CG125 (Copy) - What's This Bolt Hole For? (Generator Side)
NeonAqua
PostPosted: 18:17 - 02 Feb 2020    Post subject: CG125 (Copy) - What's This Bolt Hole For? (Generator Side) Reply with quote
The 1st photo shows you precisely what bolt hole I'm referring to.
The 2nd photo is a duplicate of the 1st (without blur).
The bolt hole is 1 inch deep (24mm)
What's this bolt hole for (or what part does it bolt to the engine)?
WD Forte
PostPosted: 18:35 - 02 Feb 2020    Post subject: Reply with quote
I'll have 50p each way bet its for bolting a 'stopper' to hold the rotor in place when removing/fitting the centre nut?
bikers smell of wee
baldy
PostPosted: 18:36 - 02 Feb 2020    Post subject: Reply with quote
It’s supposed to have a little bracket on it that holds the starter gear in place. (The big one behind the flywheel)
One day i will rule the world, just not today.
PostPosted: 18:37 - 02 Feb 2020    Post subject: Reply with quote
Pure guess but maybe for a crankcase splitter?
NeonAqua
PostPosted: 06:41 - 16 Feb 2020    Post subject: Reply with quote
"It’s supposed to have a little bracket on it that holds the starter gear in place. (The big one behind the flywheel)"
@Baldy this is exactly what a motorcycle mechanic also told me. But he said I do not need it, as it's not essential (some motorcycles of this sort were manufactured without this bracket).
The gear has a bit of space to move forward and backwards (without the bracket), but is held in place by the other components / parts.
I put the engine back together again (without the bracket) and it runs fine.
Thank you for all the help & replies!
The last post was made 6 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 42.81 Kb
