GSX650F K9 rhythmic light flicker
Renzakuken
PostPosted: 00:38 - 06 Feb 2020    Post subject: GSX650F K9 rhythmic light flicker Reply with quote
Hello all
I noticed today when riding home in the dark that my headlights seem to flicker as if I had a poor alternator and my indicators were on. Weirdly, there's no issue with that and they weren't!
Does anyone have any ideas of what this could mean?
CBR 125 2006 STOLEN
GSX600F 2003 SOLD
GSX650F 2009 CURRENT
jaffa90
PostPosted: 01:16 - 06 Feb 2020    Post subject: Reply with quote
A flicker sounds like a poor connection, dimmer is a power reduction.
I would replace the bulb.
Easy-X
PostPosted: 10:35 - 06 Feb 2020    Post subject: Reply with quote
Dimming at the same sort of rate as if the indicators were on Thinking
Maybe a parasitic drain from the flasher relay output, enough to trigger it?
Do you notice anything while stationary? If so try pulling the flasher relay and see if the effect persists. (Or a quick test ride without it if you can do so safely.)
blurredman
PostPosted: 10:49 - 06 Feb 2020    Post subject: Reply with quote
I have seen 'going bad' coils causing this.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:18 - 06 Feb 2020    Post subject: Reply with quote
Sounds like your charging system cant cope will all of them at the same time.
Start it, disconnect the stator and then apply your multimeter set to 50v ac (approx) across the three wires in each possible combination of pairs.
I'm betting at least on of the pairs wont be kicking out a voltage.
Triumph Sprint ST 1050
The last post was made 6 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 44.14 Kb
