 Zarishel L Plate Warrior
 MCN Super Spammer
 Posted: 14:30 - 10 Feb 2020 Post subject: |
Yes, and YES.
There's normally a mesh screen either in the petcock itself or on the take-off pipe in the tank.
Yes I have had problems with in-line filters, usually them getting an air-lock and fuel flowing out, momenterily, faster than it clows in, so the carb starves of fuel and engine stutters.
On the trials bike, that may suffer from fuel contamination, both from field filling and from the fact its a two-stroke and needs petroil, pre-mixing, I did find an inline fiel filtyer than works, it was a genuine Amal glass filter and not cheap. Cheap ones have never worked for me, and the ultimate answer on the road bikes has been to tackle at source and not let the tank get silted up, by proper POR15 clean and treat.
I would NOT put a 'common' plastic in-line filter on anythging; most on e-bay are sized for strimmers and such and likely wont flow even enough fuel for a 125 4-stroke at full throttle, larger Halfords type ones that have higher peak flow rate, are generally sized for cars, and will tend to drain and air-lock, in the time it takes the float bowls of a typical multi to empty, before they start filling.. ie not very helpful....
Hence expensive glass Amal filter on the trials bike, NO inline filter on the road bikes, and a POR5 treatment. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
 Polarbear Super Spammer
