Author |
Riejufixing |
 Riejufixing World Chat Champion
 Posted: 17:11 - 27 Jan 2020 Post subject: |
They're very like the 3M ones. Hm. How much biking can be done underwater  |
Back to top |
Nobby the Bastard |
Back to top |
trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
 Posted: 09:23 - 28 Jan 2020 Post subject: |
Riejufixing wrote: | They're very like the 3M ones. Hm. How much biking can be done underwater  |
Not sure if you're referring to the ones I linked to, but if so, they're not really like the 3M ones at all. Most obviously in relation to the material - the 3M ones are foam and those I was on about are silicon. Regardless, there are two problems (even though I do rate them) - firstly, you have to moisten them with a bit of gob. Aside from being a bit gross, it's another step - another faff before you can set off, etc. Secondly, with repeated use, you're likely to get a build up of wax and get pretty deaf (because when you put them in, you poke the wax deeper inside - but also, this starts to happen more regularly, for some unknown reason). I've a feeling but no proof that this is worse when using silicon type ear plugs. That said, it actually is - like you implied - having your head underwater! So in that sense they work really well. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
Back to top |
seeyalater |
 seeyalater Trackday Trickster
 Posted: 09:29 - 28 Jan 2020 Post subject: |
trevor saxe-coburg-gotha wrote: | Riejufixing wrote: | They're very like the 3M ones. Hm. How much biking can be done underwater  |
Not sure if you're referring to the ones I linked to, but if so, they're not really like the 3M ones at all. Most obviously in relation to the material - the 3M ones are foam and those I was on about are silicon. Regardless, there are two problems (even though I do rate them) - firstly, you have to moisten them with a bit of gob. Aside from being a bit gross, it's another step - another faff before you can set off, etc. Secondly, with repeated use, you're likely to get a build up of wax and get pretty deaf (because when you put them in, you poke the wax deeper inside - but also, this starts to happen more regularly, for some unknown reason). I've a feeling but no proof that this is worse when using silicon type ear plugs. That said, it actually is - like you implied - having your head underwater! So in that sense they work really well. |
I wonder if the foam are better due to absorbing some wax? was thinking about your point other day, pushing wax in etc. |
Back to top |
Back to top |
seeyalater |
Back to top |
Riejufixing |
Back to top |
 Posted: 14:59 - 28 Jan 2020 Post subject: |
I was looking at the 3M ones posted 9 posts before mine, which do seem to be of the foam type -
https://www.amazon.co.uk/3M-1100-Earplugs-Uncorded-Pairs/dp/B000J6BK04
But yeah - the ones you linked to are the 'same' as mine. For the money, they're excellent. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Back to top |
The last post was made 5 years, 269 days ago. Instead of replying here, would creating a new thread be more useful? |
