Ratting?
Bike Chat Forums Index -> Dear Auntie BCF... Goto page 1, 2, 3  Next
andym
PostPosted: 19:42 - 13 Feb 2020    Post subject: Ratting? Reply with quote
Anyone do this with a slingshot?
Any tips on how to improve my accuracy?
My new job is in a recycling centre with a shit load of moving targets (think ratatouille auditions), but because of licensing laws in Scotland it's a bit of a faff getting an AWC (air weapon certificate), so I bought a hunting slingshot a few weeks ago.... having never touched one in my life.
The sling came with 1000 6mm ball bearings and after a few hundred shots I learned a couple of valuable lessons, my aim is shit and a rat will scurry off even after 4 point blank shots (including a spine shot).
Thinking it was just the bearings that weren't up to the job I bought a few hundred 10mm bearings, but found the little shits can still walk it off unless it's a head shot, so now I've bought a couple of hundred marbles, (14-18mm), to try.
So far I'm up to:
At least 500 penetrations where the rat scurries off (no idea if they survive the injuries or not).
Around 80 confirmed kills (where I can pick the twitching body up).
10-15 grab and kills (lightning fast reflexes or something).
7 kills in a night, (some finished off with a smack off a concrete block).
4 bearings (10mm) in a single rat that still ran off (dragging it's back end).
3 head shots with a putter (after 2 point blank headshots bursting both eyes) on the hardest rat I've killed so far, (think 3 men and a hammer).
So far 1 bite from a rat I picked up that had a broken tail and was able to swing up and get through the glove.
Riejufixing
PostPosted: 19:51 - 13 Feb 2020    Post subject: Reply with quote
You will never be able to hit a rat with a slingshot. If you put a big stone in it, you'll be able to defeat the Philistines, but that's about it.
Buy a catapult, like this:
https://www.bladespro.co.uk/blogs/news/what-are-the-best-hunting-catapults-in-the-uk-for-survival
Edit: Better to buy a Fenn MKIV tunnel trap, or even use poison bait. Then you don't have to wait for them to come.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:59 - 13 Feb 2020    Post subject: Reply with quote
+1 at throwing bricks at them.
Triumph Sprint ST 1050
andym
PostPosted: 20:29 - 13 Feb 2020    Post subject: Reply with quote
The sling I'm using is closer to the TRUMARK FS-1 from that link.
These rats are crafty, they see the hi-vis and scarper instantly (usually from about 100 feet away).
Nobby, really? Getting close enough to grab them or cave their skulls in with a golf club ain't good enough?
Fisty
PostPosted: 21:07 - 13 Feb 2020    Post subject: Reply with quote
Put the slingshot in the bin and buy an air rifle.
Fatter and faster than Fret
Riejufixing
PostPosted: 21:08 - 13 Feb 2020    Post subject: Reply with quote
So it's a catapult. Bit too dangerous, really, I would have thought.
I'd be inclined to get an air rifle the legit. way:
https://basc.org.uk/basc-scotland/airguns-in-scotland/
The only issue might be getting permission from your work to control vermin on their land.
The traps/poison work well, but aren't quite as interesting.
Skudd
PostPosted: 21:16 - 13 Feb 2020    Post subject: Reply with quote
We used to throw tins of baked beans at the rats at ASDA.
Did you ever wonder how the tins got damaged?
Islander
PostPosted: 22:10 - 13 Feb 2020    Post subject: Reply with quote
This.
It's not hard to get an AWC, fill a form out, get a referee, get a couple of photos, post it off. You need somewhere secureish to store it, a locked cupboard will do.
.177 is probably best - it'll give you a flatter ballistic trajectory and will do the job.
PostPosted: 22:16 - 13 Feb 2020    Post subject: Reply with quote
Have you tried using the catapult to launch dead rats at living rats?
Riejufixing
PostPosted: 22:45 - 13 Feb 2020    Post subject: Reply with quote
Interesting thought. A cat-a-pult. Probably something on video somewhere done by some awful person....
Islander
PostPosted: 23:41 - 13 Feb 2020    Post subject: Reply with quote
Rat-a-pult, surely?
PostPosted: 23:59 - 13 Feb 2020    Post subject: Reply with quote
Hitting them with a long thin stick is traditional.
Polyhedral dice are evil when fired from a slingshot and can be bought in bulk from China. Just saying like.
defblade
PostPosted: 06:40 - 14 Feb 2020    Post subject: Reply with quote
Get a works terrier.
Failing that, peanut butter or nutella smeared on a brick keeps the little gits still for a while as they lick it up.
PostPosted: 10:21 - 14 Feb 2020    Post subject: Reply with quote
Islander wrote:
Rat-a-pult, surely?
https://www.youtube.com/results?search_query=squirrel+launcher
Easy-X
How effective would an air rifle be against these things anyway? Rats have got pretty mean these days.
MCN
PostPosted: 11:32 - 14 Feb 2020    Post subject: Reply with quote
We made slings (catapults) from 6mm reo-bar and 1/4" wide strips of rubber sheet that was used to line the inside of pumps and pipes in a process plant. (Sand quarries possibly use it too for.pumping wet sand into stockpiles.)
We loaded 1/2"-3/4" mill-balls as ammo.
Accurate enough to hit a beer can (empty) from about 50' about 85% of the time.
I used mine to skull rats around the workshop on night shift.
Not many that I hit walked very far. And most were stopped dead first strike.
We stopped using little stones for ammo as they are shite.
Steel or lead was best.
Try a tackle shop for lead shot.
Expect the environ-mentalists to be up in arms about the lead.
(Just ignore the Vegans, as we do.)
PostPosted: 12:25 - 14 Feb 2020    Post subject: Reply with quote
You want a .22 or ideally a .25" with the heaviest flat-nose or hollowpoint pellets you can find. You need the shock factor for chest-shots. Smaller, higher velocity rounds just punch holes in them.
Or gamo make an "air shotgun" which takes pre-loaded re-usable capsules of fine shot that splatters the little fuckers across the floor. 12" spread at 10ft. Fit a reflex sight and have-at them.
MCN
PostPosted: 12:29 - 14 Feb 2020    Post subject: Reply with quote
Licensing laws..... air weapons/bows/x-bows etc.
Sling-Shots are probably governed too. 🤔
PostPosted: 12:39 - 14 Feb 2020    Post subject: Reply with quote
Nah, just the air rifles.
You can buy a bow that will take down an adult deer at 60 yards with no licence at all. (it would be illegal to do-so, but you could).
Maybe OP should learn to use a "proper" sling. Use much bigger ammunition. I bet the wee bastards wouldn't walk away from that.
BTTD
PostPosted: 13:13 - 14 Feb 2020    Post subject: Reply with quote
.410 moderated single barrel shotgun?
It sounds like an air rifle is as much of a pain to get as a shotgun licence (unless Scotland have more complicated laws for those too), so why not get a nice little firearm.
Riejufixing
PostPosted: 13:24 - 14 Feb 2020    Post subject: Reply with quote
Effective. Used at sensible ranges you can humanely take rabbits with air rifles. Being a reasonable shot and having time are the two main issues, which is why traps are probably better.
bhinso
PostPosted: 14:28 - 14 Feb 2020    Post subject: Reply with quote
Give them bikes and make them go ride in the rain.
andym
PostPosted: 14:52 - 14 Feb 2020    Post subject: Reply with quote
I'll update this tomorrow after I've tried a few marbles Wink
dynax
PostPosted: 15:07 - 14 Feb 2020    Post subject: Reply with quote
There is an unwritten code of conduct when it comes to vermin control, i suggest you visit this forum and get some proper advice Thumbs Up
https://www.airgunforum.co.uk/community/index.php
Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber
JackButler
PostPosted: 15:24 - 14 Feb 2020    Post subject: Reply with quote
Even rats deserve a quick clean kill.
If they won't let you own an airgun then there are some ingenious methods of trapping & despatching on Yootoob.
I clean my guns with the tears of the snivelling, left wing scum.
The last post was made 5 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.34 Sec - Server Load: 5.07 - MySQL Queries: 13 - Page Size: 129.03 Kb
