| Easy-X |
 Easy-X Super Spammer
 Posted: 00:59 - 02 Feb 2020 Post subject: Musings on optimum power to weight ratios |
I'm just watching "Restoration of Everything" which is a nice soothing YouTube channel if you want to put your brain into neutral
My subconscious has a tendency to percolate ideas over a long period and it keeps noticing the same thing...
Let's take a generic bike, for example: standard steel tube frame, it can only be of roughly one size for a moderate spectrum of human sizes. Add to that all the legal requirements: lights, indicators, speedo, etc. and all the stuff to support them: battery, regulator, wiring loom. Comfort things like a seat. Standard controls and so on.
Obviously wheels would be nice along with brakes. What else?
Oh yeah! The engine
So what I'm saying is: there's a certain amount of "base weight" you have to have just to get started regardless of engine size. This is particularly acute for some models of 50cc road bikes and quite a lot of 125cc. You see a standard bike but one component sticks out as being undersized: the barrel. What drives it home is the fact the gearbox is almost always a "base size" across quite a range of engine capacities. (As a side note this seems a modern trend. Way back there was no problem making small barrel bikes with tiny 3-gear boxes.)
Going the other way, e.g. litre bikes, no problem - you just build bigger.
So the big question: what is the optimum before you have to build bigger? How powerful can you make a bike before you start making a seriously stronger gearbox, reinforce the frame, wack on 4 piston brake calipers?
tl;dr ^^This is what happens when you have a Saturday night without beer  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| pepperami |
 pepperami Super Spammer
| Easy-X |
| Teflon-Mike |
 Posted: 06:09 - 02 Feb 2020 Post subject: |
| Easy-X wrote: | The market seems to have coalesced around 250 & 450 (4-strokes) but from what I've seen - bear in mind I hardly know anything - is a 250 2-stroke rebarrelled to 300/320cc seems like the thing to do these days so just for the narrow subset of dirt bikes that might be the answer to my question. |
I'm not too sure what the question is now, but, as the last of the 2T 500 GP bikes and beyond were proving, its not so much the amount of power that's important, as the power delivery; hence modern power delicery modifying traction aids. They got those monsters up to over 500bhp per litre,and the weight down to around the 100Kg mark, where they were having to add ballast to meet minimum weight regs, and again, it wasn't so much the weight as the weight distribution, and GP teams spent a almost as much time testing the best ballast locations as they did tyres!
My 1981 Montesa Cota trials bike.... weighs about 70Kg, and makes just shy of 15bhp. Steel spine frame, and full street kit etc... that roughly sets your base line... it boasts 'Magnesio' on most of the major motor castingts, and 'Akront' on the wheel rims, fork-yokes, etc, and has no battery, no indicators, no pillion seat etc. And folling vogue of the era the frame was 'Majestied' and the bottom of the engine cradle abreviated to use the engine as a stressed member both to save weight and make ground clearance.
Development history reports that the engine was taken from the 'Impala' road bike, and is mostly the same as the Capra scramblers, so was made in a range of displacements from I think 150cc to 360cc, maybe a tad bigger, ISTR a Capra 440, made to go head to head with the Kawasaki KX and the BSA Victor, and Montesa had a habit of putting numbers in the model name actually rather bigger than the engine cc, b-u-t.... gives an idea, how much difference they can get by boring.... even on a one-pot motor. 248 and 349 'trials' variants, were essentially the same bike, with same quoted weight, the only difference being the size of pot over the block, the piston inside it, and the pant scheme. And again, power was not deemed as important as power-delivery, the 350, only claiming about 20bhp or so, to the 250's 15.
In the last 1/4 century, road bike weights have tended to hog out towards the 200-250Kg mark, that was the upper end of the demographic back when all we could get was cross-ply tyres.
A look at 125's new and old is revealing. My water-cooled Kawasaki AR125 thirty years ago had a claimed kerb weight of just about 100Kg.. with a steel spine frame, and all street gear, and most 125's weren#t a lot diferent. My DT for example had a claimed ke4rb weight of 95Kg I think, without water-cooling or fairings, a Cagiva Mito, with water cooling, fairings and an ali frame, claimed I think 140Kg... which is not a lot different to either Snowies old AJS cruiser thing 125 or her Goto-Muzzi 750.... more mention of that power delivery over peak power, I think.
I would 'say' that the optimal weight is probably around the 180-200Kg mark.... that's about what most can physically manage; and 'about' 75bhp ish, as that's enough to be exciting, and certainly more than they got from the old 250 strokers and 400 four-bangers, right up to things like the 883 Hardley, or 1000cc Goto-Muzzi, and hate to say it but the Suzuki SV650....
Ultimately, I think that the question is some-what perverse. Power is not proportional to engine cc, and it's not the power any way, but power delivery.... on weight, with or without street gear, the range is similarly enormouse, and the KR1S ISTR, had a claimed kerb weight in show-room spec of a mere 100Kg... they can get the power up, and the weight down to almost anything they want, what comes out though is how usable the resulted creation may be, and back to power delivery over peak power and weight distribution over shear weight..... and the summation is the 'nature' of the bike as a package, not it's vital statistics....
And from that, do you want something to chuck around the lanes, a race track, over the fields or a trials course, tour America or cross the Ghobi....
Its like trying to judge how sexi a woman is going to be by the numbers a beauty pageant judge yells out... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| wr6133 |
 wr6133 World Chat Champion
| JackButler |
 JackButler Traffic Copper
| Easy-X |
 Posted: 17:44 - 02 Feb 2020 Post subject: |
Sometimes you wonder whether to be silent and be thought a fool or hit "Submit" and remove all doubt
I think I probably had a mad idea that there was a "sweet spot" everyone was missing out. Obviously the guys at Honda, BMW, Yamaha, et al know a thing or two but laws and marketing trump all that.
Very interesting though, thanks guys  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| trevor saxe-coburg-gotha |
 Posted: 19:09 - 02 Feb 2020 Post subject: |
yeah interesting - i want to ask a related question but don't really know how to phrase it. It's about *where* is the best place for the weight to be. Take something basic like the now proverbial sv650. Next imagine that all the mass that isn't the frame and wheels + handle bars and forks, etc., could somehow be condensed down into a tiny volume about the size of a bike battery - where is the best place for that to be? Is it just above ground level at a point halfway between the front and back wheels? In other words, if it were possible to compress the engine and other sundry components into e.g. a cubic foot of mass, where should it be placed so that the bike can corner most efficiently i.e. with max stability?
Manufacturers talk about centralisation of mass and such like, but apparently it's important to distinguish between that and centre of gravity. I just found an interesting discussion about this, but it's mainly in relation to off-road bikes. Presumably different emphases apply to different uses a bike is designed for.
https://transmoto.com.au/explained-mass-centralisation/ ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
| Easy-X |
 Posted: 19:48 - 02 Feb 2020 Post subject: |
Worth considering the rider can be counted as "movable ballast" Both for race bikes (leaning and getting the knee down) and off-road (standing on the pegs.)
<addendum> Superbowl tonight so I've got plenty of beer in. Currently sampling Camden's "Off Menu" IPA  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Easy-X |
| JackButler |
| stevo as b4 |
| JackButler |
| Easy-X |
 Posted: 02:33 - 03 Feb 2020 Post subject: |
| stevo as b4 wrote: | Post by OP is pointless... |
Most certainly I think it's a case of not quite knowing what the question is. However, I know the answer certainly isn't the current crop of 125 4-stroke street bikes.
Having said that, props to Honda for turning out the MSX, Monkey and Cub for a touch of variety whereas Yamaha and Kawasaki have unimaginatively shrunken down the MT & Ninja lines.
Talking of the Grom: when someone goes bat-shit crazy and drops in a CB300R engine are they totally mad or are they creating something magically denied to us for purely marketing reasons? ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| wr6133 |
| DJP |
 DJP Crazy Courier
 Posted: 10:29 - 05 Feb 2020 Post subject: |
I read it thus: What would an engineer build with a clean sheet, minimalist design unencumbered by regulatory considerations?
Plenty of research (by car & bike manufacturers) suggests that the optimum cylinder size for power/economy trade off is 400-500cc.
So how about a 400cc single: Lightweight, compact, economical. BUT... Probably not very powerful.
So how about an 800cc twin? Now we're talking: Nice compact engine, whole bike not much bigger or heavier than a 125, but with about 5 or 6 times the power, and still with decent economy.
Triples and fours? Fine engines for sure, but we're starting to lose the compact dimensions and economy.
So I'm going to go with an 800cc (ish) lightweight twin. And they already exist: Think Yamaha MT07 or KTM 790.
Both decently quick. Both capable of impressive economy. Neither much bigger or heavier than a 125.
Sorted! ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
| MarJay |
 MarJay But it's British!
The last post was made 6 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
