Reiju MRT 50 cut out now wont start
Griifin29
PostPosted: 16:27 - 29 Jan 2020    Post subject: Reiju MRT 50 cut out now wont start Reply with quote
Hi Folks, should be simple but I'm stuck. My son's MRT 50 (2015) was going along perfectly when it just cut out and died. He said it didn't splutter like when it ran out of petrol once, he said it just quickly stopped running.
Not seized and you can operate kick start. Wont bump start and shows no sign of life.
Not long ago we changed the spark plug and the HT lead cap (turns out the cap was missing the clip that makes a secure contact with the plug top so kept cutting out).
Plug isn't oily or worn, looks normal to me. Sparks when you kick it over.
The bike has no battery (I find that really weird these days) but when kicked the lights all come on momentarily.
Full tank of new fuel (well about 10 miles in), definitely in on position. Would have thought it would splutter or backfire etc if fuel not getting through.
Don't know anything about these little bikes so any help appreciated, he uses it for communting to his apprenticeship so needs fixing asap. I have managed to get it transported home so looking forward to some tips.
Many thanks
McHattrick
PostPosted: 17:55 - 29 Jan 2020    Post subject: Reply with quote
My son also has an MRT 50, same age.
It's been a bitch to start, but haven't had any probs with it cutting out.
I know our problem is fuel starvation. I think the carb float sticks. A good bit of tapping usually resolves problem. Long term answer is probably strip it down and clean it.
If you have good spark, then check carb/fuel.
If it aint broke... fix 'til it is.
jaffa90
PostPosted: 18:08 - 29 Jan 2020    Post subject: Reply with quote
Try kick starting a few times with full choke & throttle and see if the plug is wet with fuel.
"""Sparks when you kick it over."""
Can you here the spark and is it blueish?
Griifin29
PostPosted: 23:09 - 29 Jan 2020    Post subject: Reply with quote
Thanks guys, it usually starts first or second kick.
So if I kick it over a few times and the spark plug isn't wet then suggest fuel ? is that right ? Suprised it didn't splutter but maybe he didn't realise.
When I got to him at the side of the road he'd tried it for a good while and I tried about 10-15 kicks I guess. Spark plug was pretty dry when I removed to check for a spark.
Spark looked to be pretty strong couldn't really tell colour.
McHattrick - have you tracked down a manual of some description, I know wanting good old Haynes is unlikely but ......
jaffa90
PostPosted: 02:02 - 30 Jan 2020    Post subject: Reply with quote
Ok, so can you removed the fuel pipe at the carb and see if fuel is peeing out with tap ON ?
McHattrick
PostPosted: 16:28 - 30 Jan 2020    Post subject: Reply with quote
Here are links to Owner manual and Workshop manual
https://www.manualslib.com/manual/1079411/Rieju-Mrt-50.html
https://www.manualslib.com/manual/1088567/Rieju-Mrt-50.html?page=2#manual
There isn't really much help there in Troubleshooting but page 40 on Workshop shows where the Fuel/Oil is mixed and how to access the carb.
I resolve our fuel prob by switching off fuel, kicking over for a while, light taps on side of carb (hoping to un-stick float) and fuel on again.
Sometimes works straight away, sometimes takes a bit of perseverence.
However you may have a different issue.
Good Luck.
Griifin29
PostPosted: 14:18 - 31 Jan 2020    Post subject: Reply with quote
Checked fuel , took pipe off before fuel filter - yep, after fuel filter -yep, into carb yep.
Decided to take carb off (didn't see the manual link !), all looked really clean and no sticking with float as far as I can tell. Put it back together, unscrewed the drain plug thing on the carb and fuel poured out.
Checked spark plug again as in garage now not outside so can see better, looks good and blue. Quite anew plug so not really any colour, not at all wet.
Annoyed at myself for not knowing what to do now Sad Appreciate any other ideas before I get it taken somewhere.
Griifin29
PostPosted: 14:19 - 31 Jan 2020    Post subject: Reply with quote
Good Luck.
Thanks, as per other comment cant see any sticking in carb, thanks for the links.
jaffa90
PostPosted: 19:02 - 31 Jan 2020    Post subject: Reply with quote
Next to try is easy start spray or carb cleaner spray or volatile spray into the inlet manifold with air filter removed and choke off and then kick start with throttle.
McHattrick
PostPosted: 15:50 - 01 Feb 2020    Post subject: Reply with quote
Checked spark plug... not at all wet.
You have good spark and plenty fuel getting to carb?
So no fuel getting through to engine maybe suggest prob with reed valve.
I am not an expert on 2T but I guess if reed valve is stuck open then there is no compression to force fuel into cylinder.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:01 - 01 Feb 2020    Post subject: Reply with quote
A reed valve can't really get stuck open. If its put in backwards it will be kept closed but the bike was working before so it's not that.
Potentially the leaves of the valve could snap off but that's unusual.
Triumph Sprint ST 1050
Griifin29
PostPosted: 13:26 - 04 Feb 2020    Post subject: Reply with quote
Just tried easystart - that stuff stinks Smile Sadly nothing, not even an attempt to fire. Wondering about piston rings/barrel now ?
jaffa90
PostPosted: 13:42 - 04 Feb 2020    Post subject: Reply with quote
Well if you have a good spark and you have introduced fuel into the air intake manifold then it`s a compression / suction test.
Easy-X
PostPosted: 14:42 - 04 Feb 2020    Post subject: Reply with quote
This is not hard stuff Smile
Take out spark plug, put thumb over hole, attempt to start engine. Is there any pressure pushing against your thumb?
Nobby the Bastard
Harley Gaydar
PostPosted: 18:09 - 04 Feb 2020    Post subject: Reply with quote
You cant test compression like that.at best you would be able to hold back about 4 psi with your finger when you would need to measure in excess of 100 psi.
Easy-X
PostPosted: 21:55 - 04 Feb 2020    Post subject: Reply with quote
If I need that much thumb pressure I get my wife to do it Laughing
Griifin29
PostPosted: 17:08 - 05 Feb 2020    Post subject: Reply with quote
Thanks for the help folks, the comment 'this is not hard stuff' well yep I agree but nothing is hard when you know how to do it.
Decided to take cylinder head and barrel off, looks liek one of the piston rings is welded to the piston and the barrel is scored.
So I've found that problem, I guess before replacing I need to look at why but as no water came out of the water pipes I'm guessing the radiator was empty through neglect or from a leak so will ne looking at that first.
Easy-X
PostPosted: 17:18 - 05 Feb 2020    Post subject: Reply with quote
Nobody likes to get their ring damaged Shocked
Lack of coolant wouldn't help, certainly, but is/was it getting oil?
The last post was made 6 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.15 - MySQL Queries: 13 - Page Size: 97.86 Kb
