What does your kill switch do?
jaffa90
PostPosted: 01:46 - 21 Feb 2020    Post subject: What does your kill switch do? Reply with quote
I have had umpteen bikes and never used them but only checked them.
My latest bikes kill switches always prevented engine turn over when using the start button.
mentalboy
PostPosted: 01:57 - 21 Feb 2020    Post subject: Reply with quote
And the earlier ones didn't?
First thing to check when the bike wouldn't start was whether you had accidentally knocked the kill switch off.
Can't imagine anything has changed on them since they were introduced.
Make mine a Corona.
PostPosted: 02:49 - 21 Feb 2020    Post subject: Reply with quote
Early 90s Hondas allow you to turn the strarter with the kill switch off.
Oh how we laughed!
mentalboy
PostPosted: 03:16 - 21 Feb 2020    Post subject: Reply with quote
Oh how we laughed!
Come to think of it, my 90's 'Blade was like that - mind you, when you say 'kill switch off' you probably didn't mean 'off' as in 'sitting in a box with the fuel pump and a whole host of other unnecessary weight'. Laughing
Make mine a Corona.
yen_powell
PostPosted: 09:16 - 21 Feb 2020    Post subject: Reply with quote
I have hired japanese bikes abroad that I have also owned in the UK and quite a few don't have a kill switch at all.
XT1200Z and a DR350 in bits
PostPosted: 09:17 - 21 Feb 2020    Post subject: Reply with quote
My Suzuki GT500 kill switch used to operate at the first hint of rain.
I'm not sure that was what Suzuki intended though. Laughing
blurredman
PostPosted: 09:48 - 21 Feb 2020    Post subject: Reply with quote
Never use mine anyway.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:04 - 21 Feb 2020    Post subject: Reply with quote
Turns off everything except the trigger from the ignition to the heated grips relay....
Triumph Sprint ST 1050
PostPosted: 12:23 - 21 Feb 2020    Post subject: Reply with quote
Awesome backfires especially so if it has carbs and without a catalytic converter.
Easy-X
PostPosted: 12:50 - 21 Feb 2020    Post subject: Reply with quote
A kill switch just shorts the electrics going to the ignition coil so everything else'll work, just no spark. Isn't that how it works on all bikes?
jaffa90
PostPosted: 13:08 - 21 Feb 2020    Post subject: Reply with quote
No, my 2004 Fazer 1000, Cbf 1000 (forgot year) and both Gsx 1400 bikes killed the start buttons and fuel pumps.
MCN
PostPosted: 14:10 - 21 Feb 2020    Post subject: Reply with quote
Possibly discombooberates the Main Relay switch wire so that Hee-Haw power gets past the main relay.
It depends on how the OEM wants to wire it.
I have never had a phaph with a kill switch.
The Rule is not to use the kill switch and only use the ignition key to shut off the engine.
That rule is to prevent 'over-use' creating a weakness in the system.
Unless it's used to fcuk with folk. That is 100% not a maintenance issue.
ThatDippyTwat
PostPosted: 14:53 - 21 Feb 2020    Post subject: Reply with quote
My Viffer won't even turn if the kill switch is flicked.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:00 - 21 Feb 2020    Post subject: Reply with quote
Also turns off the lights and the dash on the strumpet.
PostPosted: 15:49 - 21 Feb 2020    Post subject: Reply with quote
At least with that you are never going to get caught out if someone has flicked the kill switch on.
WD Forte
PostPosted: 16:21 - 21 Feb 2020    Post subject: Reply with quote
Depends
On AC CDI bikes like Easy X's and Blurredmans
they short power from the CDI source coils to ground
preventing or killing the sparks
Some bikes, they open and cut off DC power to the
ignition circuit and coils and that's all
Those are simplest functions
On other bikes and in theory they can do whatever they're designed to do
related to stopping and inhibiting the starting.
On my bike it's a modified form of an AC CDI switch to give a ground to a relay coil
where the NC contacts supply the ignition components.
depends see?
bikers smell of wee
Easy-X
PostPosted: 17:41 - 21 Feb 2020    Post subject: Reply with quote
Yeah, the DT is so old-skool you don't so much "hot wire" it as just unplug the ignition cable Sad
Just checked the Rebel and the kill switch seems to operate the fuel pump (and I assume also the ignition coil) but everything else works, even the starter motor.
Sister Sledge
PostPosted: 19:44 - 21 Feb 2020    Post subject: Reply with quote
Mine won't crank when off at the kill switch but I want to bypass it for maintenance reasons - the bike isn't used every day and has a dry sump system. I want to be able to crank it without the engine starting so that I can be sure that oil is at all critical surfaces when it does fire up. Kinda like you do with large diesel engines!
CCM 404 DS
Hong Kong Phooey
PostPosted: 22:32 - 21 Feb 2020    Post subject: Reply with quote
Required by law in Murika, probably same for EU.
CBR6 kills engine, same way as if you drop sidestand in gear.
Won't let starter turn, this is 99 carbs model.
WreckTangle
PostPosted: 19:17 - 22 Feb 2020    Post subject: Reply with quote
Going back to the original question, I think the reason for the kill switch is that in an emergency, if the bike is crashed and on it's side, it might be a pain to get to the ignition switch to turn off the bike (my ignition switch is on the side of the bike, not the top, like most other bikes, which would be impossible to get to if it had been put on it's side) so it would be faster to hit the kill switch to kill the engine, than pick the bike up and turn it off. (if there is spilt petrol, time would be of the essence)
and.........
My friends reason is 'I usually drop the bike and the tip over switch turns it off' Thinking
My wife asked me to get her something that goes from 0-100 in under 5 seconds for her birthday. ......................I got her a bathroom scale.
mentalboy
PostPosted: 23:23 - 22 Feb 2020    Post subject: Reply with quote
and.........
Surely the reason for a kill switch (which isn't included in the original post) is covered when you do your CBT, which as a recent Mod 2 passee you would have covered in the not too distant past. Back in the 80's we just assumed it was for the pillion to flick when our superhuman filtering skills scared the shit out of them. Rolling Eyes
Make mine a Corona.
MCN
PostPosted: 23:39 - 22 Feb 2020    Post subject: Reply with quote
and.........
I think you misinterpreted the OP's question.
"What does your kill switch do?"
Your answer to, What is a kill switch for?
Jist sayin'.
hellkat
PostPosted: 20:45 - 06 Mar 2020    Post subject: Reply with quote
Thinking
I think mine does The Macarena.
Thinking
recman
PostPosted: 22:09 - 06 Mar 2020    Post subject: Reply with quote
hellkat wrote:
Thinking
Thinking
Mine engages.
1198
PostPosted: 08:08 - 08 Mar 2020    Post subject: Reply with quote
it either kills the ignition or kills the ignition and starter in my experience if it doesn't kill the starter too you can look an absolute chump trying desperately to start a bike with it turning over fine but not firing...
The last post was made 6 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 129.52 Kb
