Playing with sharp things -making gaskets
WD Forte
PostPosted: 00:28 - 21 Feb 2020    Post subject: Playing with sharp things -making gaskets Reply with quote
Reassembling my spare engine and see new gaskets could cost me in
the region of £70
bollards to that
£13.95 for a 2.5M x 50 Cm roll of 0.8mm Flexoid and a few pound shop knives
plus found items and I can make my own up with lots left for other jobs.
This rear cover is the single biggest gasket to make
https://imgur.com/5NcuO0p.jpg
I'd already cut two peices of flexoid off the roll when it arrived
and kept them sandwiched between two pieces of board to flatten them
I start by laying the paper over the cover making sure to overlap all edges,
then using a long tapered blade knife, cut first holes and fit wall plugs to hold it inplace
https://imgur.com/998zKIt.jpg
I find a sawing twisting action helps cut the holes cleanly
Keeping the paper as flat as possible I work my way around using whatever
fits snugly in the holes to hold the paper securely.
https://imgur.com/CXo60AC.jpg
After all holes are cut and plugged I cut a cross in the paper and use scissors to cut the majority of
the centre out before cutting the inside profiles.
I dont try to cut them in one continuous cut, I do them in sections
and may hold paper to the cover to stop any dragging where it gets thin.
https://imgur.com/yen78wf.jpg
Mostly done inside just need to trim a few parts
Pound shop knives dont keep a good edge long doing this and they can start to drag when
losing their edge so changing blades may be neccessary.
https://imgur.com/dCWDgmO.jpg
Nearly there, probably give it a wee trim and snip here and there before final fit.
I trimmed the outside close to the edge with scissors but wont try to do the
final outer profile trim until the cover is bolted to the block
that's about £30 saved already and its kind of enjoyable to do.
https://imgur.com/t94Yoc4.jpg
bikers smell of wee
PostPosted: 01:48 - 21 Feb 2020    Post subject: Reply with quote
I oil the gasket face, "stamp" it onto the paper, draw round it with a pencil then cut it out with paper shears.
Do the holes with punches hammered against a bit of aluminium sheet (£2.50 off ebay for a punch set).
blurredman
PostPosted: 08:47 - 21 Feb 2020    Post subject: Reply with quote
Gasket sets for these engines have almost doubled within the last 10 years.
Easy-X
PostPosted: 11:54 - 21 Feb 2020    Post subject: Reply with quote
Nice use of rawlplugs for alignment Thumbs Up
<edit> fixed one of my many inadequacies Wink
Riejufixing
PostPosted: 13:35 - 21 Feb 2020    Post subject: Reply with quote
Easy-X wrote:
Nice use of raw-plugs for alignment Thumbs Up
Are they different from cooked ones? There are things called "Rawlplugs".
Sister Sledge
PostPosted: 19:03 - 21 Feb 2020    Post subject: Reply with quote
I miss doing that sort of thing. Lots of modern gaskets have metal wire in or are like a layered thing.
In the distant past when Britain was very industrial we could simply ask a parent to bring some gasket sheet home from work - at least I now know what it's called and what to buy!
Could you have ironed it instead of using boards to flatten the roll?
CCM 404 DS
WD Forte
PostPosted: 21:40 - 21 Feb 2020    Post subject: Reply with quote
Did the transmission cover earlier and found a clutch cover one
I cut out last year on the machine after scanning it in and creating
a dxf file for it.
Not sure if ironing would help flatten it any quicker or better
but a day or two between sheets of hardboard after coming off the roll
did the trick.
For small-ish gaskets you may not have to bother too much, I just find it helps when making the 2 larger ones.
https://imgur.com/cJplT77.jpg
https://imgur.com/EOMHVMo.jpg
bikers smell of wee
The last post was made 6 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 55.32 Kb
