your charging system. Not often used but probably the best way to monitor your charging system, the needle will swing one way if the battery is charging and the other way if it's discharging. If you connect a VOLTMETER like this, it'll go bang. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Polarbear |
 Polarbear Super Spammer
| JackButler |
 JackButler Traffic Copper
| steve the grease |
 Posted: 18:17 - 26 Jan 2020 Post subject: |
Go full house... ____________________ a.k.a 'Geri'
| Polarbear |
| Nobby the Bastard |
| chaza |
 chaza Nova Slayer
 Posted: 22:04 - 26 Jan 2020 Post subject: |
I find them really useful. As above, it tells you if your charging system is keeping up with the loss. it will tell you if your regulator has failed (either over or undercharging). You can test the lights (needle dips when turned on) and if you have points ignition, it tells you the exact point where the points start to open and is a useful guide for where to place the engine for kick-starting. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Polarbear |
| G |
 G The Voice of Reason
| WD Forte |
 WD Forte World Chat Champion
| chaza |
 chaza Nova Slayer
| WD Forte |
| chaza |
 chaza Nova Slayer
The last post was made 6 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
