Starting a bike with a flat battery
Freddyfruitba...
PostPosted: 17:02 - 04 Mar 2020    Post subject: Starting a bike with a flat battery Reply with quote
My battery loses charge when the bike's left unused and I do make use of a smart charger to keep it topped up. But sometimes I do forget - like just now Evil or Very Mad - going out for a run; was all geared up, sat on the drive pointing at the road, pressed the button... nothing. Nada. Zip. Sweet fuck all. So have just put the bike away again, stuck it on charge, and come back into the house in a strop.
Question: are there any easy options to get the bike going quickly under these circs? I'm not on a hill here, and am no longer young/strong enough to try bump starting 200+ kg of bike. If it was the car, I'd have just got the jump leads out and gone round to chat up Janice next door, but as far as I know, jump starting a bike from a car battery is likely to fry my electronics innit? I imagine the same thing applies to those power pack devices? Apart from keeping a spare bike battery permanently on charge in the garage, does anyone have any cunning solution to this?
PostPosted: 17:16 - 04 Mar 2020    Post subject: Reply with quote
Practically, with a modern bike it can be real hit and miss if they start and run OK from a bump start. They are so power reliant.
Wifies ER6N would not run with a flat battery. If it fired it would pop and bang but not run properly.
Nowadays I have one of those small starter battery things. It will start anything. I've used it for a car, bike and even my boat. Just leave it connected till the engines settles down and is running properly and off you go.
edited to add - I have never ever fried any bike, car or hamster, jump starting from one to another. As far as I am concerned 12v is 12v and it will jump.
https://www.batteryfocus.com/wp-content/uploads/2019/07/GOOLOO-1500A-Peak-SuperSafe-Car-Jump-Starter-.jpg
Triumph Trophy Launch Edition
Nobby the Bastard
Harley Gaydar
PostPosted: 17:18 - 04 Mar 2020    Post subject: Reply with quote
You'll have a job to bumpstart a FI bike because they invariably need the fuel rail pressurised to start and the bike won't pressurise it until you press the starter.
Triumph Sprint ST 1050
Riejufixing
PostPosted: 17:34 - 04 Mar 2020    Post subject: Re: Starting a bike with a flat battery Reply with quote
Does connecting a new battery fry the electrics Smile
https://www.screwfix.com/p/streetwize-500a-promo-power-pack-12v/5256r#product_additional_details_container
45 Squiddicks. I have had one like this for about 15 years, and it's still on its original battery, and it still works. It has been invaluable on occasions.
Yes, you can get others. No, I don't know what happens if you've a lithium battery on your bike, but if it's a straight swap-in for a lead acid Id assume it to be OK, someone will be along to say, in a minute.
WD Forte
PostPosted: 17:40 - 04 Mar 2020    Post subject: Reply with quote
I've used a car battery on a bike manys the time
jump started too* and as PB says, 12v is 12v
I'd be more concerned over the health of the battery as
letting them go flat can sulphate up the plates.
Starting should be easy enough but how well is it holding charge?
It may be fine but I'd suggest keeping an eye on it
* I even used a CX to top up a failing Transit battery when it was
struggling to turn the engine over on a frosty morning
Top up, not start! I hasten to add, it wasnt dead flat.
bikers smell of wee
Kawasaki Jimbo
PostPosted: 19:52 - 04 Mar 2020    Post subject: Reply with quote
I've got a small, easily portable jump starter which does the trick.
Regarding blowing electrics, as I understand it a flat battery, a starter motor, etc. will only draw what it needs. The spare battery doesn't force feed anything, so electrics won't be blown. The exception might be when using a car battery with the engine on, where the bigger alternator might cause damage. However, I've done this loads of times without issue before I learned it might be a risk. A running car engine isn't necessary anyhow.
I've also bump started my 2003 R1 quite easily although the FI is probably a primitive version.
PostPosted: 19:53 - 04 Mar 2020    Post subject: Reply with quote
No problem using jump leads from your car battery to start your bike. Just don't have the engine running when you do it.
To be safe, if you are worried about a voltage spike from the bike upsetting the car electrics, disconnect the terminals first so you're just using it as a big cranking battery.
Both batteries are 12v, the car one just holds more charge.
The problem arises if your bike reg/rec tries to regulate the car alternator output.
I used to keep an old car battery charged up in the workshop. It was too dead to turn over the car but would spin the bike over like a good-un. It got nicked by gippos when I left it outside though.
1198
PostPosted: 22:53 - 04 Mar 2020    Post subject: Reply with quote
Why has nobody asked yet about Janice? Pictures of?
Disappointed.
xX-Alex-Xx
PostPosted: 23:40 - 04 Mar 2020    Post subject: Reply with quote
Disappointed.
Here you go:
https://external-content.duckduckgo.com/iu/?u=http%3A%2F%2F1.bp.blogspot.com%2F-1rz5KxncouM%2FVSqQNEJYwkI%2FAAAAAAAABsk%2FelkIQ3NsMuw%2Fs1600%2Fjanice-from-friends-34854473-500-564.jpg&f=1&nofb=1
As mentioned, using a car battery to jump is fine. Just make sure the car engine is off and you don't short out the jump leads on the bike's frame Wink
If the battery's been dead, it'll likely need replacing. Wouldn't hurt to check your voltages with the engine running after it's been replaced to make sure the charging system is able to top it back up
DILLIGAF
Freddyfruitba...
PostPosted: 11:11 - 05 Mar 2020    Post subject: Reply with quote
Thanks all, that's good to know - will jump start off the car next time then!
Battery was at 11V yesterday but the starter motor didn't want to know. All fine today after an overnight charge.
Stroppy cow. Asked her for a topless photo to post here and she gave me the finger.
Suntan Sid
PostPosted: 02:04 - 06 Mar 2020    Post subject: Reply with quote
Prior to replacing the battery, I bump started my FZ1 a few times with no problems at all.
Blah blah
PostPosted: 21:49 - 10 Mar 2020    Post subject: Reply with quote
Trying to start a bike with a duff / weak battery can sometimes stuff the sprag bearing as well, which isn't a cheap and easy fix !
I'd buy a new battery.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:46 - 10 Mar 2020    Post subject: Reply with quote
I'd rather find out why the battery is going flat before I start wasting money.
Riejufixing
PostPosted: 23:53 - 10 Mar 2020    Post subject: Reply with quote
This and the other things that have been said.
It sounds as though the battery could be scrap.
It sounds as though it's not being charged.
This needs looking at and fixing.
bacon
PostPosted: 07:16 - 13 Mar 2020    Post subject: Reply with quote
When my brother scrapped his old focus I kept the Bosch battery. It's not huge by car standards but it is in bike standards. I just jump from that when needed.
So get on the hunt for a freebie battery to leave in the garage.
megaross
PostPosted: 10:15 - 13 Mar 2020    Post subject: Reply with quote
Nothing wrong with jump starting a bike off a car or a jump pack. Ye olde bump start is the king though.
I remember coming out of a mates house about 2am and my tiger not starting, below freezing so standard "Early warning sign" of a duff battery but less than ideal when you want to go home and get some kip.
Took me about 10 tries but managed to bump start it on a dead flat bit of road, also helped a mate bump start his ZZR1400 (that's a 2 man job). You definitely can bump an EFI bike - it depends how dead the battery is. If it's got enough voltage to run your electrics but not enough to power the starter it'll go on a bump.
I've got jump packs and a few "Questionable but good" batteries in the garage and a baby jump pack (like a power bank) but tbh I've never needed to use any of them on a bike.
Anyway - if your battery is going flat after being sat for a few weeks replace it, it's on it's way out.
'07 Tiger 1050
The last post was made 6 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 92.8 Kb
