| chaza |
 chaza Nova Slayer
| Nobby the Bastard |
| chaza |
 chaza Nova Slayer
| Nobby the Bastard |
| chaza |
 chaza Nova Slayer
| Teflon-Mike |
 Posted: 01:03 - 31 Jan 2020 Post subject: |
Raptor uses a derivative of the Honda CB/CM/CD engine.
The carbs were balanced last summer? How many miles ago was that? [patient shrug] And how the heck do you 'balence' a single carb?!?!?! What do you balence it to?
Oh-Kay... first up, these motors are wont to fire up on just one pot, then have the other cut in once the motor starts to get warm, especially if they are a bit tired.
Raptor, on carbs.... this is not a very new bike... ISTR that they went efi around a decade ago... s-o-o.. my 'bet' is that the thing is has either done a lot of miles, and/or spent a lot of it's life laid up unused.
Pretty good odds that the cylinder bore/piston rings are knackered, or at least past their best.
These engines have diddy cylinders, OTMH 42mm stroke, 43mm bore, barely big enough to fit a spark-plug over! (In fact, it's the same plug as a Honda 'Cub' moped, and Honda had to get I think it was Champion to develop that specially to be able to make a four-stroke engine that small, to get plug and valves in the cylinder head!). Any-how... they don't like worn bores or weak piston rings. A-n-d, wings go 'weak' on laid up bikes as they gum up in the piston grooves, and the 'wear' on the bore at high miles that sees them start to play up is almost imperceptible...
You mention smoke on the left pipe... is that as you look at the back of the bike? That'll be the side-stand side... and from memory, the raptor has no centre stand.... so... bike sits on side stand, leaning to the left, oil in the rocker cover settles at the lowest points inside, and on start up, is puddled around the left hand side valve guide... Engine sucks-squash-bang-blow, and oil puddled around the valve guide is as want to get sucked into the cylinder as charge through the carb, gets burned, makes more smoke on that side exhaust....
S-O.....
Suggestion is that you have a tired old engine, sucking oil down the valve guides, and the ultimate answer is that it needs reconditioning...
See handy How2's in profile; it costs about £130 for a new cylinder and piston kit for these things; and whilst in there, and you have the head off, get the valves out, lap them to their seats, and replace the stem-seals.... eliminates the piston ring issue and remedies the valve stem seal 'problem'... but it might be worth getting a block of wood to prop the kick-stand to hold the bike more vertically when left over night or longer.
Whilst you are at it, get the proper tappet tools (I think the part no's for them are in one of the How2's, and they are only about £15 the pair) for adjusting valve clearances, which you will have to do on rebuild, and every 15oo miles or so there-after as routine maintenance.. good odds they have never been done or done properly, a) 'cos its a 125 and little is ever done to them until they stop working and b) 'Cos it's a Chinky 125, worse still, an chinky AJS that have about as much service support as a one legged man who's had his crutches stolen!
'Bubbling' around the rocker cover... that suggests excess crank-case pressure, which would be caused by worn rings, and more indication engine really needs a top end rebuild.... but, also suggests that 'maybe' some-one might have tried tackle the routine maintenence of the valve clearance adjustment at some point... only trouble is that the rocker cover 'seal' is rather prone to not sitting properly in the rocker cover rebate, and or getting skewed when cover refitted... it's a bit of a fiddle to get the cover off, over the rocker-bosses, under the frame top tube, making more ham-fisted mechanics a bit more problematic/likely.... but 'should' be remidied by that top end rebuild.... and some patience and diligence when you do them tappet tickles... hint, remove the petrol tank, completely!
OR.. you just live with it as is, on the basis that a top-end rebuild is too expensive and difficult, so until it stops working all together. avoid and tickle bits round the outside, in vein hope it will make up some defacit....
That's your call... and only you can make it B~U~T....
Personally, i would NOT waste my time trying to mugger about with another Raptor.. I do mugger about with genuine Honda's, though. a) because at least the CB varient offers a genuine 70mph for it, and is quite a nice bike to ride, and b) resale value of the bike after stands some chance of being worth the quids sunk into it... but like I said, its your call... but sysmptoms indicate a tired old engine, that is likely in need of a top end overhaul.... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| WD Forte |
 WD Forte World Chat Champion
 Posted: 01:13 - 31 Jan 2020 Post subject: |
Bobby the Bastard  ____________________ bikers smell of wee |
| jaffa90 |
 jaffa90 World Chat Champion
| Sister Sledge |
| Nobby the Bastard |
| chaza |
 chaza Nova Slayer
| WD Forte |
| chaza |
 chaza Nova Slayer
| trevor saxe-coburg-gotha |
| Nobby the Bastard |
| chaza |
 chaza Nova Slayer
| Nobby the Bastard |
| chaza |
 chaza Nova Slayer
| Skudd |
 Skudd Super Spammer
| chaza |
 chaza Nova Slayer
| chaza |
 chaza Nova Slayer
| Teflon-Mike |
 Posted: 15:26 - 03 Feb 2020 Post subject: |
The crank-vase vents from a hole om the top of the crank-casee half castings, from memory, just behind the carb(s). The actual vent, has a labrathyth seal, a maze of bafles basicaly, cast into each crank-case half to catch xs oil before it leaves, then theres a short 1/2" pipe on the top of the cranki-case for the vent pipe top attach.
The AJS engine is made on sub-contract, and AJS have over the years mixed and matched bits from the Honda parts catalogue and their own revisions, B~U~T as it's in the die of the crank-cases, I very much dount that they have changed the labaryth arrangement. And there would be little reason for them to blank off the vent, which would need to be plugged.
On the Honda's the vent pipe from the cranbk-case, either vents via a rubber hose, over the back of the gearbox, to between the rear engine mount plates, with the carb-over-flow pipes, or its closed looped back into the air-box so that any spent vapour gets burned in the cylinders.
Have a poke and a prod round that area see what you can find, look for hoses that are there, and more carefully for places ones may be missing.
On the CB's, common for the vent hose to be pinched between engine and frame, if the engine's ever been out, or to fall off of any-one has tried to feed old pipe into the gap between engine and frame, and given up, 'cos it don't fit!
I suspect on the Raptor the breather would be routed into the botom of the air-box; if so and if you have XS crank-case pressure, common if the engine oil has been over filled.. especially easy as bike has no centre stand so oil level checked on the side stand canted over top the left... XS oil blown out, into the air-box... and wow, check the presses.. you see smoke on start up when it gets sucked into the engine! (after clogging the air-filter!) And wow check them presses... bike leans to the left on the side stand, guess which side the XS oil settles in the air-box, and which side carb then sucks most oil and vapour into the pot to burn.......
| chaza |
 chaza Nova Slayer
| Nobby the Bastard |
| chaza |
 chaza Nova Slayer
The last post was made 6 years, 143 days ago. Instead of replying here, would creating a new thread be more useful? |
