DIY Question
colink98
PostPosted: 12:31 - 11 Feb 2020    Post subject: DIY Question Reply with quote
so picked up this toy box at the charity shop for all of 25 notes...
i have given it a clean and wax, but I'm unsure as to what to do with the lettering.
https://i.imgur.com/39Yes7i.jpg
i was thinking of some type of acrylic which can be coloured and poured into the recess to set hard.
but i wouldn't know what to get......
any advice ?
Ride it like you stole it.
PostPosted: 12:34 - 11 Feb 2020    Post subject: Reply with quote
No idea but I'm jealous. What a lovely box.
Triumph Trophy Launch Edition
Nobby the Bastard
Harley Gaydar
PostPosted: 12:36 - 11 Feb 2020    Post subject: Reply with quote
I'd just use blackboard paint.
Triumph Sprint ST 1050
mentalboy
PostPosted: 12:47 - 11 Feb 2020    Post subject: Reply with quote
Gold leaf is always fun to play with, cheap too.
Make mine a Corona.
BTTD
PostPosted: 13:28 - 11 Feb 2020    Post subject: Re: DIY Question Reply with quote
any advice ?
I've seen a few youtubes on using coloured epoxy on table tops, or if your're feeling fancy you could melt pewter into it (I have no idea how expensive that might be).
Riejufixing
PostPosted: 13:48 - 11 Feb 2020    Post subject: Reply with quote
Paint-on single part red laquer. I've got a tin of it somewhere, can't remember what make.
You've waxed it? Will the wax have got into the lettering (not bloody Briwax)?
colink98
PostPosted: 13:50 - 11 Feb 2020    Post subject: Reply with quote
Beeswax with a slight tint.
its not likely to have got into the letters which has been cleaned.
Riejufixing
PostPosted: 13:52 - 11 Feb 2020    Post subject: Reply with quote
I'll nip out ans see if I can find that tin....
colink98
PostPosted: 13:53 - 11 Feb 2020    Post subject: Reply with quote
Hmmmmm....
i have some of this to hand.
However as a kids toys box i wanted to used different and bright colours for each letter.
colink98
PostPosted: 13:55 - 11 Feb 2020    Post subject: Reply with quote
we have a lot of charity shops in the area and i always like to spend a while looking for mostly furniture.
a lot of its the same old rubbish but occasional you come across something that looks lovely.
picked this up a while ago...
cleaned up real nice...
its small enough to sit in the hall way without being in the way.
https://i.imgur.com/5krTKIM.jpg
cant remember what i paid...
but it would have only been 20-30 notes at best.
Easy-X
PostPosted: 14:26 - 11 Feb 2020    Post subject: Reply with quote
My wife loves all this sh*te Smile She tends to go with rough whitewash - that "shabby-chic" look.
Riejufixing
PostPosted: 14:46 - 11 Feb 2020    Post subject: Reply with quote
Nope. Was probably Japlac, which does not seem to be available. Perhaps use Miranol if you can find it, or some other high gloss enamel. Maybe just (solvent based) high gloss alkyd paint like Dulux trade.
Riejufixing
PostPosted: 14:55 - 11 Feb 2020    Post subject: Reply with quote
Ah. Humbrol enamel (solvent based!).
https://www.humbrol.com/uk-en/shop/paints/enamel-paints.html
Coverage said to be 0.3sqm per 14ml. About £2/tin. Loads of different gloss colours.
c_dug
PostPosted: 15:10 - 11 Feb 2020    Post subject: Reply with quote
I've filled similar with gel-coat before which turned out really nicely and comes in every colour under the sun. Never tried gel-coat on wood mind.
I don't see why it wouldn't work on wood though.
PostPosted: 15:29 - 11 Feb 2020    Post subject: Reply with quote
Wub that.
It should be mine, it's got my cushion on it. Laughing
MCN
PostPosted: 16:50 - 11 Feb 2020    Post subject: Reply with quote
That looks like a 'West of Scotland Free Church (yer no here tae be comfortable' pew.
They softened thing later when you could bring a cushion.
colink98
PostPosted: 17:25 - 11 Feb 2020    Post subject: Reply with quote
i will take a look cheers
Islander
PostPosted: 17:42 - 11 Feb 2020    Post subject: Reply with quote
Copper leaf is cheaper and a good place to start Very Happy
I'd be seriously tempted to either copper leaf it or look at inlaying it with something interesting like kirinite.
mentalboy
PostPosted: 23:42 - 11 Feb 2020    Post subject: Reply with quote
The copper leaf would contrast better with the colour of the wood.
Make mine a Corona.
PostPosted: 00:24 - 12 Feb 2020    Post subject: Reply with quote
Copper or gold leaf will be picked out by small fingernails in no-time flat.
Coloured wood dye then wax? Keeps it wood then and a very robust/repairable finish.
Filling with clear, colured epoxy (+ or - sparkles) would be awesome but I think you'd need to fill it proud them sand it back down level and polish to get it to look good. Probably wouldn't play well with the wax finish.
If you did epoxy fill, You could roll a couple of filler coats of clear epoxy over the top, flat it down then yacht varnish for a super-durable, mirror-gloss finish.
These guys supply lots of coatings. they do resin dyes too. https://www.ecfibreglasssupplies.co.uk/
This varnish is second to none. https://www.epifanes.nl/uk/the-epifanes-range-of-paints-amp-varnishes/yachting You can apply it with a cloth.
Seems a lot of faff though.
The gelcoat idea has merits but don't use actual gelcoat. it's designed to apply to the inside of a mould before you apply fibreglass. It';s flowcoat you'd be lookng for.
WD Forte
PostPosted: 21:10 - 12 Feb 2020    Post subject: Reply with quote
If you do use epoxy or resin, seal the wood first or you could get air bubbles from the wood fibres into it.
I think epoxy once cured is less toxic for the little uns to lick and chew on and it can come in range attractive colours
bikers smell of wee
PostPosted: 21:18 - 12 Feb 2020    Post subject: Reply with quote
Allow it to acclimatise to somewhere warm, then move it somewhere cooler (but still in the epoxies thermal range) and apply the epoxy. Any microbubbles will contract and draw the epoxy back into the wood.
I have some experience with epoxy on wood. I made this.
https://lh3.googleusercontent.com/oimH7o1PwTfSRdppXE7I4m8tib5p3B-dlgDe8J7zrxAtI0fFenszEGyJjlubE0_Kl28dwuW3QFH3LsBMr6D1MvxqCI17PgSRKMRHhGxu1DfrvJ_ZtEPduwqSHp8X6CJ-yOieXfZ6oQ=w1155-h866-no
If you do decide to do it, long sleeves and nitrile gloves. Uncured epoxy on your skin can do nasty things.
PostPosted: 22:39 - 12 Feb 2020    Post subject: Reply with quote
Fucking hel, Stinkers is God, He made a loch.
hellkat
PostPosted: 23:03 - 12 Feb 2020    Post subject: Reply with quote
ColinK98 wrote:
as a kids toys box
Damn.
That was not the sort of toys I had in mind for such a venture.
I was going to suggest upholstering it in black leatherette with bronze humbrol (do they even do rose gold humbrol????? Laughing )
hellkat
PostPosted: 23:19 - 12 Feb 2020    Post subject: Reply with quote
Islander wrote:
kirinite.
OMG. Wub
I had to google that.
But wow ... teal pearl kirinite.
Perfect.
The last post was made 5 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.50 Sec - Server Load: 2.41 - MySQL Queries: 15 - Page Size: 130.51 Kb
