Vauxhall Agila fuel filler pipe replacement DIY or garage?
Ribenapigeon
PostPosted: 12:17 - 19 Feb 2020    Post subject: Vauxhall Agila fuel filler pipe replacement DIY or garage? Reply with quote
Im pootling about in my mums old Vauxhall Agila and the fuel filler pipe is rusted to F. Pupes cost about £40 excluding fittings (jubilee clips, bolts etc). Its not outwith my spannering skills but it might be easier and less time consuming for me to just do an extra shift at work if the cost of having a garage do it is cheap enough. It looks lime a sub 1 hour job for a properly tooled uo mechanic. So how much do you think it would cost?
Riejufixing
PostPosted: 13:31 - 19 Feb 2020    Post subject: Re: Vauxhall Agila fuel filler pipe replacement DIY or gara Reply with quote
Phone up your garage and ask them. Say £45/hr labour rate plus the dreaded at a guess unless it's a "glass palace" in which case avoid. Also ask how much for the part, and if thats too much there's no harm in asking if they will fit a part sourced by you.
Sister Sledge
PostPosted: 07:42 - 20 Feb 2020    Post subject: Reply with quote
Is it easy or is it a tank out job too? Sometimes tank straps rust and cause bother too which would add to the expense.
CCM 404 DS
Ribenapigeon
PostPosted: 09:46 - 20 Feb 2020    Post subject: Reply with quote
I'll phone a couple of garages.
jimspeed
PostPosted: 23:08 - 20 Feb 2020    Post subject: Reply with quote
Easy enough job but would be a pain to to with the car on a jack, I wouldn't tackle it without a car lift, the fuel tanks are made from paper thin metal too so be careful with any "wiggling" when trying to separate the rubber joiner from the filler .
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Riejufixing
PostPosted: 23:23 - 20 Feb 2020    Post subject: Reply with quote
Wow, I had no idea, that's quite interesting. Any guesses as to what proportion of (car) fuel tanks are metal these days?
steve the grease
PostPosted: 15:40 - 21 Feb 2020    Post subject: Reply with quote
It's a rebadged Suzuki wagon R. So it probably does have a thin metal tank. Rust bucket cars sadly.
Ribenapigeon
PostPosted: 20:17 - 21 Feb 2020    Post subject: Reply with quote
It has a galvanised body so not a rust-bucket at all. Apart from the slowest gearbox on earth its a great car.
steve the grease
PostPosted: 18:43 - 28 Feb 2020    Post subject: Reply with quote
Ok , I take that on board, some of the early Suzuki built ones were rubbish though.
Ribenapigeon
PostPosted: 12:45 - 29 Feb 2020    Post subject: Reply with quote
They were good cars. Certainly the Vauxhall versions. Vauxhall screwed up when they changed it.
The last post was made 5 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 63.17 Kb
