YBR-125 clutch slipping?
whatwouldluke...
PostPosted: 12:10 - 27 Jan 2020    Post subject: YBR-125 clutch slipping? Reply with quote
Hi all,
Anyone know if this is a sign of a clutch slipping and possibly needing new plates?
When i'm moving along (example in 4th gear) and i either come to a bit of a hill or need to overtake someone going a little bit under the speed limit, i pull in the clutch, drop a gear and then the engine seems to rev a bit before the selected gear seems to engage properly (like a good second or two after releasing the clutch).
My clutch cable is adjusted correctly and its only started doing it in the past couple weeks.
I'm fairly decent with a set of spanners and make sure to maintain my bike well, but as it's my only transport i'd just like a second opinion before opening the case up and looking inside (i work nights and don't have a garage so i'm limited to what time i can do any work).
Cheers.
Current: Yamaha YBR-125ED 2010.
Previous: Honda CG125ES 2006.
Easy-X
PostPosted: 12:21 - 27 Jan 2020    Post subject: Reply with quote
How many miles on the bike?
whatwouldluke...
PostPosted: 12:27 - 27 Jan 2020    Post subject: Reply with quote
Just over 19,000 Miles.
I've Done 5,000 since i bought it January 2019.
Riejufixing
PostPosted: 13:27 - 27 Jan 2020    Post subject: Reply with quote
Recent oil change?
whatwouldluke...
PostPosted: 13:32 - 27 Jan 2020    Post subject: Reply with quote
About 300 miles since last changed, i normally do it around every 1000 miles.
Riejufixing
PostPosted: 13:36 - 27 Jan 2020    Post subject: Reply with quote
whatwouldlukedo wrote:
About 300 miles since (oil) last changed, i normally do it around every 1000 miles.
https://www.manualslib.com/manual/612290/Yamaha-Ybr125-Custom.html?page=42#manual
Same engine? Same oil spec?
whatwouldluke...
PostPosted: 13:42 - 27 Jan 2020    Post subject: Reply with quote
pretty much, that page is for the custom but i think its the same engine.
i usually use either Halfords own brand motorbike 10-40 or castrols version (if its on offer), never had a problem with either before (they are both to the same spec as is in the haynes manual)
Riejufixing
PostPosted: 14:01 - 27 Jan 2020    Post subject: Reply with quote
There's loads of info out there, this might be interesting: https://ybr125owner.blogspot.com/2014/08/yamaha-ybr-125-clutch-problems.html (you could get the cover off & have a look, make sure you don't knacker the gasket, or have another available).
Teflon-Mike
tl;dr
PostPosted: 14:28 - 27 Jan 2020    Post subject: Reply with quote
See:- HOW2: Overhaul Clutch (Small Honda's +)
Its a different bike, but it's much the same job.
It does 'sound' like the plates are cream-krackered, but? 125's do tend to get rather sorely abused by Learners, learning gears and slkipping the clutch a lot, cables get stretched, and plates 'can' wear out, though probably more common is cluster chuck of 'things' like practicing pull-away, finding the biting point, plus crap mechanics and lack-luster oil changes, oft with the wrong' oil, and far too common these days, 'car' oil, that contains friction reducing additives, that never should come in contact with devices that actually rely on friction to work, like clutches....
For the faff, I would bite the bullet, and replace the clutch plates AND springs, if one is shot other wont be far behind; flush the engine oil, thoroughly, and fit a new clutch cable. The bits shouldn't cost an arm and a leg, and once done you should have plenty of confidence its 'good'.
Just get the bits, get a Haynes manual, and go for it. And get on with it.
Its not an enormous job, is very satisfying, doesn't demand a fully equipped workshop, or necessarily any special tools.. though DO check, as the How2 for the little Hondas they do beg a special castilated socket that in the example I spent longer making than doing the job it was for, and having the proper tool (I later bought!) needn't be exorbitantly expensive and CAN make the job oh-so-much easier and quicker to get done.
Riejufixing
PostPosted: 14:49 - 27 Jan 2020    Post subject: Reply with quote
Teflon-Mike wrote:
(don't) necessarily any special tools.. though DO check, as the How2 for the little Hondas they do beg a special castilated socket
If he's just looking at or replacing the plates he won't need that.
WD Forte
PostPosted: 16:02 - 27 Jan 2020    Post subject: Reply with quote
Sounds like classic worn clutch symptoms
but test the cable and actuator arm for stiffness
Plates springs etc easily found on Ebay
I've done it a few times and its pretty painless
best have a new gasket to hand though.( Ebay again)
you can check/clean the oil strainer while yer in there
Tip:
Make a note of the bolts and where they come from
as some are a bit longer than others
I had to helicoil a couple of case threads on a low mile ybr engine where some numpty tried to force
the longer bolts in the shorter holes recently and snapped the bolts off
You can do it without removing the exhaust and just backing the rear brake adjuster off
so the pedal can be tied down out of the way
bikers smell of wee
PostPosted: 16:47 - 27 Jan 2020    Post subject: Reply with quote
Nothing to add except it's an easy job if you have a manual. (I by far prefer a paper manual than an electronic version when working on a vehicle.)
Get the bits. Make sure you have the tools and a manual and spend a happy Saturday in the garage. Thumbs Up
Triumph Trophy Launch Edition
whatwouldluke...
PostPosted: 16:56 - 27 Jan 2020    Post subject: Reply with quote
Cheers guy,
I'll get the bits ordered and give an update in couple weeks when i get time to do it. Smile
Riejufixing
PostPosted: 18:30 - 27 Jan 2020    Post subject: Reply with quote
Cheers guy,
I should get a gasket just in case, and look at the thing first. You don't know what the exact problem is!
The last post was made 6 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 81.46 Kb
