VFR800 in a merc e class estate - can it be done?
lynnnsr
PostPosted: 21:48 - 29 Jan 2020    Post subject: VFR800 in a merc e class estate - can it be done? Reply with quote
What do we reckon?
Thinking about the practicalities only, is this feasible over quite a long distance without causing damage to the bike?
Going to look at one over the weekend which is 150 miles away
NSR 125 (with L-Plates) > 1994 NTV 650 > 2015 CB650F > 16 VFR800F
doggone
PostPosted: 22:09 - 29 Jan 2020    Post subject: Reply with quote
At worst it would probably go in with one or both wheels off, you might have to remove the tank and lie it on a side on a quilt or something.
Riejufixing
PostPosted: 22:18 - 29 Jan 2020    Post subject: Re: VFR800 in a merc e class estate - can it be done? Reply with quote
lynnnsr wrote:
What do we reckon?
Specs say Length 2,120 mm / 83 in Width 735 mm / 28.9 in Height 1,195 mm / 47.0 in.
Put it on its side (you will need hands) or perhaps hire a van.
Vracktal
PostPosted: 23:08 - 29 Jan 2020    Post subject: Reply with quote
If I were to do this i'd drain the petrol, oil and coolant first, remove the fairings on the side you're laying it on and put down some kind of buffer between the frame and the boot floor. The main risk is things like the shift lever or switchgear getting bent so if you can prop the frame up with blocks of wood or something that would help.
On paper a VFR has a dry weight of around 200kg against a max boot weight capacity of a common-or-garden E class at 500+kg so should be fine in that regard.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
lynnnsr
PostPosted: 23:11 - 29 Jan 2020    Post subject: Reply with quote
Sounds feasible if not entirely practical.
Ah what could possibly go wrong, I'll be sure to post pics...
PostPosted: 00:07 - 30 Jan 2020    Post subject: Reply with quote
If you can't ride it back, presuming you are going to buy it, surely a hire van is the way to go.
Triumph Trophy Launch Edition
Riejufixing
PostPosted: 00:13 - 30 Jan 2020    Post subject: Reply with quote
I suspect your main problem would be getting it into the back of the vehickle, and getting it out. You would not want to damage the bike.
PostPosted: 00:24 - 30 Jan 2020    Post subject: Reply with quote
They are heavy fuckers. Most of it's engine so there are a limited number of pieces you can take off to make it lighter.
Lifitng it in is going to be the issue.
Radiators are side mounted. Be vulnerable if it's laid down withthe plastics off. Might be safer to drain and remove them... but you'll be giving it a full service anyway??
FretGrinder
PostPosted: 00:28 - 30 Jan 2020    Post subject: Reply with quote
Or just hire a small van for the day Thumbs Up
Yamaha MT-09
ಠ_ಠ
kgm
PostPosted: 00:31 - 30 Jan 2020    Post subject: Reply with quote
Way more hassle than it's worth IMO. You'd need to strip off the fairings, rads and a few other bits which would be a pain to begin with and then supporting the weight of the thing sideways from the inside of the car will be a nightmare.
I did fit a cg125 partially disassembled into a Hyundai i3o once but even that was a pain
ThatDippyTwat
PostPosted: 06:06 - 30 Jan 2020    Post subject: Reply with quote
So much this.
Just hire, beg or borrow a van, pay for a bike courier blag a mate to help.
PostPosted: 08:49 - 30 Jan 2020    Post subject: Reply with quote
I've got a VFR, and an estate car.
I wouldn't. Side mounted radiators, engine made of depleted uranium, complex braking systems, not particularly heavy wheels.
Hire a van for petes sake, or ride it. You'll end up spending more on scratch repairs to the bike and car than you will on van hire, and that's not including radiator damage to the bike etc.
When I picked up my VFR I couldn't believe how heavy it was just to lift off the stand, let alone to lift it off of the floor.
If it were a GSXR600 or something I'd say sure give it a go, but a VFR is a heavy beast with lots of spiky and critical bits that would need to be removed. Don't do it.
yen_powell
PostPosted: 09:41 - 30 Jan 2020    Post subject: Reply with quote
I'd take someone with me who can drive your car back legally if you buy it and then you can ride it home.
XT1200Z and a DR350 in bits
Sister Sledge
PostPosted: 10:09 - 30 Jan 2020    Post subject: Reply with quote
If it does all go in it's a bit of a risk in a crash..
CCM 404 DS
Easy-X
PostPosted: 12:20 - 30 Jan 2020    Post subject: Reply with quote
I think we need reasons why you can't ride it and reasons why you can't hire a van or trailer.
A100man
PostPosted: 13:24 - 30 Jan 2020    Post subject: Reply with quote
The biggest bike I've transported in a car (apart from my basket-case XJ550) was Honda-ish Dax inside a Berlingo - which is nearly a van anyway... That was about half the weight of a VFR or less.
Like all the above I would say the cons massively out weight the pros and it would very much be a course of last resort..
adam277
PostPosted: 13:58 - 30 Jan 2020    Post subject: Reply with quote
Stick it on the roof. Problem Solved.
Bikes: Previous Bikes: Piaggio x8 125: 2012/2013, YBR 125: 2013/2013 BMW R1150GS 2013/2017, Honda CBR600RR 2017/2017, Honda CB500 2018/2018, Suzuiki Address 110cc 2019/2020, BMW R1200GS 2021-2023
Current Bike: Honda CBF 125: current
pepperami
PostPosted: 15:08 - 30 Jan 2020    Post subject: Reply with quote
If it’s to big in one piece, cut it up with an angle grinder.... bet it’ll fit now!
Or go and buy a cheaper bike so you can afford to hire a van for the day you cheapskate!
Once again Pepperami offers sage advice to solve a problem, you’re welcome. Thumbs Up
adam277
PostPosted: 15:26 - 30 Jan 2020    Post subject: Reply with quote
pepperami wrote:
If it’s to big in one piece, cut it up with an angle grinder.... bet it’ll fit now!Thumbs Up
Are you talking from experience?
If so I believe I have brought one of your bikes before.
Next time make sure the bike is straight before welding it back up. Felt like I was riding sideways.
pepperami
PostPosted: 15:31 - 30 Jan 2020    Post subject: Reply with quote
Smile give me a bike, any bike and I can ruin it for you....... bespoke fuckwittery is my specialty Thumbs Up
WD Forte
PostPosted: 15:50 - 30 Jan 2020    Post subject: Reply with quote
Bad idea IMO
E class may have a large cargo area and the weight wont kill it
but that area is low so you'd have to strip the bike down and hope you dont bugger it up in the process.
By the time you've done all that faffing about dismantling and loading you could have ridden it home.
Van/Trailer/Mate or bike courier company
what locations are we talking about?
bikers smell of wee
1198
PostPosted: 16:25 - 30 Jan 2020    Post subject: Reply with quote
Video to post on YouTube - or you’ve been framed! Hell, that way you’ll get £250 that can be used towards the repairs to car and bike!
Just hire a van...
1198
PostPosted: 16:28 - 30 Jan 2020    Post subject: Reply with quote
Unless it’s a bike you’re getting for spares anyhow? I’ve bought a bike, turned up with an Estate car and tools and carefully removed enough components to make it fit - that was only an air cooled 125 though!
PostPosted: 16:37 - 30 Jan 2020    Post subject: Reply with quote
If you have breakdown cover that covers you on any vehicle then be extra careful not to lose the keys for the new bike because then you would have to call the breakdown people who would then come and recover you and the bike to your home address. Wink
Riejufixing
PostPosted: 16:47 - 30 Jan 2020    Post subject: Reply with quote
OH!
The last post was made 6 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.29 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 125.73 Kb
