I would like some advice on a nsr125r(2001) gearbox problem
deFatherland
PostPosted: 01:19 - 05 Mar 2020    Post subject: I would like some advice on a nsr125r(2001) gearbox problem Reply with quote
I bought a new(used) engine for my honda nsr125r and put it on. I got it working and moving but the gearbox is not very happy. It wont go to neutral when you are stopped, when you are moving it goes in neutral just fine. And also the clutch isn't right, when you are stopped and put it in gear the clutch doesn't disengage when you pull down the lever. Its a quite problem for me cuz my battey is dead and i have to pushstart it quite a lot. Some advice would be helpful. Smile
davebike
PostPosted: 08:36 - 05 Mar 2020    Post subject: Reply with quote
It is a clutch issue you describe a dragging clutch assuming it is correctly adjusted!
Get a clutch gasket, drain the oil, pull the clutch cover off and strip the clutch
Check the steel plates are not rusty clean all the plates and re-assemble
try again if still not cleanly disengaging try the plates from you old engine or a complete new set steels as well !
Dave
NC750Xdct + others at work !
[email protected]
deFatherland
PostPosted: 20:29 - 05 Mar 2020    Post subject: Reply with quote
Thanks for the advice i will try this as soon as i can
The last post was made 6 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 34.53 Kb
