Yamaha YBR 125 Indicator Flasher / Relay
gwernybwch
PostPosted: 14:55 - 02 Feb 2020    Post subject: Yamaha YBR 125 Indicator Flasher / Relay Reply with quote
Come to ride the ole YBR125 after several months of it being parked up and the indicators aren't flashing. (Checked all four bulbs are working and enough battery power to start the bike)
Have taken off the relay and sprayed it with some WD40, when I turn the indicators on I have hear a sort of grinding / clicking noise for the relay.
Is this the type of noise that faulty relay makes? Or is it more likely faulty wiring?
Thanks in advance for any replies.
Easy-X
PostPosted: 17:29 - 02 Feb 2020    Post subject: Reply with quote
Relays cost feck all, just buy one Smile
WD Forte
PostPosted: 18:50 - 02 Feb 2020    Post subject: Reply with quote
Easy to test
Pull off the 2 way connector from the relay
Strip a small length of wire and push it into the connector
so the Brown and brown/White wires are linked
Turn on ignition and switch the flashers on and off both sides
If all blubs come on fully bright, buy new relay
bikers smell of wee
PostPosted: 18:56 - 02 Feb 2020    Post subject: Reply with quote
Just replace it.
Get 2 pin electronic one. Be around a fiver
The last post was made 6 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 4.44 - MySQL Queries: 13 - Page Size: 39.29 Kb
