Honda CG125 convert lamp to H4
mikimisz
PostPosted: 17:29 - 02 Feb 2020    Post subject: Honda CG125 convert lamp to H4 Reply with quote
Hi,
I made a dexission to switch headlight in my CG125 to new lamp with H4 to see anything at night.
Unfortunately I don't have access to bike at the moment. I'm looking for exact spec. to order good parts.
What I found it should be 7", my questions are about connector and size/dimensions of mounting braces. Does any one kows them or where to find them?
Greetings
Michał
PostPosted: 18:39 - 02 Feb 2020    Post subject: Reply with quote
What year/model of CG125?
Some of them wont be able to power an H4 bulb.
Assuming it can cope with one, If it's a 7" shell, you should be able to get a sealed beam insert for it quite cheaply that ought to fit in the existing shell.
mikimisz
PostPosted: 21:03 - 02 Feb 2020    Post subject: Reply with quote
Good point! Sorry, it is 2007 Honda CG125 ES7.
Can you show an example of sealed beam?
PostPosted: 01:36 - 03 Feb 2020    Post subject: Reply with quote
That one should cope. You may want to use a 35/35W H4 bulb so you don't overload the wiring.
Just search on ebay for 7" H4 insert. They are held into the rim by funny W-shaped steel spring clips. I'd advise wearing goggles when fitting/removing these.
I'd say the only potential issue is clearance behind the unit. The reflector will be deeper than standard.
Here's a picture of one fitted in the chrome headlight rim of my enfield. The insert is the brown bit (which is glass). You can see the four spring clips, (poorly spaced out here I moved them later). I use a pair of needle nose pliers to put them in (bit of a fiddle to be fair, hook in one end, then bend the other end in.
https://lh3.googleusercontent.com/kvbvd8AXTd-kRnv-RyJ_1QszrN3WN9B_tT3zJKK-F6AY5arD81T4GvI9WgFkQU2RtZC7nQZesFoC0kimhaWc2_4rD1l5nujZPk5S8-5f1YS9Rnw-8MiUfxpOnHlZA1JbRlPvwCj10Q=w1155-h866-no
The other thing you'd need is a bulb holder (search H4 bulb holder) for the back of the bulb, you can buy them with flying wires attached, just fit terminals to attach it to the existing lighting terminals.
EDIT: don't get a neolite one. I was less than impressed with mine and replaced it with a lucas one.
mikimisz
PostPosted: 09:21 - 03 Feb 2020    Post subject: Reply with quote
Thanks!
Found one seller close to me, will go to fit once weather gets better!
mikimisz
PostPosted: 15:53 - 17 Feb 2020    Post subject: Reply with quote
Hi again.
So I found out a bit of an issue.
First, it is 5 3/4 in lamp, and I found some inserts, more or less they looks like that:
https://5.allegroimg.com/original/01e713/a9482d714b818a1201aaef716c35
And insert for my CG looks that:
https://thumbs.img-sprzedajemy.pl/1000x901c/af/09/51/reflektor-szklo-honda-cg-125-jawiszowice-522931732.jpg
It has dedicated mounting bracket with screws, and those universal has not. Any idea how to mount universal H4 insert to original lamp?
PostPosted: 16:31 - 17 Feb 2020    Post subject: Reply with quote
Odd that. I assumed it would be similar to the one on my Honda H100 (which uses those spring clips).
To be honest, I'm not sure, it's not how I was expecting it to be. Might be a case of replacing the entire headlamp and shell. Bit of a pain because most of the wiring runs through it.
The last post was made 6 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.72 - MySQL Queries: 13 - Page Size: 52.33 Kb
