1996 Kawasaki zx7r issues after plug change
Joe89
PostPosted: 20:29 - 06 Feb 2020    Post subject: 1996 Kawasaki zx7r issues after plug change Reply with quote
Hi everyone I’m looking for some help with my bike rather than going to the local rip off garage ..
I’ve had my bike outside over winter it wouldn’t start , cleaned up all the connectors and new battery and it ran but rough
It’s now garaged , cleaned up the connectors even more and done a oil and filter change , then I changed the plugs ..
The 3rd plug was stuck , felt seized so I sprayed some WD down there only a bit , left it 10 mins and then got it out ..
Put the 4 new plugs in ( the old ones was rusted and rotten )
The bike started right up ran better then cut out - it does this when cold and not kept revved up abit ...
So now after cutting out it won’t start , I noticed a pipe off under the air box I must of knocked off when messing with them plugs , I’ve not put it back on with a jubilee clip but still nothing .. it’s got a fully charged battery aswell . Any info would be much appreciated
Here’s photos
https://ibb.co/t2kPNdM
https://ibb.co/frfV1Wk
Nobby the Bastard
Harley Gaydar
PostPosted: 21:57 - 06 Feb 2020    Post subject: Reply with quote
First off, whats the voltage measured on the battery with a multimeter?
Triumph Sprint ST 1050
jaffa90
PostPosted: 01:11 - 07 Feb 2020    Post subject: Reply with quote
"""Hi everyone I’m looking for some help with my bike rather than going to the local rip off garage .."""""
The bike is 24 years old so a rip off garage is out of the question.
Not worth much so sell it for spares and buy another bike.
JackButler
PostPosted: 07:59 - 07 Feb 2020    Post subject: Reply with quote
There's a few keywords in there which set the alarm bells ringing.
First off, where did you source those new plugs? Fakes are now endemic in the marketplace & unless you are very particular where you get them from there is a high probability they're fake.
Standard diags proceedures should automatically kick in. Does the fuel flow? Does it spark? Is it a 'healthy' turnover on the button?
Is it flooded?
Is it fresh petrol?
Check all of those & if all check out fine it's time to distinguish between elektrikal gremlins & fuel fukwittery. Reach for your can of Easystart.
I can bet you £5 that standing outside over winter means the fuel went off & gummed up in your carbs. If the carbs have never been rebuilt since new then all of the internal NBR seals are fubar, the pilots are blocked & the float needles aren't seating.
But then this is the T'internets & it's probably your side stand switch or drive chain adjustment.
I clean my guns with the tears of the snivelling, left wing scum.
Joe89
PostPosted: 18:22 - 07 Feb 2020    Post subject: Reply with quote
The fuckin thing started up , just knocked a vacuum hose off and now it’s fine . Cheers anyway
Joe in Cornwall
The last post was made 6 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 43.16 Kb
