Carb tune pro dead or carbs issue?
Gsxr_rory
PostPosted: 02:20 - 11 Feb 2020    Post subject: Carb tune pro dead or carbs issue? Reply with quote
I've got a gsxr srad 600. Carbs were totally rebuilt last year. Bike starts and runs yet when the carb tune pro is connected there's literally nothing no reading at all?
I've checked double checked and triple checked and cannot for the life of me find out why.
If you turn the carb tune pro upside down you do get a little reading bit nothing worth writing home about.
Any ideas?
Easy-X
PostPosted: 02:44 - 11 Feb 2020    Post subject: Reply with quote
I take it this is carb balancing gear? You're only measuring vacuum pressure so...
There is no pressure Smile Well, none to measure so that would hint at a blockage somewhere in the chain. Either the port on the carbs, the pipes or... the gauges are knackered Sad All of 'em?! I'm assuming there's four?
Simple tests for almost any equipment: try it on another bike or borrow kit to test on your bike and see which of the two is "at fault."
JackButler
PostPosted: 08:56 - 11 Feb 2020    Post subject: Reply with quote
This is a Morgan Carbtune yeah?
Have you tried sucking on the pipes to create your very own vacuum?
I clean my guns with the tears of the snivelling, left wing scum.
Gsxr_rory
PostPosted: 11:17 - 11 Feb 2020    Post subject: Reply with quote
Hi,
Yes this is a Morgan carb tune pro.
I haven't tried sucking up give it a go and see what happens!
mentalboy
PostPosted: 13:12 - 11 Feb 2020    Post subject: Reply with quote
Try opening the taps on the gauges vacuum pipes...
Make mine a Corona.
Gsxr_rory
PostPosted: 22:41 - 11 Feb 2020    Post subject: Reply with quote
So today I refitted the carb tune pro. I tried it without the restricted in and the bars did move but barely. With them fitted it doesn't even register.
I tried sucking on the pipes and the bars move perfectly .
I removed the pipes from the carb tune whilst engine was running and there was definitely vacuum on all four cylinders.
I'm at a total loss now?? Any ideas?
Nobby the Bastard
Harley Gaydar
PostPosted: 08:34 - 12 Feb 2020    Post subject: Reply with quote
Crap seal between the pipes and the carbs.
Triumph Sprint ST 1050
Gsxr_rory
PostPosted: 00:22 - 13 Feb 2020    Post subject: Reply with quote
Evening,
Would an incorrectly set up bank of carbs cause this issue? I.e if it's running rich or lean?
I'm at a loss now and figure this could possibly be a cause
mentalboy
PostPosted: 01:12 - 13 Feb 2020    Post subject: Reply with quote
Gsxr_rory wrote:
Evening,
Did you rebuild the carbs last year?
Is this the first time you've used carb balancers?
If the bike runs then you have a vacuum, as per Nobby, it is going to be an issue between the carb ports and the balancer.
Check that the pipes are tight at the balancer end, ideally the vacuum taps should be closed when you start up the bike and then open them up gradually to get a steady reading and, lastly, how have you connected the pipes to the carb ports? Those are the only three areas that can give grief.
Can you put up a pic of the set up in situ?
Make mine a Corona.
The last post was made 6 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.30 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 59.85 Kb
